New Owner of a 2010 Tacoma TRD 4X4
Discussion in 'New Members' started by brianc142, Dec 30, 2009.
  1. Dec 30, 2009 at 11:42 AM
    brianc142
    brianc142 [OP] Active Member
    South Carolina
    2021 TRD OR DC
    I just purchased a new Double Cab TRD Off Road 4X4. This is my first Toyota after a 10 year lay off. My first Toyota 4x4 was an '87, then a '93 and two Tacomas, '95 regular cab and '96 access cab. I've been driving Chevys and Fords since I sold my '96. Well I came back to the light and plan to stay here this time. I have been lurking here for a week or so and just joined up. Great forum with lots of good information for Tacoma owners.
  2. Dec 30, 2009 at 11:43 AM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Welcome!
  3. Dec 30, 2009 at 12:54 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Welcome as well... I got the very same truck 3 weeks ago... and just finally figured out all the new drive features after 4 wheeling and reading replies on this forum. This is my third Tacoma (after the '01 and '05).
    Here is what we have in the 2010 4WD TRD Off Road (USA):
    a) VSC: Vehicle Stability Control was develpoed by Bosch and uses sensors to apply brakes to wheels to keep the truck moving safely if it should go into a skid.
    b) TRAC: Traction Control normally on in 2WD uses both brakes and cuts power as needed to create a limited slip differential action by braking spinning wheels and directing power to wheels with traction. In 4WD (H4), engine output is not regulated.
    c) AUTO LSD (2WD Only): If TRAC is turned off in 2WD, AUTO LSD turns on and forces power to the wheel with traction by braking the spinning wheel. NO power is cut in AUTO LSD. AUTO LSD (TRAC Off only) cannot be activated in 4WD. (TRAC works the same as AUTO LSD in H4 on all 4 wheels. A-TRAC works the same as AUTO LSD in L4 on all 4 wheels).
    d) A-TRAC (Active Traction Control) works only in L4 (Low Range 4WD)... works like AUTO LSD, but on all 4 wheels.
    e) RR DIFF LOCK (Rear Differential Lock) works only in L4 on 4WD Tacomas. VSC and TRAC are both off when the rear differential is locked.
    Now, the various options of driving systems using the above 5 traction controls:
    1) 2WD: VSC and TRAC normally active.
    2) 2WD: Quick push of switch (car with wavy skid lines) turns off 'TRAC' and 'VSC', and turns on 'AUTO LSD'. Gives maximum power to tire with traction by braking spinning tire without cutting power.
    3) 2WD: 5 second push of switch turns off all three (VSC, TRAC, AUTO LSD) for free spinning of tires. VSC will reactivate if driving over 30 MPH. This is for getting out of snow, mud, sand if spinning the tires or rocking the truck can help.
    4) 4WD-Hi (H4): VSC and TRAC are both on. No engine power is cut in TRAC while in H4.
    5) 4WD-Hi: 5 second push of button (while stopped) turns off VSC and TRAC. This allows spinning of tires if needed.
    6) 4WD-Lo: VSC and TRAC are both off.
    7) 4WD-Lo: Push of A-TRAC button (by Cig. lighter) activates A-TRAC and forces power to the wheel with traction by braking the spinning wheel. NO power is cut in A-TRAC (just like how AUTO LSD works in 2WD).
    8) 4WD-Lo: RR DIFF LOCK gives equal power to both back wheels and power to either one of the front wheels (open front differential).
    9) 4WD-Lo: RR DIFF LOCK and A-TRAC activated would make the front differential limited slip by braking a spinning tire and forcing power to the tire with traction.
  4. Dec 30, 2009 at 1:01 PM
    jeremy
    jeremy Active Member
    jeremy
    mass
    07 trd off road
    welcome
  5. Dec 30, 2009 at 1:02 PM
    AK27
    AK27 Well-Known Member
    welcome!
  6. Dec 30, 2009 at 1:04 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Welcome to TW bud!! :wave:
  7. Dec 30, 2009 at 1:06 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    welcome to tw brian.
    wow nice man. This needs to be a thread of its own and a sticky
  8. Dec 30, 2009 at 1:26 PM
    TRICOMA
    TRICOMA Tacoma with the TRI package
    Tri
    Carlsbad, CA
    2010 Tacoma DC SB 4x4 TRD Off Road
    King Off-Road Shock Coilover 2.5 with Resi in the front. King Off-Road Shocks 2.5 with Resi's for the rears, Rear Spring TSB, KMC XD Enduros 16x8, Black Vinyl Fenders, Bed compartment locks, Cobra 19 DX IV with Lil Wil mag mount antenna, CoverKing Seat covers front and rear, Built Right UCAs, Aluminess Expedition Bumper, GY Wrangler MT/R with Kevlar 265/75-16, Custom hybrid style rock sliders.
    Welcome, but I really think you should leave now before it is too late. I have a 2010 and the mods have been non stop...save your money now before TW takes over...Don't say I didn't warn you.
  9. Dec 30, 2009 at 6:57 PM
    brianc142
    South Carolina
    2021 TRD OR DC
    Thanks for the welcome guys. David K., excellent information, thanks for sharing brother. Just to add to my original post, my truck is Silver Streak Mica and I haven't even seen it in person yet. I'm currently on the job in Afghanistan but will be home on Jan. 8th. I bought the truck from my local dealership over the phone and internet and my wife picked it up for me. It is sitting in my driveway waiting for me to come home. This was my Christmas present to me.:D
  10. Dec 30, 2009 at 6:59 PM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    Welcome!!! Great write up btw
  11. Dec 30, 2009 at 8:51 PM
    David K
    Thanks for your service to our freedom my friend. My 2010 is also the same color!
  12. Dec 31, 2009 at 2:38 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    welcome from SC too. lots of members around SC if u need any help w/ anything
  13. Dec 31, 2009 at 4:29 AM
    XSB41
    XSB41 If I had a hammer...
    Rik
    Va.
    2010 SR5 4X4
    hitch haul, bed extender, bed mat, behind seat gun rack, roof rack
    Congrats...got the same rig ALMOST; picked an SR5 since I'll mainly use it for zipping 'round town and the occasional foray into the woodline. If you happen to see any 101st folks over there, especially Tiger Force recon, tell 'em a former trooper sez howdy...we're all pulling for you guys, and our appreciation is hard to describe in words. Looking forward to seeing some pics of you and your new aquisition!:)
  14. Dec 31, 2009 at 10:22 AM
    David K
    I shortened it up and put it in my signature, below all my posts here... Having fun figuring it all out!
