new michelins
Discussion in 'Wheels & Tires' started by millerm20, Oct 23, 2011.
  1. Oct 23, 2011 at 12:57 PM
    millerm20
    millerm20 [OP] Member
    mark miller
    charlotte NC
    08 sr5
    putting 4 new michelin ltx ms2 on my tacoma monday. hoping to get 60000 miles out of them
  2. Oct 23, 2011 at 1:08 PM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    Not sure exactly how many miles I have on mine, but it rides much better on the street, and after at least 10k there is no noticeable wear.
    2 thumbs up so far!
  3. Oct 24, 2011 at 5:13 PM
    maju
    maju Well-Known Member
    Davenport Fl
    2010 DC Silver TRD Sport 4x4
    Undercover tonneau, Scangauge II, Garmin GPS, Michelin LTX M/S2
    I have about 15K on mine just starting to see that the tires are being used. with this type of wear I am figuring about at least 60K form them
  4. Oct 25, 2011 at 4:08 PM
    millerm20
    mark miller
    charlotte NC
    08 sr5
    I will be putting them on thursday
  5. Oct 25, 2011 at 4:13 PM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    The Michelins are great on wear - you should easily get 60k, but they are known to dry-rot after a few years, so it depends on how much driving you do. If you can get the 60k in before they start to crack then no problem. If the truck only gets used occasionally and the tires reach five years or so they will have to be replaced before you can reach the 60k :(.
    They are good tires though and grips good on wet roads etc. They are relatively low road noise also.
  6. Oct 25, 2011 at 4:36 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Best tire I ever had.
  7. Oct 26, 2011 at 8:38 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    My previous truck was a 98 V-6 access cab TRD. I ran Michelin LTX M/S 31X10.50-15s for 110,000 miles. They were still pretty good tread when I traded them to my barber for a free haircut. He ran them another year(10,000-15,000 miles).
    On my 2011 Standard cab I pulled the stock Dunlop tires off at 1300 miles. They made the truck seem like a drunken hog as they wallered and wandred down the road. Handling in corners was ridiculous. You did not know which end was going to break loose first. I replaced them with Michelin LTX M/S2 265X7016s. It was a whole new truck then.
    If you monitor the tire pressure, alingment and do rotations, I see no reason you should not get 70,000 plus miles from your M/S2. Do not be surprised with 100,000 miles.
  8. Oct 26, 2011 at 8:40 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
