New Method 701 street legal "beadlocks"
Discussion in 'Wheels & Tires' started by bajakerry, May 31, 2018.
  1. Jul 13, 2021 at 1:36 PM
    #581
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    From Method Part number LK-W56015SEB ET. These will be used with Kasnerd's now mine 701's. Do to Tacoma's short studs and the 701's thickness these lug nuts extend into the hole opening beyond the taper to engage more threads. They may also be available from Gorilla as well. The image/picture on Methods site is not of the ET version.
    kasnerd likes this.
  2. Jul 23, 2021 at 12:00 PM
    #582
    Holloman
    Holloman Well-Known Member
    chris
    nor cal Cloverdale
    2016 dcsbTRD OR
    Things and stuff
    Has anybody run low pressure (5-8 psi)with these wheels yet?
  3. Jul 23, 2021 at 12:02 PM
    #583
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    We sell and install a lot of the beadgrip methods. I thought it was kind of gimmicky at first, but I've actually had a lot of trouble unseating the bead on these using my tire machine, so they definitely hold a lot better than a standard bead.
  4. Jul 23, 2021 at 1:15 PM
    #584
    01 dhrracer
    Still Shopping
    Holloman[QUOTED] and OmahTako like this.
  5. Oct 6, 2021 at 6:55 PM
    #585
    89hatcher
    89hatcher Well-Known Member
    anyone mount some 35 on 16x8 yet? wondering if it rubs the UCA.
  6. Nov 1, 2021 at 8:33 PM
    #586
    JBDLB
    JBDLB Well-Known Member
    I'm looking at getting these in bronze. I am looking at the 16's with -12 offset. Is this the correct size to get if I want to run 33's with no spacers?
  7. Nov 2, 2021 at 12:14 AM
    #587
    89hatcher
    I don't think they make a 16 with -12 offset. I think its 16x8 0offset
  8. Nov 2, 2021 at 7:24 AM
    #588
    JBDLB
    Sorry. Is a 17 in a -12. Either way. Wondering what the best option is for me to not have to run spacers
  9. Nov 2, 2021 at 9:34 AM
    #589
    01 dhrracer
    Still Shopping
    I run 701's 17x8.5 0 offset/4.75" back spacing. With BFG KO2's 285/75/17 with JD Fabrication upper arms and spindles are reinforced I have about a 1/2" clearance between tire and arm with tire straight. I suppose I should check at full lock but I bet it will be ok.
  10. Nov 2, 2021 at 11:57 AM
    #590
    JBDLB
    So far I am stock. Jut throwing on rims and bigger tires, trim where need too then will lift.
    Is this size the preferred size?
  11. Nov 2, 2021 at 12:09 PM
    #591
    Corn_Taco
    Corn_Taco Member
    2020 Tacoma TRD Off Road
    No one HAS to run spacers. How wide are you wanting to be?
    For reference, the Tacoma TRD Pro wheels are 7” wide with +13mm offset. Moving to an 8” wide wheel with 0mm offset will push the outside of the wheel out .99”. So, you’ll already be sitting about an inch wider on each side compared to the TRD Pro. Inner clearance is the same.
    Compared to the TRD OR wheels which are 7.5” wide with +25mm offset the same 8” 0mm Method setup would poke an additional 1.21” with inner clearance being a bit better (.72” more).
    13mm is .512” so just add that to the exterior numbers above if you need to know how a -13mm offset on an 8” wide wheel would poke.
    Google “wheel offset calculator” if you desire more specs. All you need to input is wheel width and offset to get what you’re looking for.
    Also, FWIW I am running the 16x8” 0mm Method 701s with a “33 inch” (285/75r16) tire with lift and UCAs and I still need a cab mount chop. Not horribly, but it needs done.
    You’re going to have a bad time if you mount 33s on the factory suspension. If you wheel even the slightest I’d suggest dropping to the 265/75r16 or 265/70r17 else be prepared to take it easy until you can drop the time/money on a lift, UCAs, and CMC.
    JBDLB[QUOTED] likes this.
