New Mexico Owners BS Thread
Discussion in 'South West' started by twistax, Apr 3, 2009.
  1. Mar 4, 2010 at 11:07 PM
    #1081
    Taco505
    Taco505 Well-Known Member
    Alex
    New Mexico
    2011 4cyl 4x4 5 speed
    OME 884's/90021, MD Dakar/Nitrocharger.
    i think its an 8.4?? which it pretty right an 8 bit thats what i have been reading.
    but that is what im confused about because everything is about the 4x4 or the prerunners i just wana know what the 2wd has im sure its the same as the rest but it would make me feel better if i knew haha.
  2. Mar 4, 2010 at 11:20 PM
    #1082
    yotabeast505
    yotabeast505 The Beast
    David
    NE Hights ABQ NM
    THE BEAST
    here we go. Ford 9" rear after breaking 5 sets of gears in the stock yota 8.8, 5.13 gears with a detroit hard locker, 63" chevy leafs and custom hangers, sky's front spring hanger with sky's extream hysteer and PSC hydro assist ram and PSC pump. welded front spyders in the f-550 front dana 60 with warn hubs, pico brake lines and hoses, elecrtic fan, TRD supercharger with URD 2.1 Pully, URD Map-ECU2 and cage built by me. wide band a/f by inovations, lots and lots more...........
    yeah dud i dont know iv been searching th net for the last hour trying to fined out and nothing lol time to go to the dealer lol you can put a powertrax in it for about $300
  3. Mar 4, 2010 at 11:39 PM
    #1083
    Taco505
    Alex
    New Mexico
    ya i was lookin at those but i didnt know if they would fit? haha wtf i dont even know man maybe i should just do what greg said find a junked taco and take the rear end haha
    o and sorry for my last post i just read it, i didnt write very clearly haha
  4. Mar 4, 2010 at 11:43 PM
    #1084
    yotabeast505
    David
    NE Hights ABQ NM
    THE BEAST
    i found this funny people trying to use a-trac with the locker on. its pointles you have a higher probiblity to get stuck if the a-trac is trying to stop one wheel in the back from spinning if its sinking in the sand because it will slow down the wheel with traction if your going to sport a-trac turn the locker off it will work better trust me and if you going to run the locker on turn the a-trac off but you wont have the open diff in the front traction like you would with the a-trac....... just use a track unless crawloing then you can use both and the locker and it will help out the front for everything els dont use the locker in your new toy!!! burn out your rear breaks its commen sence!!!!
  5. Mar 5, 2010 at 12:21 AM
    #1085
    TacoTron
    TacoTron Tacotronn
    Anthony
    Denver, CO
    07 Toyota Tacoma
    seems like i missed out alot alex lol
  6. Mar 5, 2010 at 12:35 AM
    #1086
    yotabeast505
    David
    NE Hights ABQ NM
    THE BEAST
    yeah ask her and see im interested if this shit falls through again she dont know what she wants and i dont feel like sticken around
  7. Mar 5, 2010 at 1:06 AM
    #1087
    yotabeast505
    David
    NE Hights ABQ NM
    THE BEAST
  8. Mar 5, 2010 at 6:43 AM
    #1088
    blendedfamily
    blendedfamily Well-Known Member
    'Burque(sucks)
    ^^ phuckin cool!!
    So, painted my avid stuff -- it came out like sh!t. Paint chipped off from my finger. Sanded the hell out of the stuff, cleaned it with parts cleaner wiped it down... painted it with a few light coats over the course of about 2 hours. let it dry over night. The next day, I chipped the paint with my finger nails as I was taking the things down from the hangars.
    So--- guess who forgot to primer?
    AND... you guys post the bejesus out of this thread.
  9. Mar 5, 2010 at 7:10 AM
    #1089
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    Nice!
    It looks like it would work but since it's not selectable it's going to change your on road manners too. You may or may not care about that.
    The locker effectively disables the ATRAC. The brakes only grab a tire if it is spinning more than the tire on the opposite side. With the locker turned on, both left and right tires are spinning at the same speed whether they have traction or not. Because they are spinning at the same speed, the ATRAC never kicks in. I'm not burning out my brakes. Another misconception is that ATRAC cuts power. It does not. It just makes sure it goes to the tire with the most traction. VSC cuts power and that is a different system.
    Finished cutting last night for the sliders. I was able to tack them together too. They are 2"x2"x3/16" square tube on the inner legs and main beam. The outer legs and the secondary beam are 7 gauge 1.5"x1.5" square tube. I need to finish welding and get the mounting plates, end caps, and gussets on. I arguably over engineered them. Many sliders just have 3 legs going to the frame, I did 4. Many have 1.5" tube on the main legs and beam. I did thick walled 2". They should be as strong or stronger than any you can buy. I intentionally wanted them not to stick out too much to keep the lines of the truck. They should be fairly low profile.
    Here they are:
    What do you think?
  10. Mar 5, 2010 at 7:11 AM
    #1090
    Whitecloud
    Whitecloud Cloudy-fabricator of things
    Johnathan
    Albuquerque, New Mexico
    Superwhite 06 DCLB
    ICON Extended travel Coilovers, Custom leaf pack, custom sliders and F&R bumpers, 295 75 17 Toyo Open Country MT's, On-Board air with F+R connectors, On-Board water with quick disconnect shower.Trimmed fenders and body mount chop. LOTS of wiring, dual battery setup, Solar charging system, with some random lights spread around here and there.
