New Mexico Flea Market Thread
Discussion in 'South West' started by NewMexiTaco, Nov 7, 2011.
  1. Apr 12, 2021 at 7:38 AM
    #1681
    deekyn
    deekyn Well-Known Member
    Dustin
    Yellowstone
    2015 Black Tacoma TRD Off Road
    These got sold already. I love the rear relocate kit so far. Look forward to seeing you out there.
    fr0stbytten[QUOTED] likes this.
  2. Apr 15, 2021 at 6:29 PM
    #1682
    STravis
    STravis Well-Known Member
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    I'll also be building a 2.5 gen tacoma front bumper and a fifth gen 4runner bumper these next couple weeks if anybody is interested.
  3. May 1, 2021 at 6:11 PM
    #1683
    fkLymphoma
    fkLymphoma Well-Known Member
    Seth
    2020 Cement Tacoma OffRoad
    Anyone interested in my predator tube steps? I’d like to get some sliders, haven’t taken The steps off. Truck only has 3K miles on it
    Chris256 likes this.
  4. May 5, 2021 at 10:15 AM
    #1684
    pigger
    pigger Well-Known Member
    Greg
    Rio Rathole
    04 tacoma 4x4 reg cab
    Detroit True-Track rear limited slip, steering rack bushings, shell, SAF decals, Wheelers 5-leaf & Bilstein 5100's, some nice LED lights from Chris, big-ass bumpers, older-than-dirt owner
    Did you ever find any? I just put 2019 Taco wheels on my truck, and will need spacers for the front, at least; rubbing at full lock due to the difference in offset.
  5. May 5, 2021 at 10:44 AM
    #1685
    montijo505
    montijo505 Moon soon?
    Rio Rancho, New Mexico
    08 4Runner SR5/ AKA The Great White Pig
    Rubbing where?
  6. May 5, 2021 at 12:38 PM
    #1686
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    Uca probly
  7. May 8, 2021 at 6:44 PM
    #1687
    pigger
    Greg
    Rio Rathole
    Clears the uca, rubs at full lock against the inner fender/liner, although I haven't found exactly where yet. Tires are 265/75-16 on 2019 TRD wheels, the offset is different enough to rub.
  8. May 8, 2021 at 7:09 PM
    #1688
    montijo505
    You’ll rub more with spacers. Just try getting an alignment and get as much caster as you can and trim/mold plastic accordingly.
  9. May 8, 2021 at 7:13 PM
    #1689
    pigger
    Greg
    Rio Rathole
    Why would it rub more with spacers? I'm talking about putting the track dimension back towards stock; the 2019 wheels are offset considerably more inward than 2004 Taco wheels. Honest question, though, I'm interested in your input.
    Edit: the truck is aligned properly, I keep it that way.
  10. May 8, 2021 at 7:33 PM
    #1690
    pigger
    Greg
    Rio Rathole
    From what I can find online, the offset difference between these wheels and my 2004 wheels is around an inch or so.
  11. May 8, 2021 at 8:37 PM
    #1691
    montijo505
    What are the offsets of each wheel? The spacers will make your turning radius even wider, if you’re rubbing the plastic now you’ll likely rub the body mount with the spacers. But if you think it’ll fix your problem give them a whirl. Easy enough to sell if you don’t need them!
  12. May 8, 2021 at 9:02 PM
    #1692
    pigger
    Greg
    Rio Rathole
    These particular 2019 wheels have a +25mm offset; the 2004 wheels I've been using have a -20mm offset. The 2019 wheels narrowed the truck's track visibly.
  13. May 8, 2021 at 9:24 PM
    #1693
    montijo505
    Are the tires bigger though? Or same size?
  14. May 9, 2021 at 1:41 PM
    #1694
    pigger
    Greg
    Rio Rathole
    The truck came new with 265/70-16 tires. I have used that size, and also 265/75-16 and 235/85-16 tires. The tires on the truck right now are 265/75-16. This size does not rub at all with 2004 Tacoma wheels, which are offset almost an inch more to the outside than the wheels I am using now; this is what is causing the rubbing. Not sure how to make that more clear.
  15. May 31, 2021 at 7:24 AM
    #1695
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
  16. May 31, 2021 at 7:25 AM
    #1696
    boostedka
    James
    NM
    Did you end up getting your wheels figured out, Greg? What you're describing totally makes sense. Those 3rd gen TRD OR wheels are definitely more sunken in due to the more positive offset. A 1-1.25" spacer would set you up perfectly.
  17. May 31, 2021 at 7:33 AM
    #1697
    montijo505
    boostedka[QUOTED] likes this.
  18. May 31, 2021 at 8:23 AM
    #1698
    pigger
    Greg
    Rio Rathole
    Yup!
    I just got back from a 4500-mile trip through the Midwest to visit family and friends; now that I'm back the spacers are on the to-do list. The SpiderTrax brand seems to have good reviews here and elsewhere, so I will go that way. I like the look of the wheels; the spacers will correct the offset issue.
    The tires are working very well for me; thanks very much for selling them to me. They are the correct load range for my truck, with the correct amount of sidewall stiffness, so the contact patch stays firm at all times, no bouncing around on small surface imperfections. I'm very pleased with them. :turtleride:
  19. May 31, 2021 at 11:23 AM
    #1699
    dlopan
    dlopan Well-Known Member
    Dave
    Albuquerque, NM
    2015 Pyrite Mica 4wd DCSB TRDSport
    Camper shell, CB radio. R-pod 179
    One minor problem. THe steering wheel is on the wrong side.
    montijo505[QUOTED] likes this.
  20. May 31, 2021 at 12:34 PM
    #1700
    Chris256
    Chris256 Member
    Christopher
    Albuquerque, NM
    2017 Toyota Tacoma TRD OffRoad
    did you sell yet?
