New Pioneer DMH-WC6600NEX flush mount install
Discussion in 'Audio & Video' started by PreRunnerSeth, May 27, 2020.
  1. Jul 18, 2020 at 6:20 PM
    #721
    plim
    plim Well-Known Member
    Pascal
    2019 Black TRD Pro
    I believe I gave a good suggestion to Arisian, who has a camera which is warm even if the truck is off. It would suggest it is always powered.
    dwillhere1[QUOTED] likes this.
  2. Jul 18, 2020 at 6:39 PM
    #722
    plim
    Pascal
    2019 Black TRD Pro
  3. Jul 18, 2020 at 11:04 PM
    #723
    vmart
    vmart Well-Known Member
    victor
    Southern California - Riverside Area
    2020 Tacoma Double Cab TRD Premium Package Offroad 4x4 Short Bed Advanced Technology Package
    OV Tune - Valley Runner Installed Authorized Installer For Valley Tuning PM me for details Black Out Trim Package Toyota Bed Mat TRD Skid Plate TRD Cold Air Intake TRD Shifter TRD Pro Tail Lights ADS Suspension Front Coilovers with Reservoirs ADS Suspension Rear with Reservoirs Dirt King Upper Control Arms Cali Raised Off Road Rock Sliders Gibson Exhaust Air Bags with Daystar Cradles U402 Stage 1 Deaver Leaf Spring Kit Snugtop Rebel Shell Snugtop Wireless Pro Lock Power Lock Tailgate Rago Fabrication Bed Stiffeners Spiker Engineering Hood Struts Tinted Windows Rain Guards DMM - Dash Multi Mount Sequencial Turn Signals Raptor Lights in stock 2020 grill Baja Designs Squadron Fog Lights FN Wheels - Konig Countersteer Type X Dark Metallic Blue 17" x 8" Great Design, Quality and Price Point. Thanks Dustin - Great guy to buy your next set of wheels from - www.fnwheels.com Nitto Ridge Grapplers 285/70/R17 - Americas Tire Cab Mount Chop - Beast Fab in San Bernardino Thanks Geraldo - You did a fantastic job https://www.instagram.com/tv/CGbT97SHBtg/ Parts yet to be installed: Body Armor Hiline Front Bumper Light Bar for above Rugged Ridge Trekker 12LB Winch for above Screen Protech Kit Future: Regear Rack Rear Bumper ??
    Nice Install
    TX Toy Taco likes this.
  4. Jul 19, 2020 at 8:53 AM
    #724
    Arisian
    Arisian Well-Known Member
    2019 Gray Tacom SR5
    none yet!
    Correct, I have it wired into my blue sea fuse box - but I'm ignorant of what the process should be for making sure it switches off when the truck is off - perhaps I need a switch between the blue sea and the battery?
  5. Jul 19, 2020 at 11:58 AM
    #725
    plim
    Pascal
    2019 Black TRD Pro
    I suggest you use switched power. On the radio, you have 2 12V power wires. Yellow and Red. The red one is connected to switched power, which is only powered when the ignition is on. The Yellow wire is used for memory functions and has 12V all the time.
    Unless you have switched power in your blue sea fuse box, I would not use it for things that don’t have a switch to power them on or off.
    There are also many fuses you can tap into using an add-a-fuse in the driver side fuse box at the kick panel. Some are switched and some have constant 12 volts.
    hope this helps.
    Arisian[QUOTED] likes this.
  6. Jul 19, 2020 at 12:05 PM
    #726
    Arisian
    2019 Gray Tacom SR5
    none yet!
    That does help. Basically find a switched fuse slot in the oem fuse box, add a fuse piggy back /add-a-circuit - Run that power to the camera
    Thanks
  7. Jul 19, 2020 at 12:12 PM
    #727
    emund
    emund Well-Known Member
    Arroyo Grande, CA
    2017 Inferno TRD OR 4x4
    I'm slightly confused with the software bypass comments. There's no need to disconnect GPS to "listen" to video when driving correct? I've read the last several pages and that's the only thing that has me scratching my head. Sorry if I missed the answer in there somewhere.
  8. Jul 19, 2020 at 1:13 PM
    #728
    plim
    Pascal
    2019 Black TRD Pro
    correct. Software bypass works for watching video while in motion.
    However the keyboard in Google Maps and in Apple Maps, still don’t work while the vehicle is in motion.
    emund[QUOTED] likes this.
  9. Jul 19, 2020 at 1:30 PM
    #729
    TiHo
    TiHo Well-Known Member
    2018 TRD Sport
    Do you need to use the ODBII cable that comes with the TO2 harness? Thanks!