  12. Nov 2, 2021 at 12:36 PM
    #592
    01 dhrracer
    Still Shopping
    I have also had the JD Fab lower control arm mounts. This allows the lower control arm to be moved forward and the upper moves the upper ball joint (actually a uniball) back only .250". They do also offer upper arms with a set back of .750" if not doing the lower control arm mounts. Depending on how much you lift (recommend max of 2" with the shock) I would stick with a 285/75/16 or a 285/70/17 max unless you are willing to do a lot of work at the rear of the wheel well or move the lower forward. It is a lengthy read if you read it all but you will learn a lot from this post.
    Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
  13. Nov 2, 2021 at 1:19 PM
    #593
    JBDLB
    OK,
    I'm super green to aftermarket rims and tires. I have a 2002 chevrolet tracker with 31's on stock rims and needed 1.25" spacers to clear.
    For my tacoma I am not looking for major poke. I just want to be able to functionally run 285/75r16/285/60/17 without spacers (i hear spacers are not a great idea).
    So you are suggesting that the 8 inch wide 0 offset will be fine for my TRD OR?
    The lift is on order, so I'll take it easy until it gets here.
  14. Nov 2, 2021 at 1:30 PM
    #594
    Corn_Taco
    Corn_Taco Member
    You'll be fine with either of those Methods. The issue is with the larger tires.
    If lift is on the way then yeah, you probably don't need to mess with the smaller "32 inch" tires like 265/75r16 or 265/70r17.
    With a lift, regardless of your choice of 0mm or -13mm offset I'm saying you will likely run into clearance issues around the cab mount when running "33 inch" tires. There may be a combo of some parts where you clear just fine, but I can't say for certain what that combo is.
    I can say that I ran the 16x8" 0mm offset Methods with 32s on factory suspension for a year and even getting flexy in Colorado there was zero rub. With the 285/75r16 BFG KO2s on the same wheels I had to trim a little plastic behind the front wheels and I'm still in need of a CMC as there is some minor rubbing when turning with articulation. Again, I'm running roughly 2.5"ish of lift on the OME BP51s and HD Dakars as well as Camburg ball joint UCAs.
    Spacers MAY help this, but I'm not interested in that route. Even so, you'd be approaching wide body widths if you're adding spacers on top of a -13mm 8" or 8.5" wheel. I'd say do it right and just get the CMC as needed. They're not too pricey. Usually $200-300 at a local shop.
    A buddy of mine ran 33s on the factory TRD Pro wheels (7" +13mm offset) and he claimed to have no issues at all with rubbing FWIW.
    My advice: buy the tires and wheels you want with the offset you want knowing that you may need to trim a little and/or get a CMC. Avoid the spacers.
    terminus and JBDLB[QUOTED] like this.
  15. Nov 7, 2021 at 3:19 AM
    #595
    Montana_Actual
    Montana_Actual ;)
    Anyone running 285 Toyo Open Country AT3's on these rims?
  16. Nov 22, 2021 at 11:48 PM
    #596
    VersaTrax
    VersaTrax Well-Known Member Vendor
    Nicholas
    2019 Toyota Tacoma
    Where’s the best price for these nowadays? I see a couple years ago they were below $200, now $300+.
  17. Nov 23, 2021 at 8:04 AM
    #597
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    We may be a bit bias @chasenicholas93 but we say, Discount Tire :cool:
    In all seriousness, we do have a low price promise for all the wheels we offer and right now through December 6th 2021 retail pricing on all Method wheels have been reduced by 15%.
    w.adventures likes this.
  18. Nov 23, 2021 at 9:20 AM
    #598
    VersaTrax
    Nicholas
    2019 Toyota Tacoma
    Id be wanting 5x method 704s 16x8/ 6x5.5 (Titanium)
    also wanting 5x Toyo ATIII 265/75/R16
    im I’m the military as well so I’m assuming it will be 25%?
  19. Nov 23, 2021 at 9:32 AM
    #599
    VersaTrax
    Nicholas
    2019 Toyota Tacoma
    The link you provided to eBay has prices of the method rims at $309 each.
  20. Dec 8, 2021 at 10:36 PM
    #600
    v8rboi
    v8rboi Well-Known Member
    Raymond
    Southern California
    2019 Tacoma TRD Sport 4x4
    How’s the mpg average for y’all running on 265/75/16?
