New owner, what should I do?
Discussion in '1st Gen. Tacomas (1995-2004)' started by kenm, Jul 24, 2011.
  1. Jul 24, 2011 at 1:46 PM
    kenm
    kenm [OP] New Member
    Jacksonville, FL
    01 PreRunner SR5
    STOCK
    I am the proud new owner of an 01 Prerunner double cab with a camper top. I need to add a rack to transport construction equipment. any ideas?
  2. Jul 24, 2011 at 2:00 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    nice truck and welcome! Seems like theres always some construction/raft racks floatin around craigslist. Keep a close eye there. If your lucky you'll find one that has an extended base so you can keep the shell.
  3. Jul 25, 2011 at 3:46 PM
    jbrandt
    jbrandt Well-Known Member
    Sacramento, CA
    '04 TRD Tacoma 4x4 DC
    King ext travel coils Total Chaos UCAs Sticker mod
    I would look into having one custom made. It shouldn't cost too much more (if any) than buying one off the shelf. (~$600+/-)
    OR.....
    Buy one for your truck (craigslist?) that doesn't fit the camper shell, then have a local fabricator extend its width to fit the shell... All you'd need is an extra 2-3" on each side. Cut it down the middle, and insert new tubing and weld up. Use 1/4" or thicker steel plate for the bed mount extension. You shouldn't need to worry about the height, they extend over the cab anyway.
    just some ideas...
  4. Jul 26, 2011 at 4:47 AM
    kenm
    Jacksonville, FL
    01 PreRunner SR5
    STOCK
    I think I understand, you are suggesting using a tradional rack, but extended wider to go around the cap. good idea. does anybody have any pictures?
  5. Jul 26, 2011 at 4:52 AM
    rleeharris
    rleeharris "Old Timer," compliments of 11Taco2.7
    Bob
    San Antonio, Texas
    '11 Tundra Crew Max TRD Off Road
    ^ I think that's what everyone is suggesting. A stand-off rack that is supported by the rails not the camper shell. If it is not a contractor/commercial shell, it will probably only support a minimum weight because it is not reinforced to support heavy loads. Certainly not enough for routine construction/carpentry equipment and materials. I'm sure someone has one on here... just can't recall seeing one. Welcome to TW!
  6. Jul 26, 2011 at 4:55 AM
    hpvds
    hpvds Well-Known Member
    Manie
    Seattle, WA
    Barcelona Red 2010 4x4 Doublecab
    Ironman 4x4 FCP lift, ARB bumper, NL Dual bats, Skids and sliders
    Here's what we had on my old truck (my dad's tacoma) that was identical to yours. If you want more details on what we had just ask.
    photos/hpvds/5977756116/" title="J3008x2000-14112 by HPVDS, on Flickr">[​IMG]</a>
    more for rec. use but may fit your needs
  7. Jul 26, 2011 at 4:56 AM
    rleeharris
    Bob
    San Antonio, Texas
    OP, how much weight are you thinking you'll carry?
  8. Jul 26, 2011 at 4:58 AM
    rleeharris
    Bob
    San Antonio, Texas
    Just checked the Leer site for example. The regular caps generally can support no more than 150 pounds and that's on their optional Thule rack system. Their commercial versions can support 400lbs. May make a big difference to you depending on your needs.