  10. Jul 19, 2020 at 1:59 PM
    #730
    MGMSangTaco
    MGMSangTaco Colorado Toyota Tuning
    Denver, CO
    2017 TRD OR MGM DCLB
    Are all the plug ins in the back the same As stock jbl? I want to keep my wiring to my switch pro and front cam
  11. Jul 19, 2020 at 3:51 PM
    #731
    svermilyea
    svermilyea Well-Known Member
    Scott
    East Tennessee
    2018 Taco Sport (Cement)
    3in leveling lift (Coilovers and AAL) 285/65R18 tires 18" Fuel wheel/tire package Pro Grill, Morimoto XB LED Headlights, DD SS3 Pro Fogs Body Armor Front and Rear Bumpers Pioneer WC6600 head unit w/ OEM Audio + Reference 500 System with dedicated sub amp Meso signal lights, gas hole, led interior lights, ECT relocate, Chrome delete kits Meso Overhead Molle Rack, Seat Risers, Katzkin Leather seats (self installed...it was a fucking bitch) VFTuned .....KDMax Pro!
    If you wish to pull over TPMS readings, door open readings, and be able to adjust a few other settings ..... yes
  12. Jul 19, 2020 at 4:37 PM
    #732
    Ch78
    Ch78 GBO!
    Tomball, TX
    25’ Landcruiser 1958
    Tuned By D3 Performance
    Should be. The OP had JBL I believe, so he should be able to answer that.
    MGMSangTaco[QUOTED] likes this.
  13. Jul 20, 2020 at 6:30 AM
    #733
    dwillhere1
    dwillhere1 Well-Known Member
    Dan
    Surprise, AZ
    2017 TRD OFFROAD
    I am on my second pioneer unit in this truck, an avh-2400nex, and now the DMH-wc7600nex. I have not used the obd2 connector, and still can access the tpms, doors open, RPM, temps, etc.. I do not believe it gives you any more options using the actual obd2 connection. I also have ovtune, and know that it will not load if I don't go in and disable the obd2 connection through oem settings on the pioneer deck.
  14. Jul 20, 2020 at 7:08 AM
    #734
    TX Toy Taco
    TX Toy Taco Member
    Just a quick note that hopefully saves somebody a headache. I wanted to put in a matte screen protector because I didn't like the reflection and fingerprints with the stock radio. So I removed the stock screen protector. DO NOT do this....it was a huge pain in the ass because it breaks into pieces as you remove it and you are left with a bunch of residual glue. After a few hours of elbow grease I finally got 99% off but I do not recommend this. I almost passed out when I started thinking I had just ruined my $900 radio. If I had it to do over again I would just put it over the built it screen protector. Hope my experience helps somebody out!
    Ch78 likes this.
  15. Jul 20, 2020 at 7:24 AM
    #735
    TiHo
    2018 TRD Sport
    Got mine installed and everything is working except the firmware transfer. I can connect using the CarAVAssist app just fine but everytime I try to transfer it fails. I have read and reread the manual and read every post in this thread. I have tried it every which way possible. Anyone have any tips?
  16. Jul 20, 2020 at 7:35 AM
    #736
    dwillhere1
    Dan
    Surprise, AZ
    2017 TRD OFFROAD
    @svermilyea Morning. A couple post back someone stated they peeled off the oem film that came on their pioneer unit and it was a nightmare, recommending for people to not do this. My screen glass protectors came in last week and I am going to install one soon. Did u pull off the pioneer oem screen protector? Just curious. I have never had any issues before, but definitely don't want a nightmare on my hands. lol Please let me know if u installed the glass over the pioneer film, or removed it and then installed the glass?
    Thanks
  17. Jul 20, 2020 at 7:37 AM
    #737
    Ch78
    Ch78 GBO!
    Tomball, TX
    I had the same issue & the OP pointed me in the right direction. You need to go into the settings on your radio and do it. There’s instructions several pages back on how to do it.
  18. Jul 20, 2020 at 7:38 AM
    #738
    dwillhere1
    Dan
    Surprise, AZ
    2017 TRD OFFROAD
    @TiHo Did u go into the settings screen and select (firmware) or firmware update? Something like this? I know you have to be connected to AVassist and then go into the settings and select update firmware to download the update. I tried multiple times to just download the update by doing it from my phone multiple times. wasn't until I went into settings and selected the software update did it work. The instructions posted somewhere in this forum are what I ultimately used.
  19. Jul 20, 2020 at 7:45 AM
    #739
    TiHo
    2018 TRD Sport
    Yea I tried that too following the directions in this thread. I will try again later. Too frustrated now lol.
  20. Jul 20, 2020 at 7:50 AM
    #740
    svermilyea
    Scott
    East Tennessee
    Yes, I pulled off the OEM screen protector (mine had a slightly peeled up edge and was causing me OCD issues). It is really stuck on there, but take your time and it will come off. The glue on the protector is very sticky. I used Turtle Wax Label and Sticker remover and a soft cotton cloth to remove the remaining glue (this is also what I used to de-badge my truck). Then I wiped down the screen with rubbing alcohol before using the prep pads and installing the tempered glass screen protector.
