New owner of a Toyota Tacoma 07 question for DIY guys. In Pa
Discussion in 'New Members' started by zig07 tacoma, Sep 15, 2018.
  1. Sep 15, 2018 at 5:32 PM
    zig07 tacoma
    zig07 tacoma [OP] Active Member
    ARMSTRONG/BUTLER COUNTY, PA
    2007 TACOMA ACCESS CAB 4WD
    So I just got mine, little late lol but it's an 07 tacoma sr5 access cab 4x4, 4.0 engine.... Question have any of you guys changed your fluids, I ask because other than the engine oil being ok as conventional 5 w 30 ... the transfer case and two differentials should they be synthetic or conventional as well? the manual doesn't say either way? I am going to do this myself.
    Bigdaddy4760, NAAC3TACO and Hobbs like this.
  2. Sep 15, 2018 at 5:41 PM
    dreadedyota
    dreadedyota Well-Known Member
    Ernest
    Ontario Canada
    2008 Black Tacoma TRD.SR5.Sport
    Camburg UCA,Cowl Induction, ECGS, Exhaust Reroute.
    If you change your fluid often or at-least inspect them at oil changes conventional would be fine, synthetic is better and generally lasts longer but is more expensive it really depends on your maintenance schedule. I personally run all synthetic fluid because I sometimes forget and the added protection is always a good backup.
  3. Sep 15, 2018 at 5:47 PM
    zig07 tacoma
    Thanks Got ya...... thanks yes i am pretty good about 4,000miles or every 3 months.
  4. Sep 15, 2018 at 5:50 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    Welcome to The Forum! :thumbsup:
  5. Sep 15, 2018 at 5:51 PM
    dreadedyota
    Ernest
    Ontario Canada
    If your willing to save a few bucks at fluid changes conventional would be just fine, Welcome to TW as well!
    zig07 tacoma[OP] likes this.
  6. Sep 15, 2018 at 5:52 PM
    zig07 tacoma
    Thanks most of my wrench turning was on chevys from mid 70's up till now . lol so just need to switch a little bit ..... but still was wondering. Thanks for the welcome.
  7. Sep 15, 2018 at 5:58 PM
    kystnTRD
    kystnTRD Ramblin Man
    NW Pennsylvania
    2016 TRD Sport 6MT
    look at your oil and change accordingly whether you use conventional or synthetic. 4000miles you are likely throwing money away. You should be able to get double that under normal driving conditions. I understand people will argue this both ways so do whatever gives you piece of mind. Just my personal 2cents and has served me well
  8. Sep 15, 2018 at 6:04 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Welcome!
    zig07 tacoma[OP] and Hobbs like this.
  9. Sep 15, 2018 at 6:08 PM
    Bishop84
    Bishop84 Well-Known Member
    Tacomas do not need any special oil, only the early TRD sports/xrunners had lsd in the rear.
    You can use regular 75w90 on the axles/tcase and standard 5w30 oil in the motor.
    I'd never bother with synthetic unless you want to push intervals a bit. But regular oil changes go a long way.
    I've yet to see a lubrication failure in the 4.0 except for those who don't do oil changes 50k at a time.
  10. Sep 15, 2018 at 6:12 PM
    zig07 tacoma
    Bishop Thanks good info, my diff has a Lsd tag on it. so i guess i need it. NAAc3 Thank you.
  11. Sep 15, 2018 at 6:14 PM
    Bishop84
    Up in Canada we only got LSD on sport models, good that you caught that.
    Special fluid for sure in the rear axle. Some people use full synthetic LSD oil, some people use regular gear oil with LSD additive. Both work fine!
  12. Sep 15, 2018 at 7:07 PM
    Bigdaddy4760
    Maner
    Poolville Texas
  13. Sep 15, 2018 at 7:22 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!!
  14. Sep 15, 2018 at 7:30 PM
    man17TRDoffroad
    man17TRDoffroad Well-Known Member
    Manny
    Basecamp Mars
    21 Tacoma DCSB TRD Offroad Cement
    Badge blackouts, tailgate inserts
    welcome to the site! maybe look into synthetic blends
  15. Sep 16, 2018 at 7:09 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW! I prefer synthetic for the diffs and tcase since it's a much longer change interval.
    man17TRDoffroad and dreadedyota like this.
