New Mexico Owners BS Thread
Discussion in 'South West' started by twistax, Apr 3, 2009.
  1. Aug 2, 2013 at 5:35 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    So my locker won't disengage, and I can't get the motor off of the axle...
  2. Aug 2, 2013 at 5:48 PM
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    I enjoyed what we did. We went to left before we went back and went right to the national forest. But saw some nice views. Would like to get to the top soon.
  3. Aug 2, 2013 at 5:52 PM
    Alexb03
    Alexb03 Well-Known Member
    Alex
    New Mexico
    06 Tacoma Double cab
    3" lift, 285/75/16, navigation,
    Let me know if you want some company, i would be down to go with you...
  4. Aug 2, 2013 at 6:20 PM
    tacodane
    Dane
    Sure thing. Will let you know
  5. Aug 2, 2013 at 6:24 PM
    Slodgetto
    Slodgetto Über Posre
    Silas
    Welcome! I payed a bit over $500 to have the dealership replace my driverside door latch. :(
    Try the junkyards though.... u-pull and pay has a few tacomas on the lot right now..
    ruh roh. should be 3 bolts and a sharp flathead or something to pry it off... be careful not to ding up the mating surface, but that seal has to be broken to get the motor off. it'll probably under a bit of pressure since it's stuck on, so jack up at least one of the rear tires to relieve that tension, and try a bit more elbow grease. :D Once the bolts are off, (unless it's fubar'd) it's only the seal that holds it on.
    Nice, man! That 350 counts for something, but I thought expo rigs are supposed to be reliable????? ;) I didn't think "heep" and "expedition" could be used in the same sentence. :D
  6. Aug 2, 2013 at 6:38 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    Have you tried rocking the wheels back and forth?
  7. Aug 2, 2013 at 6:42 PM
    tomtom
    The Desert SW
    2012 FJ
    Dunno about the 350 but the 4.0 was an awesome engine. Everything else, meh...
    I owned one for 6 years. Everything broke on it except for that tank of a 4.0. Nice thing is parts are easy to get. ;)
  8. Aug 2, 2013 at 6:53 PM
    PcBuilder14
    Brent
    Nor Cal
    Yeah. I removed the all of the bolts, took off the shield, and unplugged all of the wiring. It just wouldn't budge. I thought I was about to break my flat head in half. I sprayed it with pb blaster, so we'll see if that helps. I'll try jacking up the tire as well.
    No, I figured Turning for a good 5 minutes on pavement would be good enough. Haha
  9. Aug 2, 2013 at 6:56 PM
    Alexb03
    Alex
    New Mexico
    I've always had great luck with 350! There's nothing to them and make nice power! Ya I never thought I would own a jeep but got a good deal so I thought I would try one!
  10. Aug 2, 2013 at 7:09 PM
    PcBuilder14
    Brent
    Nor Cal
    Lifted on tire in the air and tried moving it but it's locked together tight
  11. Aug 2, 2013 at 7:10 PM
    99yodataco
    99yodataco Little Taco that could
    Chad
    New Mexico, it's just a little bit fresher.
    MGM 21 TRD OR 6sp MT
    Soon...
    Nice jeep Alex, I still need to drop in my 350 into my jeep wrangler. But before I do I need some better axles than the D30/35 that came with it. Plus it's gonna be the wife's toy :D
  12. Aug 2, 2013 at 7:12 PM
    tomtom
    The Desert SW
    2012 FJ
    As shit breaks, upgrade it. If you want ideas, let me know. I found pretty much every weak point in mine. :D
    One of the big ones is the NP241 could use the slip yoke eliminator. It helps with driveline angles and if you have to drop the drive shaft to get off the trail, you won't have to worry about ATF spewing everywhere.
    If it has the Chrysler 8.25, the rubber fill plug is the breather (if I remember right). Not too big of a deal here in NM but many guys welded a tapped washer over the fill hole to put in a metal fill plug and then ran a separate breather.
    The Chevy 350, I got no experience with. Probably has a bunch of different peripherals as well (alternator, water pump, power steering pump, A/C, etc.) Although, I seem to remember the 4.0 used a lot of the Chevy ones.
    Keep an eye on the front roof pillars. They crack right below the roof line since the unibody construction has to flex somewhere.
    And a gas tank skid does wonders.
    Otherwise, fun vehicles. Especially with some aftermarket control arms.
  13. Aug 2, 2013 at 7:13 PM
    tomtom
    The Desert SW
    2012 FJ
    The rocking back and forth needs to be done with both tires off the ground. Takes the tension off the locking mechanism.
    Let me do some reading in the FSM.
  14. Aug 2, 2013 at 7:18 PM
    PcBuilder14
    Brent
    Nor Cal
    Did that too, they were both just going back and forth.
  15. Aug 2, 2013 at 7:35 PM
    tomtom
    The Desert SW
    2012 FJ
    According to the FSM (pg. SA-2) troubleshooting says that if it won't unlock it is the:
    Speed sensor
    Diff. Lock ECU
    or
    Wiring or ground is faulty.
    When you hit the button, can you hear the motor do something?
    And, yeah, what Silas said. According to the FSM, step 7 on page SA-180, undo the bolts and remove. Helpful, huh? :rolleyes: :)
  16. Aug 2, 2013 at 7:52 PM
    tomtom
    The Desert SW
    2012 FJ
    Have you tried using a buddy and rotating the wheels in opposite direction?
  17. Aug 2, 2013 at 8:00 PM
    PcBuilder14
    Brent
    Nor Cal
    The motor doesn't even make a noise anymore, but the diff lock light does stay on along with the abs light. I undid the grey wire mod to see if that would fix anything, but nope.
    Did t try that, but I did yank it back and forth haha
  18. Aug 2, 2013 at 8:48 PM
    tomtom
    The Desert SW
    2012 FJ
    Hey Silas, a conversation today at work has me considering 315s. :D
  19. Aug 2, 2013 at 11:32 PM
    SGT Taco
    SGT Taco It all fun and games till its not.
    Scott
    Spring Hill TN.
    R.I.P. 2007 TRD, Land Rover Disco II, F250.
    Wife rolled it 3x mod...
    Hey pc... With that locker motor, there should only be two wires going into it. Just put voltage and ground directly to the leads (the ones going to the locker, not the vehical side) and listen to see if the solenoid is faulty or not. If you don't hear anything, reverse the wires and try again. If you still don't hear anything it's the solenoid... If it unlocks the diff, then it's an electrical issue...
    Or I guess you could just use a multimeter at the harness to see if it's applying voltage like it should. Also check your IGN 1 fuse...
  20. Aug 2, 2013 at 11:37 PM
    SGT Taco
    Scott
    Spring Hill TN.
    If you have any question at all just ask and I should be able to walk you threw it. I'll pm you my number...
