New Owner Lift Advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RRDave, Dec 13, 2010.
  1. Dec 13, 2010 at 11:54 AM
    RRDave
    RRDave [OP] Well-Known Member
    Halifax, NS
    08 Black TRD
    CAI, AT2525XL, 2.5" spacer, 1.5" AAL, DNX6140 HU c/w rearview cam, Fog Light Mod, Custom rear dog seat,
    Hey Guys,
    I just purchased an 08 Taco TRD and am considering my options as far as a lift kit goes. I don't want to do anything drastic, but I would like to be able to fit somewhat larger tires on the truck..maybe 265/75 17 or 285/70 17. Regardless, I would like any and all input/advice when it comes to lifting. I would like to lift 3" and if I do so it would be with a simple kit like....
    http://www.toyteclifts.com/index.ph...tegory_id=113&option=com_virtuemart&Itemid=72
    Is there anything else I should consider installing if this is the kit I choose? I've read things like a diff drop would be a good idea, but am curious if anyone has any feedback/comments?
    Ultimately the goal is to lift the truck, install bigger tires, while not sacrificing reliability/longevity, while keeping it as cheap as possible.
    Any input is greatly appreciated.
  2. Dec 13, 2010 at 11:59 AM
    Manwithoutaplan
    ID
    Get the Long Travel Kit BY ALL Pro http://www.allprooffroad.com/. Go with 285 tires. I have the Pro comp Stage II with Coil overs and wish i would have gone with the Long travel kit but oh well.
  3. Dec 13, 2010 at 12:00 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    I would recommend taking just a step farther, and getting a set of Bilstein 5100s instead of going with a spacer lift up front. The 5100s will provide 2.5" of lift up front, plus you get a better shock with bigger piston, and improved valving at the same time.
    For the rear either the single, or 3 leaf aal will work great. The 3 leaf will provide a smoother ride than the single leaf setup.
  4. Dec 13, 2010 at 12:03 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  5. Dec 13, 2010 at 12:05 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Or that^^ Also another good option.
    OP, if you want to go with 285s, you will need different rims or wheel spacers.
  6. Dec 13, 2010 at 12:18 PM
    RRDave
    Halifax, NS
    08 Black TRD
    Guys,
    Thanks for the great replies/input.
    Manwithoutaplan: That set up looks great, but quite a bit more than I'd like to spend.
    YotaDan: I like the idea of the 5100's up front. Is that all I'd require for the front..what about the rear, beyond the AAL.
    98Tacoma27: That first kit from ToyTec is pretty much exactly what I'm looking for in terms of price/ease of installation. Would I need anything else ie: diff drop?
    Keep in mind that I don't really plan on doing any offroading, and if so very light (I baby my vehicles). I'm really just interested in the look, without sacrificing reliability.
    Thanks again for the replies!
  7. Dec 13, 2010 at 12:22 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    No diff drop is needed IMHO.
  8. Dec 13, 2010 at 12:39 PM
    ACE808
    ACE808 Well-Known Member
    DDS
    808 State
    TRD Off Road 4x4
    Toytec 3" lift light racing uca moto metals 17" (958) k&n intake Helix throttle body Borla exhaust Nfab step bar All-pro transfer case shield All-pro spindle gussets All-pro sway bar links All-pro E-locker guard All-pro rear differential armor All-pro U-bolt flip kit L.E.D. White/Blue Dash Gauge lighting Full alpine stereo with TV screens Clifford alarm optima red top battery Full wet okole seats auto meter gauges (oil pressure & volt meter) Ebc slotted & dimpled rotor Goodrich braided brake lines Hawks Lts brake pads Rear diff breather relocation
    Go with 5100 all around, diff drop, aal on rear, and don't forget light racing upper control arms. This a perfect daily driver set up.
