New PCV valve whistle?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by J-KIN81, Oct 12, 2023.
  1. Oct 12, 2023 at 5:31 PM
    J-KIN81
    J-KIN81 [OP] Well-Known Member
    Replaced the pcv valve at 70k now I’m getting a faint whistle not sure of the source.
  2. Oct 12, 2023 at 5:35 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    If you have a code reader with live data, the fuel trim values will help determine if you have a vacuum leak. Otherwise, start pulling hoses one at a time.
  3. Oct 12, 2023 at 5:43 PM
    J-KIN81
    Ya no reader. It’s gotta be related to this damn pcv valve but everything snug.
  4. Oct 12, 2023 at 6:03 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    At what mileage are you now?
    You said you replaced it at 70k, but we need more info.
    How long as the PCV been on?
    Have you pinched the hose off temporarily or removed the hose to see if the “whistle” goes away?
    Maybe it’s not the PCV?
  5. Oct 12, 2023 at 6:19 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Did you tighten it too far and crack the valve cover?
    joba27n likes this.
  6. Oct 12, 2023 at 6:23 PM
    J-KIN81
    Literally just replaced it. I snugged it up old one had 3-4 threads exposed this is at about same spot.
  7. Oct 12, 2023 at 6:30 PM
    J-KIN81
    Lol well I hope not I don’t see any cracks in vicinity of the pcv valve.
  8. Oct 12, 2023 at 6:32 PM
    Chuy
    Lakeside, CA
    Silver Taco
    Did you use teflon tape on the threads? That may help. Maybe a new hose clamp also.
  9. Oct 12, 2023 at 6:35 PM
    J-KIN81
    Old clamps are definitely not as tight on the new hose used no tape. Hypothetically if I had cracked valve cover it would be near the pcv right? Sorry guys I’m a rookie.
  10. Oct 12, 2023 at 6:57 PM
    J-KIN81
    So I took the new one out put old one back in and it’s quite again.
    b_r_o and TnShooter like this.
  11. Oct 12, 2023 at 6:58 PM
    TnShooter
    Deogee
    STOCK
    Yes. It would be right around where the PCV threads in.
    The PCV is a tapered thread, it gets larger in diameter the further you screw it in.
    That’s why you do not “need” tape. You can use some if it makes you feel better.
    I forget the the actual spec, but “spark plug” is good. Like 13-15 ft/lbs or so.
  12. Oct 12, 2023 at 7:07 PM
    Clearwater Bill
    Billy
    Largo Florida
    Is the new one an aftermarket bit? They don't work out well for some items.
    Why did you replace the old one? General maintenance or to solve a problem?
    Did you test the old one to verify it was bad? Or still good?
  13. Oct 12, 2023 at 7:08 PM
    J-KIN81
    General maintenance, its got some build up but still functional.
  14. Oct 12, 2023 at 7:10 PM
    J-KIN81
    New one came straight from Toyota however right from jump it was not want to thread in. I didn’t cross thread it but it was being difficult.
  15. Oct 12, 2023 at 7:11 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Aftermarket?
  16. Oct 12, 2023 at 7:36 PM
    J-KIN81
    No it’s Oem part. Tefloned it same thing very faint whine. I just said screw it removed it put old one back on and I’ll get another tomorrow from Toyota.
    JGO likes this.
  17. Oct 13, 2023 at 3:48 PM
    J-KIN81
    Well got it replaced. New one went in easy went sung 3-4 threads still exposed. Same faint whine tried a squirt of oil around the threads to check for leak no bubbles just quickly ran down. No cracks in cover looks like I’m rolling with it.
    Chuy likes this.
  18. Oct 13, 2023 at 4:51 PM
    joba27n
    Nolan
    Alberta
    Be mindful checking like that because that area will be under vacuum not pressure, so it will pull in anything sprayed in the area not push it out with bubbles. Maybe spray a shot of brake clean around it to see if it changes the idle from being drawn in or even a bit of water
  19. Oct 13, 2023 at 6:11 PM
    J-KIN81
    . I did try a bit of water no change. Only thing that’s made a difference was putting the old one back in lol. I figure I’m just going to have to accept the noise. Anything I should watch for if it is a vacuum leak?
  20. Oct 13, 2023 at 6:18 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Check engine light possibly coming on with fuel trim codes present
