New Method 701 street legal "beadlocks"
Discussion in 'Wheels & Tires' started by bajakerry, May 31, 2018.
  1. Apr 7, 2022 at 7:24 AM
    #621
    Nevin
    Nevin Well-Known Member
    Washington
    03 Tacoma 3.4 SR5 2022 TRD ORP 4Runner.
    OME 881 springs with 3/8 spacer. SCS SR8 16x8 Gunmetal 285/75/16 Yokohama G003 Nitros all 4 corners. Dakar rear leafs. Deckplate mod. Marlin Crawler 1200lb clutch. Redline hood struts. ECGS clam shell bearing. Philips LED headlights. Front Runner bed bars. Katskinz leather interior.
    They do make chrome valve stem covers and caps. Not sure why you'd use those on black wheels tho.
  2. Apr 22, 2022 at 6:58 AM
    #622
    jcmotr
    jcmotr Well-Known Member
    285/75 KO2s on 16x8
    Discount Tire and w.adventures like this.
  3. May 19, 2022 at 2:15 PM
    #623
    MonsterGuy
    MonsterGuy Well-Known Member
    Hill Country, Texas
    2009 DCLB TRD Sport 4x4
    265/70/R17 Toyo AT3 on 17x8.5
    gil_S and w.adventures like this.
  4. May 20, 2022 at 5:14 AM
    #624
    T.Barn
    T.Barn Well-Known Member
    Todd
    Hampton Roads, Virginia
    2010 AC 4x4 6MT
    Still loving these and still proving themselves off road.
    w.adventures likes this.
  5. May 20, 2022 at 9:35 AM
    #625
    ejewels
    ejewels Well-Known Member
    CT
    2018 MGM TRD OR 4x4 DCSB
    6112/5160/Dakars/Pro Tacoma Wheels
    why does one tire look way bigger than the other if they are essentially the same size tire? Did you mistype? One looks like a 33", the other a 31-32.
  6. Jun 21, 2022 at 10:08 PM
    #626
    Octane209
    Octane209 Active Member
    Octavio
    2020 White Toyota Tacoma TRD Off Road
    Are those 0 offset?
    jcmotr[QUOTED] likes this.
  7. Jun 22, 2022 at 6:42 AM
    #627
    jcmotr
    Yes, that’s correct
  8. Jun 24, 2022 at 9:48 PM
    #628
    Octane209
    Octavio
    What's your off set and back space on your wheels?
  9. Nov 29, 2022 at 1:58 PM
    #629
    runandgun18
    runandgun18 Well-Known Member
    Nate
    Arizona
    20 MGM SR 4X4
    Finally got a full set of five 701's. They look amazing! Nice to have the bead grip as I air down a lot.
  10. Nov 30, 2022 at 10:39 AM
    #630
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Looks good. How much lift, any rubbing/trimming, and any noticeable power loss? 4.5/ 0 offset correct?
  11. Nov 30, 2022 at 10:47 AM
    #631
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    What's the lowest psi some of you have ran with these?
  12. Nov 30, 2022 at 10:49 AM
    #632
    runandgun18
    Nate
    Arizona
    20 MGM SR 4X4
    No lift yet (6112/5160/Icon AAL, set for 2/1.5" of lift and Dirt King UCA's on the way), the skinny 33's were breeze to fit without lift. Correct, 16x8 0/4.5.
  13. Nov 30, 2022 at 10:50 AM
    #633
    runandgun18
    Nate
    Arizona
    20 MGM SR 4X4
    I saw a dude running 5 psi trying to debead the tires and wasn't able to.
    TXpro4X4[QUOTED] likes this.
  14. Nov 30, 2022 at 10:51 AM
    #634
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    :popcorn:
    Interesting
  15. Nov 30, 2022 at 10:56 AM
    #635
    OffroadToy
    Yeah... I've been looking at getting Toyo mt and these wheels in 16" for my 2nd gen with a 2" lift. Have read best to stay with the stock wheels (plus 30 offset) for no rub/trim but good to know the Methods will work... thanks for sharing.
  16. Nov 30, 2022 at 11:01 AM
    #636
    runandgun18
    Nate
    Arizona
    20 MGM SR 4X4
    With factory wheels I rubbed on the UCA's with 255 85 16, went to -10 offset and rubbed front/rear of wheel well but with a little trimming and heat gun work rub was gone. 0 offset is best
    OffroadToy[QUOTED] likes this.
  17. Nov 30, 2022 at 11:02 AM
    #637
    runandgun18
    Nate
    Arizona
    20 MGM SR 4X4
    I had Level 8 MK6 -10 offset before the Methods
  18. Nov 30, 2022 at 11:16 AM
    #638
    OffroadToy
    So with the 33' tires are you guys regearing? I know the 2nd and 3rd gens have different stock gears... thinking my 2007 with 3.73 will probably upgrade to 4.56.
  19. Nov 30, 2022 at 11:20 AM
    #639
    runandgun18
    Nate
    Arizona
    20 MGM SR 4X4
    I plan on going 5.29, I have full steel armor and next set of tires will be 34's
  20. Dec 1, 2022 at 8:47 AM
    #640
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    gilligoon likes this.
