New OME 888 Coil
Discussion in 'Suspension' started by tacomien, May 15, 2016.
  1. Jul 17, 2018 at 12:39 PM
    #501
    lee1092
    lee1092 Well-Known Member
    Lee
    Charlotte, NC
    18 MGM Tacoma
    Did you contact them?
  2. Jul 17, 2018 at 12:49 PM
    #502
    Uscgamecock7
    Uscgamecock7 Well-Known Member
    Nick
    West Columbia, SC
    2015 Tacoma Trd Sport DCLB 4x4(SOLD) 2017 Tacoma Trd OR 4x4(SOLD) 2024 T4R TRD PRO
    You have to remember also they were shipped to canada if your profile is true.....
  3. Jul 17, 2018 at 3:19 PM
    #503
    lee1092
    Lee
    Charlotte, NC
    18 MGM Tacoma
    So any recommendations on what to go with. Want to pick finally. Either the 5100 or full OME setup, both with 888 spring.
    Considering adding 1/4in spacer up front as well. Seems a few guys have a nice setup with it.
  4. Jul 17, 2018 at 6:24 PM
    #504
    T1089
    T1089 Well-Known Member
    Tristan
    B.C. Canada
    2017 Tacoma TRD Sport 6MT
    -Bilstein 5100's EXT + 886 OME coils -Bilstein 7100 14"SB shocks -Camburg Uni ball UCA's -BAMF leaf hanger & shackle -BAMF shock relocation kit -Dakar HD leafs -U-bolt flip kit/super bumps -TRD PRO SEMA rims + 255/80/17 Ridge Grapplers -Cali Raised Led 32" hidden light bar & switch panel - Backflip tonneau -Demello tube sliders -Mobtown skid -TRD Pro grill -Custom bed rack -OVT 2.0 SFOB Tune -2WD Low mod -Kicker CS Speakers
    They were shipped to Washington state where I picked them up . But yes they went a fair distance.
  5. Jul 18, 2018 at 9:21 AM
    #505
    lee1092
    Lee
    Charlotte, NC
    18 MGM Tacoma
    Anyone with input on adding the 1/4 spacer?
  6. Jul 18, 2018 at 11:58 AM
    #506
    SpeySquatch
    2016 TRD OR DCSB
    Make sure you grease the yellow bushings in the leaf loops with marine grease otherwise they squeak when dusty and dry
  7. Jul 18, 2018 at 12:11 PM
    #507
    T1089
    Tristan
    B.C. Canada
    yes I will! I've been reading a lot for the past few months and have everything ready to go.
    If your installing OME 888 coils most kits come with a spacer for the driver side lean (1/4") if your referring to adding 1/4" spacers in addition I'd check out your cv boots and look into doing the "boot slide mod" to give the fins of your cv boots some room. Some people will say it's no issue and some say it will be an issue , just be prepared to do the extra little work to make things right. Also look into ECGS needle bearing replacement as lifting 3" has a good chance of needing this .
  8. Jul 18, 2018 at 12:15 PM
    #508
    Vengar613
    Vengar613 Well-Known Member
    Simi Valley, CA
    2018 MGM 4x4 TRD Off Road
    Pretty sure Headstrong includes a little grease packet don't they?
  9. Jul 18, 2018 at 12:19 PM
    #509
    T1089
    Tristan
    B.C. Canada
    Yes they do
    Vengar613 likes this.
  10. Jul 18, 2018 at 1:07 PM
    #510
    lee1092
    Lee
    Charlotte, NC
    18 MGM Tacoma
    What is ECGS? (new to a lot of this) And is that needed if I dont do the extra spacers, just the OME kit with 888s and Dakar leafs.
  11. Jul 18, 2018 at 7:45 PM
    #511
    SpeySquatch
    2016 TRD OR DCSB
    East coast gear supply needle bearing replacement. It’s a $60 clamshell bushing. A must. Make sure you get the correct size for the differential. The TRDoffroad takes the bushing for the 8” diff. Just got it done and the vibe is FINALLY gone.
