NEW MOTOR OPTIONS
Discussion in '4 Cylinder' started by DrunkenDangler, Jan 7, 2012.
  1. Jan 11, 2012 at 6:08 PM
    DrunkenDangler
    DrunkenDangler [OP] Well-Known Member
    AL
    2005 5 lug access cab
    fat bob lift
    BUMP
    Where would yall buy a new motor for this truck?
  2. Jan 12, 2012 at 8:18 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Just went thru this decision with my Father in Law- a different truck, he had a 98 since new, great shape but he blew the motor. We researched every option, but at the end of the day he could not let "his baby" go for what they wanted to give him to scrape it, and he felt the cost to rebuild and upgrade the current truck and what he would end up with was a lot better option then buying another simular used truck with high mileage, or going new and payments. He went to a great local shop and they talked him out of a rebuild in favor of rebuilding his motor- stating they would build a motor better then any rebuilt one available, and with better parts at about the same price. So far, the truck runs as good as new. Best option IMO if you have a great shop to work with.
    I thought if I ever ran across a very clean older 4x4 Toyota truck, or Landcruiser I wanted to live with "forever", that needed a motor I would consider the diesel option for a long term truck. Its 15K, or so which is alot for the conversion, but parts are available thru dealers, and these 3L diesels run forever. 35-40 mpg or so, with tons of torque. To bad Toyota did not try to get the motor to comply to DOT specs, but I am sure the market would not be there.
    Get a good shop, and rebuild your motor is the best option. Good luck
  3. Jan 13, 2012 at 9:08 PM
    Buggys3sgte
    Buggys3sgte Well-Known Member
    Psycho state of AZ
    97 BUDGET Taco
    Newly rearranged front end, sick Hurst shifter yo gives it lightning fast shifts, thats it more to come.
    I will build ya one but you pay shipping and i need a core back. Just got through rebuilding 2 22re's with .20mm oversize pistons, and am rebuilding 2 more RE's along with a 3vze motor AKA 3.Slow but hey the guy seems to like it. :rolleyes:
