New OME Dakar Leaf Pack Review
Discussion in 'HeadStrong Off-Road' started by HeadStrong Off-Road, May 3, 2017.
  1. Jan 12, 2019 at 11:41 AM
    #641
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    Great vid. Open drawer bites and head smacks... definitely one of the masses.
  2. Jan 12, 2019 at 11:55 AM
    #642
    Clwrz
    Clwrz Well-Known Member
    San Diego, CA
    2007 Silver Double Cab Tacoma TRD Sport
    Dude that truck causes so much pain to both my body and my wallet.
    ready6delta and go2cnavy[QUOTED] like this.
  3. Jan 12, 2019 at 12:05 PM
    #643
    Nixinus
    Nixinus Well-Known Member
    Oregon
    2010 4x4
    Just a quick update on the rear leaf pack upgrade. Had ELO95s with a tent on bed bars and the pack settled quite a bit (don't have numbers unfortunately). Was sagging and the pack flattened out at 5k miles. Added the OME AAL and the truck is sitting a little high in the back, perfect for loading extra camping gear. Now that I know, I would recommend everyone getting the ELO96s (HD) and waiting for it to settle. If it's too form then just remove the 3rd leaf and keep it in case you need it later.
    ready6delta likes this.
  4. Jan 12, 2019 at 1:18 PM
    #644
    Charlie2017
    Charlie2017 Well-Known Member
    Hans
    Central Washington
    2017 Tacoma TRD Offroad Quicksand MT
    All chrome removed, TRD Pro grill, All-Pro Apex sliders, ARB twin compressor with Slee mount. SSO slimline bumper with Smittybilt X20, Softopper
    I was lucky. I was shipped one with "+" and the other was a "0". Put the "+" on the drivers side to help with the Taco lean.
  5. Jan 12, 2019 at 5:42 PM
    #645
    go2cnavy
  6. Jan 18, 2019 at 8:54 AM
    #646
    HeadStrong Off-Road
    HeadStrong Off-Road [OP] Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    I believe you ended up getting the answer to your question but I figure I would answer it on open forum so people know....
    If you are going to be installing the OME add-a-leaf with either of the packs, medium duty to make into heavy duty, or heavy duty making it even heavier duty, it is always a good idea to make sure that you have at least 1/2" of extra thread showing beyond the nut on both the ubolts and the center pin. The leaf is only about 1/4" thick however you want to make sure that the bolt fully passes through the nut. During many installations of the Dakar people will trim down the center pin so this needs to be inspected as well. Also, I have seen people over look this, if you are planning on adding in some type of liner between the leafs you will also need to account for the thickness of those when it comes to the center pin and ubolt.
    Two more things to note:
    The yellowish -, 0, + on the leaf packs are manufacturer markings. They indicate where the leafs fell during their testing process. A 0 indicates in spec, the + is slightly above spec, and the – is slightly below spec. There are varying degrees within each + and – category as well. Since this is something that is internal with ARB they do not label their leafs left/right side specific nor can we order the 0’s, +’s, or –‘s specifically. Since this is the case we usually recommend our customers to place the higher of the ratings on the driver’s side. This can help to accommodate for the additional weight that is on that side of the truck.
    Lastly, before installing a rear lift it is always a good idea to measure the factory pinion angle. This way should you experience some vibrations after the lift you can remeasure and see what degree you are off and shim accordingly. Two things to note with this.
    A). Prior to installing the Dakars on the truck you can change out the center pin and add the center pin head lengthener. The reason for the center pin change is that the OD of the Dakar center pin is slightly larger then the id of the center pin head lengthener. These parts add up to less then $25 but can save a lot of added labor down the line. Because if you have to shim you will have to remove the leaf pack completely to add these parts in.
    B). The inner bend of the OME ubolts is narrower then a lot of the aftermarket shims. So some people may need to file/grind down the edges of the shims to fit within in the ubolts. Or they can source wider ubolts should they need to shim. The part is up to the user on which method they find preferable.
  7. Jan 18, 2019 at 8:56 AM
    #647
    HeadStrong Off-Road
    Thank you so much for your business, we truly appreciate it!!
    go2cnavy[QUOTED] likes this.
  8. Jan 18, 2019 at 6:34 PM
    #648
    go2cnavy
    They arrived fast as did the separate box of hardware. I installed the very next day.
  9. Jan 20, 2019 at 12:19 PM
    #649
    Cali_Taco
    Cali_Taco Well-Known Member
    kyle
    2017 super white tacoma trd off road
    installed HD leaf pack after a week of driving letting the rear settle. I took measurements of the added lift. My rear passenger is a full inch lower and than my driver side. Has anyone else had this issue? Why is it not leveled across the rear?
  10. Jan 27, 2019 at 4:31 AM
    #650
    charlieyankee88
    charlieyankee88 Well-Known Member
    2017 TRD OR DCSB MT
    RADFLO Suspension, JBA HD UCAs, Mobtown low pro bumper, Mobtown bolt-on sliders, Engo SR10s, SCS Stealth 6, AFE CAI, URD Spec U, OV Tuned, Gobi Rack, Softopper, CMC
    Can anyone speak to the squeekeness of this pack after some use? I had the old Dakar’s on my 2nd gen and they squeeked like crazy. I was thinking of going with icon RXT this time to try and avoid that, but if the new Dakar’s have fixed the problem I would assume save some cash. Any info would be great. Thanks?
