New OME Dakar Leaf Pack Review
Discussion in 'HeadStrong Off-Road' started by HeadStrong Off-Road, May 3, 2017.
  1. May 8, 2020 at 5:28 PM
    #901
    Pilsner
    Pilsner Well-Known Member
    18 TRDOR
    255/85r16 ST Maxx 6112/5160 w/ Dakar RCI armor, sliders, and rear bumper CBI hidden winch mount w/ Smity 20k
    @HeadStrong Off-Road
    Can you help? I have seen a few different things here, but based on my results I would have thought one with a little higher spring rate.
    ejewels likes this.
  2. May 8, 2020 at 7:51 PM
    #902
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    Taco lean is more in front and two leaf packs at 0 just means they are exactly spec. Which is fine. If you get a plus or minus it is recommended to out plus on driver side but isn’t needed.
    ejewels[QUOTED] likes this.
  3. May 8, 2020 at 8:31 PM
    #903
    Pilsner
    18 TRDOR
    So why does there appear to be a random set sold? It all makes sense until it looks to be a random pick.
    ejewels likes this.
  4. May 8, 2020 at 8:42 PM
    #904
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
  5. May 8, 2020 at 9:23 PM
    #905
    Desert Dog
    Desert Dog Well-Known Member
    Los Gatos
    2007 DCSB
    Work in progress
    Kinda begs the question why ARB takes time to mark then. If they all fall within spec and ARB is going to give you a random pair anyway, what is to be gained other than the occasional irritated customer who gets both marked (-) who is left thinking they got a below average set. Only make sense if they are sorting them so no one ever gets two (-) or a (+) combined with a (-).
    ejewels likes this.
  6. May 9, 2020 at 4:13 AM
    #906
    ejewels
    ejewels Well-Known Member
    CT
    2018 MGM TRD OR 4x4 DCSB
    6112/5160/Dakars/Pro Tacoma Wheels
    ok well at least it’s ok to use 2 of the same. I’m thinking the differences are so minimal that OME doesn’t find it important enough to make sure someone gets any particular version.
    ready6delta likes this.
  7. May 9, 2020 at 7:24 AM
    #907
    Pilsner
    18 TRDOR
    Also don't understand why most kits don't come with shims, even the factory packs have a shim. I ordered and installed 2.5* and have no vibe issues so far. That aligns your driveshaft much better than a carrier bearing drop bracket.
    ready6delta and ejewels like this.
  8. May 9, 2020 at 10:23 AM
    #908
    ready6delta
    JACOB
    I would Think the variation is negligible when you are talking the amount of weight they can carry.
  9. May 9, 2020 at 10:24 AM
    #909
    ready6delta
    JACOB
    Not every one needs shims depending on your load suspension setup and lift choice. I haven’t Had any vibes and have the HD pack.
  10. May 9, 2020 at 12:10 PM
    #910
    Pilsner
    18 TRDOR
    Pinion angle will be off regardless. Once lifted, that angle will be steeper and U joints would last longer if that angle was less severe. Even the stock pack has a shim. People can do whatever they choose, but I think it is a good idea.
  11. May 9, 2020 at 6:16 PM
    #911
    tacothyme
    tacothyme Well-Known Member
    Cory
    Seattle, WA
    18 DCLB OR
    265/70/17
    this is what I did. It’s worked great!
    now I’ve got the extra leaf lying around for once I get topper/toolbox set figured out and purchased.
  12. May 9, 2020 at 7:48 PM
    #912
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    EL096R pack with no weight in the back and no vibes
  13. May 10, 2020 at 10:26 AM
    #913
    ejewels
    CT
    I actually don’t buy the “no vibes” thing. I think some people just don’t notice them. I was really sensitive to it, though.
    dhectorg likes this.
  14. May 10, 2020 at 10:28 AM
    #914
    ejewels
    CT
    How much more lift does adding the extra leaf to make the 95r to 96 add? Would the 3 degree shims I have still work or would I be chasing vibes again? Not sure how much of a difference it is angle-wise
  15. May 10, 2020 at 11:18 AM
    #915
    Pilsner
    18 TRDOR
    I don't think it's much more if anything unless you have the weight in the rear.
    ejewels likes this.
  16. May 30, 2020 at 6:44 PM
    #916
    ready6delta
    JACOB
    it sits pretty high unless you are constantly carrying weight. Check the website for specs.
  17. Jun 10, 2020 at 2:50 PM
    #917
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Question for you all running the heavy packs and the aal d29xl. Can the centering pin still be used or are you all sourcing new ones? Also does anyone have a link for the anti squeak pads to add to the aal? I need to install the aal due to the weight I run the heavies sagged about 1/2” from level.
  18. Jun 13, 2020 at 11:16 AM
    #918
    lechicklet
    lechicklet Well-Known Member
    Chey
    California
    ‘13 4WD DblCab Ltd
    Seriously considering getting the medium load pack, but I need some feedback before I fork over the monies...
    Problem: I have adjustable Bilstein 5100’s, a Leer cap and a cap rack (300lbs constant load). Presently the 5100’s are set on the notch that gives me the most lift which is about 2.5”. With the cap and the rack I’m sagging, and the ride isn’t that great because of the shock setting.
    Goal: 1.) I want the smoothest ride my Bilsteins can give me, 2.) I want to keep my 2.5” lift, and 3.) I want more load support so I’ll stop sagging.
    My question is: If I get this OME Dakar leaf pack and put the shocks back to their default setting (no notches, so no extra lift) will the leaf pack retain the 2.5” lift I want? Or would I need to get an additional lift kit to compensate?
    Asking this because unfortunately I won’t install this myself and shop labor ain’t cheap so I’d want to knock out as many jobs in one shot as possible.
    Thoughts, experiences and suggestions welcome =]
  19. Jun 13, 2020 at 4:45 PM
    #919
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    Maybe I’m wrong but the rear shocks dont typically give the lift it’s the leaf springs. It’s just the rear shocks can accommodate up to X amount of lift. Again I could be wrong.
    I put the heavys on my truck and with shell I had about 2.5” of lift. Once I added my fridge, drawer system and rtt back on it went down to only about 1.75-2” of lift. Not ideal so I’m adding in the aal next weekend to bring it back up.
    gotblika likes this.
  20. Jun 13, 2020 at 6:31 PM
    #920
    gotblika
    Maui
    2015 DCLB Sport 4X4
    Adjustable 5100 is for the front, no shock will give you lift in rear. I’d get the HD pack.