  12. Jul 18, 2018 at 7:49 PM
    #512
    lee1092
    Lee
    Charlotte, NC
    18 MGM Tacoma
    It's a must with both OME and the 5100 setup?
  13. Jul 18, 2018 at 7:52 PM
    #513
    lee1092
    Lee
    Charlotte, NC
    18 MGM Tacoma
    Why is it needed and what causes the vib?
  14. Jul 18, 2018 at 7:54 PM
    #514
    SpeySquatch
    2016 TRD OR DCSB
    Any lift 2” or taller
  15. Jul 20, 2018 at 6:51 PM
    #515
    Dor
    Dor Well-Known Member
    James
    '18 MB ACLB TRD-OR
    Torn between OME 887/888s and between Dakar MD/HDs on a 3rd gen. No armor yet but sliders and bumpers front and rear are on the wish list. Wondering if anyone else has had the same dilemma and how it worked out.
    I'm trying to get 2.5-3" of lift or so all around. Keeping the factory rake would be good. I have a hard shell on the back and am putting a platform back there, hence the dilemma - more constant weight than spec for the regular Dakars to get that kind of lift but less than the 660lbs the HDs are spec'd for.
    The three bad outcomes would be:
    1) I go 888s and HD Dakars and the end up with a front-to-back rake or very harsh ride in back
    2) I go 887s and HD Dakars and get a very intense rake or very harsh ride in back
    2) I go 887s and regular Dakars, don't get the amount of lift I'm looking for, and lose more when I throw some armor on.
    My struggle is that the Dakars are spec'd for either 0 load or 660lbs and I'm somewhere in the middle. Anyone with a similar setup?
  16. Jul 20, 2018 at 8:05 PM
    #516
    SpeySquatch
    2016 TRD OR DCSB
    Don’t think you will get 2.5” all around. More like 2” in from 3” back. I went with medium. Plenty of stiffness and weight capability with bumper and sliders. Go with the 6-leaf setup (7-leaf had Dakar’s minus the 3rd leaf from the top) with 3 degree shims if you have the ECGS bushing
  17. Jul 22, 2018 at 7:21 PM
    #517
    Gary86
    Gary86 IG: 2a_Aviator
    Gary
    Corpus Christi, TX
    2018 DCSB Cement TRD 4X4
    Is anyone with a 3rd gen willing to post fender to ground measurements with 5100/888 w/ medium dakar around a 285/70r17 setup?
  18. Jul 30, 2018 at 5:31 PM
    #518
    T1089
    Tristan
    B.C. Canada
    Installed Kit:
    Camburg UCA
    888coils (assembled by "headstrong off-road")
    Bilstein 2nd gen 5100/b110 rears
    1/4" driver side spacer
    Dakar Med
    ECGS bushing
    OME CB drop
    Install took 8 hours. Front was solo , rear had a friend help
    -After install even with my 1/4" driver side spacer truck sits lower by 5/8" on driver side, seems a little odd anyone have any input? I'm thinking of changing it out to a 1/2" spacer. Rear sits level L/R .
    - After install I have some vibration from 0-20mph ( seems to be drive line) and again around 70 mph . The low speed vibration also seems to be at lower rpm's as rpms are higher vibrations are not noticeable. I have not re torqued anything yet (only 60miles sense lift) I'm thinking I may need 3* shims and potentially removing CB drop.
    2017 trd sport double cab MT
  19. Aug 2, 2018 at 1:15 AM
    #519
    sorgon82
    sorgon82 wanna go for a rip bud
    Ont. Canada
    2016 Grey Tacoma sport dc long bed
    Im in the same boat right now. Luckily I added a leaf spring center pin sleeve so if i need the shims theyd be easy to install. Are you going to remove the cb drop when you add the shims? I never thought of that
  20. Aug 7, 2018 at 1:32 PM
    #520
    SpeySquatch
    2016 TRD OR DCSB
    Remove cb drop install toytec 3degree shims and ecgs clamshell bushing
    sorgon82 likes this.