  11. Jan 27, 2019 at 1:27 PM
    #651
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    Did you torque bolts while truck was on stands? They should be torqued while truck is on the ground.
    ready6delta and DrFunker like this.
  12. Jan 27, 2019 at 4:53 PM
    #652
    Jakoda
    Jakoda beep boop
    Jackson
    SoCal
    2017 TRDOR DCSB
    Bunch O Shit
    I put anti seize between the leafs when I built and repainted them
  13. Jan 30, 2019 at 8:03 AM
    #653
    Cali_Taco
    kyle
    no I torqued all bolts on the ground. I gave it a full night of settling before I torqued them down
    gotblika[QUOTED] likes this.
  14. Feb 3, 2019 at 9:57 AM
    #654
    Mack411
    Mack411 Well-Known Member
    2017 Quicksand Tacoma Trd-OR
    @HeadStrong Off-Road are the Hd packs in stock? Also do the headstrong bushing kits work for these or do you recommend just getting the package with the bushings and bolts included?What size are the u bolts in the package?
    I messaged you by I'm also needing some advice/guidance on bump stops . I'm hoping some other members may chime in. I just want to know how important adding bump stops would be and if front and rear are worth it.
  15. Feb 3, 2019 at 10:07 AM
    #655
    rollin904
    rollin904 Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    I'm just speaking from my experiences but I believe headstrong gives you a set of their bushings with the packs. Also, before installing throw some grease between the upper leaves to help with squeaks down the road. The packs have a greaseable liner (needle point for grease gun) so you can add some grease every so often.
    If your rear is still uneven after installing on the proper sides (mine came with a "0" and "+" spec), throw a spacer on the front tower of the truck. For instance, I still had a noticeable lean on my rear left pack, even with the "+" side installed on that side, so I added a 1/4" spacer to my front left shock, which translates to a 1/2" lift and compressed the rear right end now my rear end looks pretty close to even. Also, buy aluminum spacers not poly, those things suck and compress over time.
    And as Marie said, measure your angles before installing! You can get a cheap digital gauge on Amazon or even use your phone. I didn't and I've been messing with shims and CB spacers since installation. There's a huge thread on here about driveline vibes and if you have them I suggest reading it.
  16. Feb 3, 2019 at 10:11 AM
    #656
    rollin904
    TJ
    Greenville, SC
    '14 DCSB 4x4
    I got wheelers super bumps and really like them, the fronts are a bit overkill but the rears have really worked great. It might also be a good time to do a u-bolt flip kit so you can order it with the appropriate superbumps.
    Mack411[QUOTED] likes this.
  17. Feb 3, 2019 at 10:21 AM
    #657
    Mack411
    Thanks man that's super helpful actually, I would be tickled if the hd hit does indeed come with some bushings @HeadStrong Off-Road I just couldn't find confirmation of this. I'm hoping it doesn't end up uneven, I will have too much money invested to be dealing with that.I have kings going on the front and rear and was planning to go with timbren but I'm seeing a lot good of the wheelers bump stops. This whole u bolt flip kit thing is new to me.Idk what it involves or what benefit I get from doing it,I did see that wheelers has the rear bumps to use with a flip kit, what else would i need to complete a flip and what would i gain/lose from this?
  18. Feb 3, 2019 at 10:26 AM
    #658
    rollin904
    TJ
    Greenville, SC
    '14 DCSB 4x4
    I havent done the flip kit yet but wish I had, basically you replace the bolts with round ones that fit over the axle and then you tighten everything from the top. Gives you a little more clearance, not that I've bashed mine, but it also keeps you from dragging the bolts and bracket through the mud, which has been more of an issue to me because it cakes up in the bolt threads. And since I have the regular superbumps I'll have to either buy a new set or adapters to run them with a flip kit.
    I want to say the packs dont come with bushings (expected to use oem ones I guess?) so headstrong sent a pack of theirs with them. I ordered the entire ome kit so that might be why they were included with mine, I'd double check.
  19. Feb 3, 2019 at 10:28 AM
    #659
    RetiredSCPO
    RetiredSCPO Well-Known Member
    Will
    Seven Cities
    2017 Tacom TRD Off Road Double Cab-Silver
    Stock
    That was a great video, and I will admit I was laughing my a$$ off with the consecutive banging of the elbow and head. (Sorry) Those pintop shocks can be an absolute horror if the nut is seized on there. A cutoff wheel or saw-zall will make quick work of that. Good Job!
  20. Feb 3, 2019 at 2:34 PM
    #660
    Mack411
    So I did some research and seeing as I can get a set if rear timbren with the flip kit from @Wheeler's Off-Road Inc for a good deal I believe I will go that route,if they can verify stock on this and shipping ETA that will be awesome, I'm assuming it will fit the hd ome pack . Now all I need to know is if the hd ome full pack from @HeadStrong Off-Road does come with their bushings, I think when I was inquiring about a military order once she told me they did but I need to confirm this as well as if they are in stock and shipping eta!! I'm ready to get this show on the road!!
