New oil filter drain tool from Fumoto
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NC Gazzer, Nov 1, 2024.
  1. Nov 1, 2024 at 9:53 AM
    NC Gazzer
    NC Gazzer [OP] Well-Known Member
    Durham, NC
    1996 Tacoma 4wd 2.7 + 2023 TRD Sport
  2. Nov 1, 2024 at 1:00 PM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    soundman98 and Jakerou like this.
  3. Nov 1, 2024 at 2:28 PM
    AZPhys13
    AZPhys13 Well-Known Member
    2021 TRD OR DCLB - MGM
    While not entirely necessary, you can also control the flow with the Motivx version.
    soundman98 likes this.
  4. Nov 1, 2024 at 2:48 PM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    One always comes with my filter so no need. For some reason I thought all filters included them, but guess not. Very good item to have.
  5. Nov 1, 2024 at 2:53 PM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    Most filters have a plastic plug included not the screw-in Motivx. But if one can use that plastic plug, good enough.
  6. Nov 1, 2024 at 3:05 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I mount the little plastic gizmo (that comes with the filter) onto a foot long hollow metal tube and then jam the gizmo into the filter housing hole. I direct the other end of the metal tube into my drain bucket and out flows the filter housing oil. Works great every time.
    Canadian Caber likes this.
  7. Nov 1, 2024 at 3:12 PM
    RichochetRabbit
    The only advantage the Motivx tool gives ... and not even necessary at that ... is that the Motivx tool screws into the housing first without opening oil flow, than position the the drain tube and under control screw in the second part of the Motivx into the housing to release the oil. Some probably love this two-step, others do not need it.
    Inyo_man, soundman98 and TacoTime55 like this.
  8. Nov 1, 2024 at 3:35 PM
    Rraiderr
    Rraiderr Well-Known Member
    Great White North
    2017 Tacoma TRD off road
    Working now a list
    I have been using thier drain plugs for years on many vehicles, they make quality stuff.
  9. Nov 1, 2024 at 3:51 PM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    The MotivX drain tool has a grip-able/screw on valve.
    I bought the Kit that did not include the filter wrench.
    It's a good amount that pre-drains.
  10. Nov 1, 2024 at 3:53 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    the plastic one is a joke
    NC Gazzer[OP] likes this.
  11. Nov 2, 2024 at 7:01 AM
    goingplacesanddoingstuff
    goingplacesanddoingstuff Well-Known Member
    2019 TRD Off Road
    2.5” OME lift, Koenig Six Shooter wheels, 275/70r17 Nokian Outpost AT, CMC, Nitro 4.88s, Greenlane aluminum sliders, CBI aluminum skid, Greenlane aluminum front bumper, Out Gear Solutions HC rear bumper, Baja SAE fogs
    I have a metal screw-in one that never works. It’s too hard to get threaded when fighting spring tension. The cheap plastic things that come with the filters work fine. Just jam them in.
  12. Nov 3, 2024 at 9:13 AM
    jackpro2
    jackpro2 Active Member
    i cant get the plastic ones that come with the filter to stick? maybe because i upgraded the housing to the aluminum type. idk
    TacoTime55 likes this.
  13. Nov 3, 2024 at 9:36 AM
    TacoTime55
    TacoTime55 TT58
    Ed
    Delaware
    skidooboy likes this.
  14. Nov 3, 2024 at 1:29 PM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    I bought motix knockoff on Amazon and trimmed the surgical tube that came with it to hang below the rim of my drain pan. No complaints.
