New Owner Advice
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SomandlilV, Jul 27, 2023.
  1. Jul 27, 2023 at 1:53 PM
    SomandlilV
    SomandlilV [OP] Member
    Sam
    2023 Lunar Rock TRD Sport 4x4
    Hey,
    Any advice for a first time owner of a new TRD sport 4x4? Anything to think about when I first pick it up from the dealership? Such as a break in period.
    Also, any common problems with the 3rd gen?
    Thanks!
  2. Jul 27, 2023 at 1:58 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  3. Jul 27, 2023 at 2:03 PM
    lavrishevo
    lavrishevo Well-Known Member
    2023 Trail Edition
    Many don’t seems to agree but I always do oil evacuation. Yes, the rings and seals are bedded from the factory but I think people are kidding themselves if they don’t believe there is a large amount of metal in the oil after the first 500 -
    1000 miles of driving. Even used oil analysis are not recommended until these wear metals has settled down.
    I remove this oil, put fresh high quality synthetic in. Avoid cruise control and long trips maintaining the same speed. I also avoid going wide open throttle much until 1k miles. My personal favorite oil for the money is M1 European Formula 0w or 5w-40. It may be overkill but this technique has always produced great motors for me so I continue to follow it / oil is cheap.
    FredRed315, marko1959 and HondaGM like this.
  4. Jul 27, 2023 at 2:05 PM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    part out
    EL DUDE, Chew, Steves104x4 and 4 others like this.
  5. Jul 27, 2023 at 2:13 PM
    RedRoss
    RedRoss Well-Known Member
    '23 TRD Sport WCP DCLB
    Congrats!
    You're kidding right? Start reading threads. TW requires you have to do the following: Undercoating. Remove every and all pieces of chrome, silver or the like. Get your new pro grill put on asap. Then drive directly to the tune shop, do not pass go. Leave the tune shop and go get your new wheels, tires (start with 33"), and then lift. While there check on window tint and rain guards. Call Kansas for extended warranty insurance to 10 yrs /125K mi. If your bed is not covered stop in the nearest topper shop and check choose from those option. And there's more, you're just getting started. So when your done with that list stop at the bank for Taco support loan. You're gonna need it. Tacos aren't cheap.
    Good luck!
    Mikeh80, Hansamzac, wayupnort and 8 others like this.
  6. Jul 27, 2023 at 2:18 PM
    Blak Shinobi
    Blak Shinobi Well-Known Member
    taco
    2020 MGM Sport DCSB 4x4
    n/a
    Dont forget to rev that crap out of it so those rings settle in
    :burnrubber:
    wayupnort and HondaGM like this.
  7. Jul 27, 2023 at 2:18 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Chew, HondaGM and oldtimertoyota like this.
  8. Jul 27, 2023 at 2:20 PM
    19992021Taco
    19992021Taco Well-Known Member
    1999 and 2021 Tacoma
    HAHA: Love this.
    HondaGM likes this.
  9. Jul 27, 2023 at 2:21 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Definitely read your owners manual as it contains everything you need to know concerning break in, basic maintenance, etc.
    Concerning common problems, stick around here but hold your nose brother! It'll take about 20 minutes before you are second guessing everything you have ever known including the meaning of life itself.
    Steves104x4, RustyGreen, Chew and 2 others like this.
  10. Jul 27, 2023 at 2:24 PM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    You are under warranty any issues should arise just take it to the dealer . I wouldn’t worry about mechanical issues . The break in period is listed in the manual don’t tow or rev the engine to high while in break in period . Pick yourself up an oem bed mat while u are there .
    HondaGM likes this.
  11. Jul 27, 2023 at 2:27 PM
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    Welcome to TW! Pick up your new truck and enjoy it, hopefully you’ll have it for many many years to come!
    HondaGM likes this.
  12. Jul 27, 2023 at 2:28 PM
    TA2016
    Oregon
    HondaGM likes this.
  13. Jul 27, 2023 at 2:33 PM
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    For camper shell, look into bed stiffeners and silicone under the plastic bed rails. At 900 mi I'm on my 3rd locking gas cap and still haven't found one that the computer likes. After hearing about 3gen as a 1gen'er, my expectations for the auto transmisssion were so low that I actually think it isn't bad. And yep am already moving ahead on the 125k mi warranty from Kansas :anonymous:
    HondaGM likes this.
  14. Jul 27, 2023 at 2:37 PM
    GBourne
    GBourne Just a regular guy
    Grant
    Surprise, AZ.
    23 Ram 1500 Classic
    Dumped the Tacoma, that's all it needed.
    I’d make sure that the bed is properly aligned at deliver time, and that the front left corner of the hood matches the front right corner of the hood.
    remember that any “services” the finance manager tries to sell you have at least 100% markup, so if you want an extended service plan (some incorrectly call it an extended warranty) or prepaid maintenance, you can get it far cheaper than they are offering it to you. Same with tint, and any other accessories or “coverages”
    HondaGM likes this.
  15. Jul 27, 2023 at 2:45 PM
    TA2016
    Oregon
    I have a CarQuest (rebranded Stant 10504) locking gas cap that has never thrown a CEL Light. Here is a good thread with pictures of caps that work and don’t. My gas cap picture is in post #8.
    https://www.tacomaworld.com/threads...p-to-avoid-engine-light.747326/#post-26611100
    tacoma_ca[QUOTED] and HondaGM like this.
  16. Jul 27, 2023 at 2:54 PM
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    In this order or not
    • Factory bed mat
    • Better floor mats….Husky X-Act
    • Tint (ceramic is better)
    • Seat Jackers….Desert does it
    • Ceramic coat…..I like Adams Graphine
    • LOMAX hard tonneau search for TW discount
    Then when you get to 1000 miles get an OEM filter and some 0w20. Change the oil and then again at 5000, 10k, 15k. OR if you’re a 10k person follow that route.
    Enjoy your new truck.
    Smunczen likes this.
  17. Jul 27, 2023 at 3:22 PM
    Fitasc Fanatic
    Fitasc Fanatic Member
    My advice is to go straight back to dealership and trade it in for a Tundra lol. I owned a 2020 m/t OR and drove it for 80k. Traded it in for a 2023 new SR OR Tundra and ain’t looking in the rear view mirror. More power, more payload, more power, roomier, more power, more comfortable, quieter and gets virtually the same gas mileage. Only negative that I see is parking in tight spaces and costs 10 k more. Did I say more power? Accelerates without hesitation when you need it. Oh and voice speakers and sound system way better. Probably not as nimble climbing in Moab so if that’s your thing then keep it. Otherwise….
  18. Jul 27, 2023 at 3:35 PM
    Wwjvd
    Wwjvd Well-Known Member
    Jimmy
    2022 TRD Off-road 4wd
    SPOT ON!
    wayupnort likes this.
  19. Jul 27, 2023 at 4:24 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Welcome to the forum :hattip:
    Read your owners manual - there is a lot of good information there.
    The Toyota bed mat is worth the money.
    Beware this forum - we like helping you :spending: !
    HBear47 and oldtimertoyota like this.
  20. Jul 27, 2023 at 4:34 PM
    Hogleg918
    Hogleg918 Well-Known Member
    Oklahoma
    Ranger Raptor, sorry TW
    Don’t forget the oil change at 2,500, 3,500, and 4,346.
    LeakyAC likes this.
