New Member
Discussion in '2nd Gen. Tacomas (2005-2015)' started by J Fitz, Jul 20, 2017.
  1. Jul 20, 2017 at 8:38 AM
    J Fitz
    J Fitz [OP] Member
    Jim
    Looking to buy
    Hi All,
    I am new and just posted in the NM areas as was suggested but I wanted to come in here as well for the gen II help. I will not repeat everything but I hope to own a Tacoma very soon.
    I drove an 07 6 speed manual Tacoma this morning with 168K miles on it, double cab, $14K. Frame was not done, not sure if it should have been or not. The underside was very clean, but I did see some level of rust up on the front gussets. I am not very knowledgeable in the years and issues so I am seeking your rapid advice. I know that pretty much all of them are solid, but in terms of buying going forward should I look for a >2010, less than xx miles, etc...
    Needs: Double cab, 6 speed. I could drive an auto-seems like it would be more fun with a stick.
    Any advice would help, I am looking in real time right now. Anything around Charlottesville, VA let me know.
    Thanks,
    Jim
    scottalot and ChadsPride like this.
  2. Jul 20, 2017 at 8:39 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Welcome to TW!
  3. Jul 20, 2017 at 8:41 AM
    musher
    musher Well-Known Member
    Alabama(born) >(the world)>Alaska(now)
    2017 Tacoma
    I'd rather not think of all the $ spent :(
    Welcome to TW :wave:
  4. Jul 20, 2017 at 8:42 AM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    Welcome to TW Jim!
    scottalot, musher and ChadsPride like this.
  5. Jul 20, 2017 at 8:52 AM
    J Fitz
    J Fitz [OP] Member
    Jim
    Looking to buy
  6. Jul 20, 2017 at 9:01 AM
    medic2230
    Murph
    Bama! Roll Tide
    Welcome to TW Jim :wave:
    scottalot likes this.
  7. Jul 20, 2017 at 9:11 AM
    TacoGold
    TacoGold Well-Known Member
    Peter
    Austin, Texas
    2010 DCSB TRD OR
    Working towards an overland build
    well having had only 1 tacoma im hardly an expert, but other than that bit of frame rust it looks pretty clean.
    is it still on the original clutch??
  8. Jul 20, 2017 at 9:13 AM
    medic2230
    Murph
    Bama! Roll Tide
    That does look pretty clean for a northern truck.
    scottalot and musher like this.
  9. Jul 20, 2017 at 9:15 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Welcome! Its definitely more fun with a standard if you like rowing the stick! My 6 speed has been great so far!
    My advice to you if youre looking for a double cab 6spd is to be patient and shop around. This configuration is very hard to find, but its the best imo! I searched for about 8months before finding my 2013 dcsb 6spd one owner with 24k miles on it. Good luck!:thumbsup:
  10. Jul 20, 2017 at 9:23 AM
    J Fitz
    J Fitz [OP] Member
    Jim
    Looking to buy
    The dealer has no idea about the truck so I am not sure on the clutch. It felt solid when I drove it, put it through the gears to 75-80, lugged it in 4-5 on the on ramps to see how the clutch was, did not see any slip on the tac. The truck was originally in Northern Virginia and then in North Carolina for the last 5-6 years. 07s ok years? Is the frame a real concern here as well? I am finding a slew for 14-17K right now locally, 2007-2011s.
  11. Jul 20, 2017 at 9:26 AM
    BassAckwards
    I would create an acct on Toyota Owners.com (link below). If you login, and add the vin number on there, you can look at the service history at Toyota Dealerships for that truck and see if the clutch was replaced at a dealer. Could have still been done at an independent shop, but this might give you a better idea as to the Toyota service history.
    https://ssl.toyota.com/owners/login?successPage=
    scottalot and 81shark like this.
  12. Jul 20, 2017 at 9:32 AM
    J Fitz
    J Fitz [OP] Member
    Jim
    Looking to buy
    Thanks - Will do. Have to run to a meeting but will check in. Anything scare folks on the year / miles ?
  13. Jul 20, 2017 at 9:33 AM
    medic2230
    Murph
    Bama! Roll Tide
    How much do you drive?
  14. Jul 20, 2017 at 9:35 AM
    BassAckwards
    I wouldn't worry about the miles if it's been regularly cared for and maintained. We have an 07 fj in the family with the 6 speed and 1gr-fe and it has 250k miles. Still running strong! Long story short, these trucks will run forever if the previous owner/you took/take care of them
  15. Jul 20, 2017 at 9:39 AM
    J Fitz
    J Fitz [OP] Member
    Jim
    Looking to buy
    Yes, clutch done in 2011:
    1/26/11
    Dealer
    Lustine Toyota
    65,856
    Repair Order Number: 0020151
    INSTALLED FLYWHEEL., REPLACED CLUTCH THROW OUT BEARING.
    From the new site - thanks. No other records after it was sold and moved to NC.
    scottalot and BassAckwards like this.
  16. Jul 20, 2017 at 9:39 AM
    J Fitz
    J Fitz [OP] Member
    Jim
    Looking to buy
    I will run about 20-25K/year
  17. Jul 21, 2017 at 10:03 AM
    J Fitz
    J Fitz [OP] Member
    Jim
    Looking to buy
    Anyone concerned on that level of rust? I am not seeing much around here in terms of cost and manuals are pretty scarce. I figure I can wire brush the frame, clean it with acetone and hit it with crown.
  18. Jul 21, 2017 at 10:23 AM
    81shark
    81shark Well-Known Member
    from what i can see it looks pretty clean. i would recommend getting under the truck and checking the frame rail by the cats. That's a very popular place for rust holes that lead to frame replacement. the frame test is to whack it with a hammer... if you get a hole, run.
  19. Jul 21, 2017 at 10:28 AM
    jarebear74
    jarebear74 Bar down or it doesn’t count
    Colorado Springs, CO
    2010 OR DCSB
    Welcome to TW!
  20. Jul 21, 2017 at 10:38 AM
    J Fitz
    J Fitz [OP] Member
    Jim
    Looking to buy
    Thanks, it looks like the recall for the frames has passed anyhow. I might drive over and take it for another ride so I can tap around on it.