    I haven't been around before the Puerco trip Anthony. The Puerco was my first run with you guys. I was in the white dc long bed with the stock streetish tires. that ended up helpig pull out Ester and Alex before you guys came back around. Got the flyers that Alex was passing out.
    Actually the wife got it on the truck when she was at the gym (thanks Alex)!! haha.
    But down for going again at any point. My schedule at work is going to change again in about 2 months. But if any of you guys out there want to go on a Wed or Thurs back to the Puerco.
    Just pm me if anyone wants to go on a wed or thurs.
  11. Mar 5, 2010 at 7:14 AM
    #1091
    Whitecloud
    Johnathan
    Superwhite 06 DCLB
    Sliders look sick!!!!!!!!:eek:
    U gonna do some up for me Greg????:confused:???? J/K
  12. Mar 5, 2010 at 7:35 AM
    #1092
    Taco505
    Alex
    New Mexico
    haha i will man ill figure that ish out today and well see what she says. so i found out that i do have an 8" :), but i think its a 30 slpine also does that sound right or m i just makin that ish up??
    and greg ya i know i dont like that it isnt and it seem like thats a litte much for me but thats all that i could find that would fit for sure haha. i just want to regear fror better performance since im pretty much a street truck. but also have a locker for moments like the puerco haha
  13. Mar 5, 2010 at 7:50 AM
    #1093
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    Is "Trucks Unique" still open in ABQ ?
  14. Mar 5, 2010 at 8:02 AM
    #1094
    FamouzStarz
    FamouzStarz The illest taco
    21 TRD PRO
    ICON Build and then some
    its still there!
    man you guys are right about reading a novel took me like 3 pages to catch up on the gossip, anyways i have 2 buyers lined up for my car so the lift looks like it might get ordered by tonight or tomorrow! :D
  15. Mar 5, 2010 at 10:24 AM
    #1095
    NewMexiTaco
    NewMexiTaco Abron Cabron
    Abraham
    Santa Fe, NM
    2007 4x4 DC LB TRD Sport
    Weathertech mats; Wet Okole seat covers; Kobalt Lowpro truck box,(sitting in the shed) Snugtop Hi-liner camper shell; AFE Pro Dry air filter, Tailgate Hoseclamp mod; 5100s all around, Light Racing UCAs, OME 885 coils, OME Dakar Leafs, CB Drop, Driveline spacer. Epoxy Satoshi; Redline Hood Struts. 4x Mil Spec. bed D rings; Brute Force Fab custom DCLB Hybrid Sliders, ARB w/ Warn M8000 wench, Diff Breather mod, Alpine Deck w/ ipod cable. Iphone ziptie to rearview mirror 4wd-cam mod!
    Got my Taxes back today!!! and got paid.... but I got mad Bills to pay before I even think about any fun shite.... Still its a good thing!:bananadance::bananadance:
  16. Mar 5, 2010 at 10:36 AM
    #1096
    Loudpedal
    Loudpedal Mind = Blown
    Blair
    Not really New, not really Mexico
    02 SR5-Hole 4x4
    Andres Devil Horns, Goodyear Duratracs, Accidental Tailgate Delete (x2), Billy 5100s, OME 881 coils, Wheeler's 5-leafs, BAMF Sliders with kickouts, Box Rocket Fab Bedrack.
    :taco: got mine back too!!!! Paying off the wife's bus! :woot: no more truck payments!!!!!!!11!11!1!1!11oneoneone
  17. Mar 5, 2010 at 10:59 AM
    #1097
    TacoTron
    TacoTron Tacotronn
    Anthony
    Denver, CO
    07 Toyota Tacoma
    Hell yeah good luck kevin hope u get it soon gonna be sick as hell
  18. Mar 5, 2010 at 11:00 AM
    #1098
    TacoTron
    TacoTron Tacotronn
    Anthony
    Denver, CO
    07 Toyota Tacoma
    Yeah I remember now my bad
  19. Mar 5, 2010 at 11:18 AM
    #1099
    yotabeast505
    David
    NE Hights ABQ NM
    THE BEAST
    the reason why i said that is because someone said they wish they could overide the locker turning off the a-trac...at under 3 miles an hr the rear locker and a-trac can me enabled. it kicks off after that to protect the breaks. it doesnt cut power but if you are going up a hill with the locker on and a-trac at under 3mph and it thinks one tire in the back is slipping it will apply breaks to one rear wheel slowing down the oposeing wheel witch could end up overall getting you stuck in the sand, mud, if i had the a-trac all i would use the locker for is rock crawling.
  20. Mar 5, 2010 at 11:19 AM
    #1100
    NewMexiTaco
    Abraham
    Santa Fe, NM
    Here they are:
    What do you think?[/quote]
    I like them! you learn well grasshoppa! soon you will be the master....
    and we will all be beggin you for sliders!
    So Those Look flippin strong! Sliders on 'roids! :D The welds look smooth and the corners look sweet rounded off, and they'll be capped right? so this is maybe a stupid question but are the weld on anchor points offset cause there is nowhere up front (or back?) to weld to ?
    Oh BTW, you inspired me to check at SFCC to see if theres any welding classes. they only have metal sculpture classes. lol.hood ornaments anyone?
