NEW OWNER OF 2004 TACOMA 4x4
Discussion in '1st Gen. Tacomas (1995-2004)' started by BVSR, Jan 16, 2023.
  1. Jan 16, 2023 at 12:30 PM
    BVSR
    BVSR [OP] Member
    I'm new here and I just bought my 1st Tacoma 4x4, it's a 2004 Double cab with 260,000 miles on it. Now that's a lot of miles to me but these trucks have a good reputation for going the distance but I'm a CHEVROLET man so we'll see how this goes. I've always liked these little trucks and finally got the chance to buy one. My dash lights are out and the fuse is good so that's the 1st little problem the 2nd is when you driving down the road and let off of accelerator there is a roaring or rubbing sound it makes until you accelerate again, mine son has the very same truck and his makes the same noise so is this just one of the characteristics of this truck as I can't find anything loose as of yet. Thanks for any help and it's good to be on here.
  2. Jan 16, 2023 at 8:32 PM
    tacoseveryday4567
    tacoseveryday4567 Member
    Jacob
    Marina
    2000 Tacoma
    Welcome to Tacoma World! Sounds like you got a good truck with minimal issues. As for the roaring/rubbing on deceleration, my truck doesn't do that, but there can be so many different causes it will be hard to pin point. I'm sure your son is aware since he has a 1st gen but definitely check those lower ball joints, as they are a well known weak spot on these truck. Other than that check up on the normal maintenance, and enjoy your truck!!
    BVSR[OP] and po35042 like this.
  3. Jan 16, 2023 at 8:51 PM
    po35042
    po35042 Well-Known Member
    Patrick
    Tuscaloosa, AL
    2021 SR 4x4 DCSB
    Welcome friend, slide under it sometime and check your ujoints and driveshaft carrier bearing for looseness. for the dash lights, check all ground wires with a bolt on them and remove, sand, and retighten. Even if these don't fix all your problems they need to be done. Good Luck!
    BVSR[OP] likes this.
  4. Jan 17, 2023 at 3:46 AM
    Tjk031
    Tjk031 Active Member
    Tommy
    2003 double cab 4x4 trd
    Welcome! Sounds like you got a nice Tacoma! This place is great with a ton of info. Best of luck with the new truck!
  5. Jan 17, 2023 at 4:23 AM
    Squirt
    Squirt Samsung Aficionado!
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
    Welcome to TW!
    BVSR[OP] and Taco critter like this.
  6. Jan 17, 2023 at 4:43 AM
    Clearwater Bill
    Billy
    Largo Florida
    You don't list a location. But if the truck has lived anywhere around salt I hope you gave the frame a proper pre purchase inspection. As in a ball peen, a probe, and a scope to look inside the boxed areas.
    I once bought a vehicle that the dash lights were out. Turned out that every bulb was bad.
  7. Jan 17, 2023 at 2:54 PM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    The add for a 1st gen I looked at years ago said “no check engine light”. And I guess it was literally true since the rat bastard seller had removed the bulb.
  8. Jan 17, 2023 at 3:07 PM
    J Williams
    J Williams Well-Known Member
    Jeff
    Central MN
    2021 TRD Pro
    Welcome to TW…congrats on the new wheels!
  9. Jan 17, 2023 at 7:16 PM
    Chipped Paint
    Chipped Paint Member
    Arkansas
    04 Tacoma Xtra Cab TRD
    I hope you noticed when you turned the key while kickin the tires.
  10. Jan 18, 2023 at 11:15 AM
    BVSR
    BVSR [OP] Member
    I live in Northeast Arkansas, before I bought it I rolled all around under the truck and it's clean as a pin, no paint covering up anything and it hasn't been in the mud, all highway miles. It's a clean original truck that runs like a sewing machine.
  11. Jan 19, 2023 at 3:16 AM
    Kevins60
    Kevin
    Odessa FL
    I did. One of the things I checked was that all of the dash lights worked when the key was on. When I asked the seller if he knew the CEL didn’t work he said yes, there was a code for o2 sensor that he hadn’t fixed and we could go to the local parts store to have codes read. I just got a bad vibe and passed on the truck. Seems like a lot more work to disable the CEL than to replace the sensor.
  12. Jan 19, 2023 at 11:01 AM
    BossFan
    BossFan Well-Known Member
    Frank
    NJ
    03 TRD 4x4 X-Cab MT swap
    Tundra brakes Bilstein 5100s OME springs
    Welcome to TW! Tons of useful information here. When I bought my ‘03 in 2016, it also had no CEL, until the ride home. I’m pretty convinced the seller just reset the light. Turned out to be an O2 sensor, so not that big of a deal, but I still think the seller was a bit shady.
    best of luck with your new truck!
  13. Jan 24, 2023 at 12:06 PM
    BVSR
    BVSR [OP] Member
    update on instrument lights, all the bulbs were burnt out, imagine that??? how many of you guys are running 265/75R16 4 ply tires on the Tacomas, I think the 10 ply tires are too heavy for my needs as I'm on the highway all the time.
  14. Jan 24, 2023 at 12:25 PM
    det107
    det107 Well-Known Member
    So much this!!
    Welcome to TW!! You won't regret jumping ship to Tacoma's ! :thumbsup:
  15. Jan 24, 2023 at 5:18 PM
    wjcunningham3
    wjcunningham3 Well-Known Member
    Joe
    2002 Lunar Mist Tacoma TRD V6 4x4 Manual
    Mostly stock - but I do have a suction cup phone holder - its pretty sweet
    Welcome to TW and welcome to Tacoma ownership! They are great trucks and I really like the size of these! To me - they are the perfect size without being massive. I have hauled more mulch and other chores than I can remember - and enjoyed doing it.
    I have a dash light out that I haven’t replaced yet - but when I do - I am going to replace all of them just in case! Glad it was something simple for you.
