New Mexico Owners BS Thread
Discussion in 'South West' started by twistax, Apr 3, 2009.
  1. Aug 2, 2013 at 11:37 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Thanks! I'm going to Carlsbad Caverns tomorrow, but Sunday I plan on working on it all day until I get it figured out. I'll use all of those methods.
  2. Aug 3, 2013 at 12:03 AM
    Slodgetto
    Slodgetto Über Posre
    Silas
    Dang, I wish I knew wire stuff like Scott. I was going to suggest a hammer. :eek: lol :D but seriously, if the electrical stuff doesn't work, i'd try tapping the motor body with a hammer to break the seal... :notsure:
  3. Aug 3, 2013 at 12:12 AM
    PcBuilder14
    Brent
    Nor Cal
    The very first thing I tried while out on the trail was tap it with a crescent wrench haha
    I think the pb blaster should help. Otherwise I'll just yank on it and try to slowly wiggle it off I guess. Scared to hit it much since it's aluminum.
  4. Aug 3, 2013 at 12:15 AM
    Slodgetto
    Silas
    Hopefully. Yeah, don't want to crack it. Maybe try a heavy rubber mallet if you have one?
  5. Aug 3, 2013 at 12:18 AM
    PcBuilder14
    Brent
    Nor Cal
    May have to go buy one... haha
  6. Aug 3, 2013 at 12:31 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    well i read your locker issue. and it looks like those guys covered it pretty dam well! Maybe you bent something in there man. What were you doing before this all happened? Even if the motor isnt moving I can't believe you wouldn't be able to just slide it out with both tires off the ground freeing up that tension. I agree though that step one should be figuring if you can get that locker motor to make any noise and try to unlock.
  7. Aug 3, 2013 at 12:35 AM
    PcBuilder14
    Brent
    Nor Cal
    Drove down a trail and did some minor rock crawling for about an hour. as I was leaving I went to disengage and it wouldn't. Didn't put much stress on the locker that it shouldn't be able to handle.
    If the actuator is frozen into engage, it won't allow the locker to un-lock. So I'm hoping for no bent parts haha
    I'm going to test the wiring first, then if that's not the problem I'm going to remove the actuator from the axle and see if it can move by itself while not being attached. If I can manually disengage the locker and the actuator doesn't move while being free from any tension, then I just need to re-build the motor.
  8. Aug 3, 2013 at 1:10 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I thought the problem was you couldn't free the actuator?
    or are you just going to pull the third and then try to free the actuator?
  9. Aug 3, 2013 at 1:18 AM
    PcBuilder14
    Brent
    Nor Cal
    I haven't even been able to remove the motor housing yet. Once I remove that I am going to manually disengage the locker as long as nothing is bent/broken inside.
    After that I am going to test the motor to make sure it actually turns. If not I am going to tear it apart and rebuild it.
  10. Aug 3, 2013 at 6:49 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Open diffs FTW!!
    Just trying to make myself feel better about my lack of lockage :anonymous:
    On another note, check out the new commuter Greg :cool: It's no Ducati but it'll do.
  11. Aug 3, 2013 at 7:30 AM
    pigger
    pigger Well-Known Member
    Greg
    Rio Rathole
    04 tacoma 4x4 reg cab
    Detroit True-Track rear limited slip, steering rack bushings, shell, SAF decals, Wheelers 5-leaf & Bilstein 5100's, some nice LED lights from Chris, big-ass bumpers, older-than-dirt owner
    OOooh, that looks very nice, Steve! :cool:
    What is it?
  12. Aug 3, 2013 at 8:54 AM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    It is a motorcycle, Greg. :p
    :D
  13. Aug 3, 2013 at 11:09 AM
    pigger
    Greg
    Rio Rathole
    Hmm.
    And here I was thinking it was the uterus of a dead gopher. :eek:
  14. Aug 3, 2013 at 11:36 AM
    Slodgetto
    Silas
    I was thinking the same thing. :rolleyes:
  15. Aug 3, 2013 at 1:20 PM
    KCDuran
    KCDuran Stormtrooper
    Kyle
    South Jersey
    5 Lug'n 4 banger
    Icon/TC Mid Travel Kit, Kenwood Deck, Helix Audio System, BHLM (With Tinted Reflectors), Tinted Taillights, Satoshi Grill (color matched to super white), Stormtrooper sticker, Air Force sticker HUA! Re colored gauges (White numbers and ODO with Blue Needles) Magnaflow Glasspack Muffler, Stainless steel exhaust tip, 8k HIDs, LED Satoshi, Eye Lids, ARB locker (4.10 Gears), 8k FOG HIDs, LED Head Lamp, Tonneau Cover
    :rofl:
    Cloudy did some more of his awesome
    Magic today... Bumper is coming along nicely! Pics to come later :cool:
  16. Aug 3, 2013 at 3:13 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Not a uterus, good guess though. It's an '07 Yamaha fz6. Pretty mich a de-tuned naked r6.
  17. Aug 3, 2013 at 4:46 PM
    Alexb03
    Alexb03 Well-Known Member
    Alex
    New Mexico
    06 Tacoma Double cab
    3" lift, 285/75/16, navigation,
    So I took the jeep out for a little ride today and met up with some nice buggies and toyotas on the Mesa. Watched a buggy go up the waterfall backwards then back down it backwards, then did it on the right side. He did it like nothing!
  18. Aug 4, 2013 at 11:56 AM
    Alexb03
    Alex
    New Mexico
  19. Aug 4, 2013 at 12:14 PM
    Slodgetto
    Silas
    :washing:
  20. Aug 4, 2013 at 12:14 PM
    tomtom
    The Desert SW
    2012 FJ
    I'm working on my monthly budget if that excites anyone.
