New Mexico Owners BS Thread
Discussion in 'South West' started by twistax, Apr 3, 2009.
  1. Sep 2, 2013 at 8:37 AM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    Do this but run a jumper from 7 to 8 and the red light should turn on.
    To test if the red light comes on at all, switch the W/B wire to #8 while leaving the others the same (Blue -> 2, Green -> 6, G/W -> 3) and see if both the fogs and the switch light come on when you throw the switch.
  2. Sep 2, 2013 at 9:04 AM
    tacodane
    tacodane The Slow But Getting Somewhere Build
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    I take a try at it. on the other hand my dash lights and ac control lights aren't working.lol be fore you any ask I have checked all fuses twice to make sure no fuses are blown.
  3. Sep 2, 2013 at 9:11 AM
    tacodane
    Dane
    when I switches the w/b wire to #8 the fog lights worked but no lights came on
  4. Sep 2, 2013 at 9:23 AM
    tomtom
    The Desert SW
    2012 FJ
    ok, something isn't right but at least the switch works for the fogs. Only other thing I can think of is switch #2 and #3 w/ W/B on #8 and see if the switch lights up and the fogs still work.
    Probably just need someone with more automotive electrical experience that can get their hands directly on it.
  5. Sep 2, 2013 at 9:33 AM
    tacodane
    Dane
    nope didn't work. blew my last fuse some im done trying for now. now have to figure out why my dash lights and ac control lights wont come on now. any idea what could be the issue.
    I don't want to take it to Toyota and have to deal with them saying me messing with the wires for the fog light caused it not to work and voiding my warranty. but I will see what bs they come up with.
  6. Sep 2, 2013 at 9:41 AM
    tomtom
    The Desert SW
    2012 FJ
    Did you check both the fuse box in the engine bay as well as the fuse panel in the cab?
  7. Sep 2, 2013 at 9:46 AM
    tacodane
    Dane
    I sure did twice. don't get it
  8. Sep 2, 2013 at 10:29 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Over 60gb of video and 400 pictures to go through...
  9. Sep 2, 2013 at 10:37 AM
    SGT Taco
    SGT Taco It all fun and games till its not.
    Scott
    Spring Hill TN.
    R.I.P. 2007 TRD, Land Rover Disco II, F250.
    Wife rolled it 3x mod...
    Check your dimmer... Make sure you did not rotate it down while working on it all.
  10. Sep 2, 2013 at 10:40 AM
    tacodane
    Dane
    checked that as well nothing
    just drove the truck around and did a walk around on all the lights everything is working fine but the gauge lights and ac control lights
  11. Sep 2, 2013 at 11:34 AM
    tomtom
    The Desert SW
    2012 FJ
    You check the fuses with an ohmeter, not just visually?
  12. Sep 2, 2013 at 11:52 AM
    tacodane
    Dane
    could a volt meter work? I don't have a ohmeter
  13. Sep 2, 2013 at 12:50 PM
    tomtom
    The Desert SW
    2012 FJ
    You can put 12V on one side of the fuse and see if you have it on the other.
    Might want to check the panel and the box to see if you can test the fuse in place this way.
    Otherwise, if you have to pull the fuse to check it, be careful not to ground out the negative side of the fuse. You'll pop it in the process.
  14. Sep 2, 2013 at 1:04 PM
    tacodane
    Dane
    so I checked to see if the fuse is getting power and it is
    And spoke to OTRATTW about the switch. he tried to help me out the best he could on the phone but hes not giving up. going to figure it out while I try to see what people did when they changed out there oem switches
  15. Sep 2, 2013 at 1:19 PM
    tomtom
    The Desert SW
    2012 FJ
    If the dashlights are on a relay, might want to check it. No idea if a relay for dashlights even makes sense but would be something to check.
    Yeah, if you find out for sure what the colour codes are, should be able to wire it up easy-peasey.
  16. Sep 2, 2013 at 1:23 PM
    tacodane
    Dane
    ya we found a diagram for the stock oem fog switches but they didn't make sense to have a ground wire to connect a circuit. but im going to have a friend look and then just take it to a dealer to have them tell me its my fault.lol
    [​IMG][​IMG]
  17. Sep 2, 2013 at 3:56 PM
    tomtom
    The Desert SW
    2012 FJ
    OK, my best guess (since the 2 pictures don't use the same terminology)
    Green -> 6
    G/W -> 7
    This should get the lower light turned on when the dashlights are on. And if it is in series with the dashlights, may get the dashlights functioning again.
    From there, the diagrams don't jive.
    Blue is hot so I'm not sure why it is listed as "Pin 85 Fog Relay" but given that it is hot, according to the switch diagram Blue -> 2
    That leaves B/W -> 3 then the fogs should work when the switch is in the "ON" position.
    Then 8 needs to be tied to ground to get the electrons flowing across the top bulb when the switch is in the "ON" position.
    But, again, the terminology in the two diagrams don't jive so I'm making a best guess.
  18. Sep 2, 2013 at 7:07 PM
    tacodane
    Dane
    ill give it a swirl when I get more fuses. ended up going thru about 10 with this switch.:D
  19. Sep 2, 2013 at 10:40 PM
    tomtom
    The Desert SW
    2012 FJ
    Speaking of dashlights, the left side of my instrument cluster is dimmer than the right. Just started today so I have to tear everything back apart. I'm hoping I accidently twisted the dimmer knob, otherwise have to find the faulty connection or bulb.
  20. Sep 3, 2013 at 7:10 AM
    KCDuran
    KCDuran Stormtrooper
    Kyle
    South Jersey
    5 Lug'n 4 banger
    Icon/TC Mid Travel Kit, Kenwood Deck, Helix Audio System, BHLM (With Tinted Reflectors), Tinted Taillights, Satoshi Grill (color matched to super white), Stormtrooper sticker, Air Force sticker HUA! Re colored gauges (White numbers and ODO with Blue Needles) Magnaflow Glasspack Muffler, Stainless steel exhaust tip, 8k HIDs, LED Satoshi, Eye Lids, ARB locker (4.10 Gears), 8k FOG HIDs, LED Head Lamp, Tonneau Cover
    if its a bulb you could just get some different colors to mix it up a bit! Change is the spice of life!
    :D
