New OME 888 Coil
Discussion in 'Suspension' started by tacomien, May 15, 2016.
  1. Oct 31, 2017 at 4:24 PM
    #301
    SeaJax
    SeaJax Member
    2017 4x4 TRD Sport DCSB MGM
    Full OME Suspension w/ 888s and Dakars
    j5Taco - I have stock OEM control arms.
    SteenosMT - Looks good! I'm not sure if you'll need wheel spacers or not since you've upgraded your UCAs. With stock UCAs and stock rims you need to add wheel spacers to keep 285s from rubbing the UCAs.
    j5Taco likes this.
  2. Oct 31, 2017 at 4:26 PM
    #302
    SteenosMT
    SteenosMT Well-Known Member
    Justin
    2022 TRD Off Road
    Stock for now.
    Thank you for the reply sir! Your truck looks great! Did you end up doing Extended Brake Lines? Mine were pretty tight.
  3. Oct 31, 2017 at 10:34 PM
    #303
    Beef Nachos
    Beef Nachos Here for a good time, not a long time
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    Front or back?
    Want to post some center hub to fendermeasurements now and a few weeks from now when it settles? You know you wanna... ;)
    Looks good!
  4. Nov 1, 2017 at 7:00 AM
    #304
    SteenosMT
    Justin
    2022 TRD Off Road
    Stock for now.
    Thanks! The rear brake lines were tight. I measured the day after the install. 24 inches in the rear and 23.5 inches in the front.
    Beef Nachos[QUOTED] likes this.
  5. Nov 1, 2017 at 7:45 AM
    #305
    j5Taco
    j5Taco Well-Known Member
    Gah! So broke from moving. I’d hate to need them and not have them. Might just buy since it’s cheaper all together
  6. Nov 7, 2017 at 9:01 PM
    #306
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    So the kit from headstrong, the 0.25" spacer for the drivers side goes between the top of the assembled shock and the mount? Correct?
  7. Nov 7, 2017 at 9:02 PM
    #307
    BlakeM
    BlakeM Well-Known Member
    Blake
    Gonzales, LA
    2023 T4R.SR5.4WD.OMG.LOL.WTF
    Yep
  8. Nov 7, 2017 at 9:05 PM
    #308
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    Thanks, I'm 48 hrs away from the install, a bit nervous
  9. Nov 7, 2017 at 9:09 PM
    #309
    BlakeM
    Blake
    Gonzales, LA
    Even after I put the spacer, it's still a little low on the driver's side. Barely noticeable though.
    What are you nervous about? Lol
  10. Nov 7, 2017 at 9:27 PM
    #310
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    ECGS, CMC, just to name a couple. Will it need a sway bar relocate?
  11. Nov 7, 2017 at 9:43 PM
    #311
    BlakeM
    Blake
    Gonzales, LA
    Not sure if it needs to be relocated. I don't want to feed you any shit. I don't even have 888's. I'm just subscribed to this thread until I decide whether I need 886 or 888's.
    Personally, I like to relocate the sway bar to a nice dark corner in the garage.
  12. Nov 7, 2017 at 11:50 PM
    #312
    Beef Nachos
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    ECGS? Do it anyway. Small price to pay to save a future headache.
    CMC? Because even a hefty 265 tire will rub; might as well fix what Toyota didn't.
  13. Nov 8, 2017 at 6:01 AM
    #313
    scottsglock29
    scottsglock29 Well-Known Member
    Scott
    Wisconsin
    2019 Cement TRD Sport DCSB
    IMO, with the stock wheels and 285's, you would most likely need the wheel spacers do to the factory wheel offset and backspace.
  14. Nov 14, 2017 at 4:02 PM
    #314
    dlo13
    dlo13 TinyRigCo.
    Daniel
    Westminster, CA
    2017 Barcelona Red Tacoma TRD Pro
    Forgive my noob question here, but I am running the Pro suspension on my 2017, and 285/70/16. (I haven't seen anyone do the swap with Pro suspension)
    If I go with 888, will my rubbing issues be solved?
    Right now i'm rubbing hard off road and coming in/out of driveways while turning (with a couple of big dudes w/ me).
  15. Nov 18, 2017 at 10:51 AM
    #315
    Tacotm
    Tacotm Member
    2017 silver sr5 tacoma
    I have a 2017 access cab with 5100 front and rear with 888 in the front (factory upper control arm) and Wheelers 2" add a leaf in the rear. I have no complaints with the 888"s in the last two months I have probably put 300 miles of snow wheeling and fast desert driving on them. Defiantly would recommend them.
    YotaKid, gsubioguy, joestacos and 4 others like this.
  16. Nov 18, 2017 at 11:06 AM
    #316
    Dmking8
    Dmking8 Where does it end?
    David
    Leander, TX
    2017 Tacoma TRD Off-Road 4x4 DCSB (Black)
    OME 888 Coils, Billy 5100's, BFG 285/70/17 BRO's with T4R TRD 17X7 Wheels, TRD Pro Front Grille, TRD Pro Shift Knob, Hondo Garage Radio Knobs
    How much total lift did it end up getting you? And what size tires are you running? I'm debating between the 887's and the 888's
  17. Nov 18, 2017 at 11:23 AM
    #317
    Tacotm
    Tacotm Member
    Haven't taken new measurements but it was enough lift to get me down all the trails I use to hit my skid plate on without even coming close. I just put 285 75/16 on and had just a little rub on driver side upper control arm at full lock in reverse so I put spidertrax 1.25 spacers on and now have zero rubbing. I would go with 888s especially if you plan on doing a bumper or a winch at some point in time
    YotaKid and Dmking8[QUOTED] like this.
  18. Nov 18, 2017 at 11:37 AM
    #318
    Dmking8
    David
    Leander, TX
    Excellent. I was leaning towards the 888's so I appreciate the advice.
  19. Nov 18, 2017 at 11:40 AM
    #319
    KrnTaco08
    KrnTaco08 Well-Known Member
    LA
    2017 Taco
    @SeaJax no rubbing and no trimming? Awesome. What’s the offset on your rims? I heard if the rims are 0 offset you won’t have to do any trimming and no rubbing.
  20. Nov 19, 2017 at 3:59 PM
    #320
    SeaJax
    SeaJax Member
    KrnTaco08 - No rubbing anywhere, no trimming needed at all. I don't think it's even close to rubbing. I believe my offset was 1 and backspacing was 5" .
    KrnTaco08 likes this.
