New overland builder
Discussion in 'New Members' started by Cody_Cochran, May 20, 2023.
  1. May 20, 2023 at 4:55 PM
    Cody_Cochran
    Cody_Cochran [OP] New Member
    Cody
    21 Tacoma sr
    Eibach pro lift 2.0 coil over with rear reservoir, body armor hiline bumper, Smittybilt 9500 winch, over land bed rack with Smittybilt gen 2 xl tent.
    Hey everyone I’m new to this forum but have been coming here for tricks and tips on my build off profile. I have a 21 Tacoma sr rwd with lsd. Just doing an overland build to check out some good camp spots off grid and enjoy the ride along the way. Nothing too serious like rock climbing or big mudding. I have a body armor hiline bumper with a smittybilt 9500 winch, hook bed rack with smittybilt gen 2 xl tent, some traction boards, shovel, air compressor for rougher roads when aired down. Currently installed the eibach pro truck coil over 2.0 with rear reservoir shocks. Looking to get some feed back on these as they were supposed to help level truck and bring the front end up from the bumper/ winch weight and be a middle ground from fox/bilstein. I just put them on out of box and the front end is 1.5” higher than the rear. 37.5” front/36” rear with a terrible sag. Slight camber up front as well. Supposed to be supported up to 2.5” on the uca but I’m not seeing that after installing. Talked to a specialist and said I might need a 1.5” add a leaf added to the rear to help get the rake so when the weight is added it will level with out comprising ride like the rear lift blocks would. Any ideas how to get this to set level at 2.5” lift out of bow to match the rear with out sagging ? Hard to find info retaining to this specific question on here. Only came across how it rides and what they’re running . Etc. I figured these would’ve helped level and support but not I’m kinda disappointed at first install and hoping to fix this issue before I decide to return in my 30 days. Any ideas.?
    buckhuntin-tacoma likes this.
  2. May 21, 2023 at 4:29 PM
    The605taco
    The605taco Well-Known Member
    Sawyer
    2014 4X4 short bed
    6112(notch 3) 5160 icon AAL Baja fogs and Ditch lights Headwaters seat covers Off roam phone mount Diamond back cover
    I’m no expert on the SR side of the Tacomas. My two cents is that it’s a fresh install and so you will get setling happen in the coming weeks. You didn’t lift the rear and so 36” is roughly stock ride height a AAL may help for a while but in my experience with my icon aal it wore out in two years and I was in a similar position as you. I would recommend going with a headstrong off-road if you want one and leave the overload spring in. If you want a totally different ride I would look into a different leaf all together. Not sure those ideas fit for a 2wd. I installed an icon RTX on mine and it changed the whole dynamic of the truck.
    A bilstin kit (5100) may be the better long term solution to all issues due to adjustability of them. Again I am not sure this is able on 2wd versions. My only experience is with 4x4 and up.
    HondaGM likes this.
  3. May 30, 2023 at 11:42 AM
    Cody_Cochran
    Cody
    21 Tacoma sr
    Installed the aal this weekend and it brought it up with slight rake so when loaded it levels out nicely. I can tell it’s going to wear out like you mentioned after taking it out this weekend. But I ended up having a shit alignment from the first person who helped out, so I took it for a second opinion and they got it squared away and riding very good now. Will look into the leaf pack for future but for now just going to leave till I can trade in for a 4x4. Would’ve got it the first time but the wait and price difference at the time was out of my budget for my first financed purchase. But hoping to have. Good trade in for the next one. Thanks for the insight!
    HondaGM likes this.
  4. May 30, 2023 at 6:39 PM
    The605taco
    Sawyer
    2014 4X4 short bed
    No problem. I would recommend as you look into different things do not start cheep at all. Do it right the first time. Save the money up and do it right. As now being around and somewhat in the industry I would recommend starting and staying with Dobinson’s do the leafs their shocks and their coilovers(mrr) and everything else like control arms…. I love my 6112 setup with the icon leaf pack and 5160 in the rear but wish I would have saved the extra 1-2k to drop on that kit from the beginning. Would have saved me a lot of headaches tbh and probably spending more money then the kit costs if I just had realized this when starting out.
  5. May 30, 2023 at 6:43 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW…
  6. May 30, 2023 at 8:33 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
    Cody_Cochran[OP] likes this.
  7. May 30, 2023 at 8:40 PM
    Cincy Tacoma
    Cincy Tacoma Well-Known Member
    Cincinnati, Ohio
    Welcome to the TW.
  8. Jul 13, 2023 at 4:29 PM
    tacoma1311
    tacoma1311 Well-Known Member
    Pictures?
  9. Jul 13, 2023 at 6:29 PM
    Cody_Cochran
    Cody
    21 Tacoma sr
  10. Jul 13, 2023 at 6:30 PM
    Cody_Cochran
    Cody
    21 Tacoma sr
  11. Jul 13, 2023 at 6:32 PM
    Cody_Cochran
    Cody
    21 Tacoma sr
  12. Jul 13, 2023 at 6:34 PM
    Cody_Cochran
    Cody
    21 Tacoma sr
    hwntaco20 likes this.
  13. Jul 13, 2023 at 6:40 PM
    tacoma1311
    Thank you. Looks great!
  14. Jul 20, 2023 at 5:13 PM
    Gazner
    Gazner New Member
    Eric
    2017 White Tacoma TRD
    Rigs looking good. Welcome to TW
