New Pioneer DMH-WC6600NEX flush mount install
Discussion in 'Audio & Video' started by PreRunnerSeth, May 27, 2020.
  1. Dec 12, 2020 at 7:25 PM
    #1261
    Tamagotchee
    Tamagotchee Well-Known Member
    SWVA
    2019 TRD Off Road Tacoma
    After the latest Pioneer update (1.30) my head unit will not find my phones hotspot. It will connect to my home WiFi with no issues. Any ideas?
  2. Dec 12, 2020 at 9:02 PM
    #1262
    Mmacdonald808
    Mmacdonald808 Member
    2017 Tacoma 4x4 sport
    Just finished the install today. That was way more involved than I imagined. A couple questions for the more experienced here. My radio doesn’t get any reception. I bought the adapter from crutchfield. It has a blue wire coming off the adapter. Does that need to get wired to anything? Also, is it better to use the Pioneer gps hardware or just use the crutchfield adapter to use the truck gps?
  3. Dec 12, 2020 at 9:10 PM
    #1263
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    FM antenna is amplified and needs the blue connected.
    Make sure you picked the right GPS connector vs the SAT as they are the same shape. GPS is white, SAT is black. The info thread first post should have this.
  4. Dec 12, 2020 at 10:36 PM
    #1264
    Mmacdonald808
    Do you know which wire I connect to the blue antenna wire? And don’t bother with the gps dongle thing that pioneer supplies with the head unit? Just use the adapter to connect the oem connection to the pioneer?
  5. Dec 13, 2020 at 5:08 AM
    #1265
    daveeasa
    David
    PNW
    The Pioneer head unit provides a blue remote out. It’s solid blue. You tie that to the fm antenna via the adaptor which also has solid blue. Here is what my harness looks like, I left 3 leads for remote out triggers:
    EDIT: maybe I am a bonehead and pioneer remote out is blue/white? Can’t remember. I use a PAC TR4 which has solid colors or at least that’s how I remember it. I see in my harness a blue white feeding the green so I think I am misremembering the pioneer remote out as blue when it really is blue / white. My bad.
    oostroma likes this.
  6. Dec 13, 2020 at 12:44 PM
    #1266
    j-utah
    j-utah Well-Known Member
    2024 Tundra SR5 Air Suspension
    If it isn’t your blue wire, then check out the pin on your harness adapter and make sure it didn’t pull out. That adapter can be tricky to get in there.
  7. Dec 13, 2020 at 2:06 PM
    #1267
    Jamuelsackson08
    Jamuelsackson08 Member
    2017 White Tacoma TRDOR
    I seen that on the instructions if you didn’t have jbl but I have the jbl system do you still cut and splice them?
  8. Dec 13, 2020 at 2:08 PM
    #1268
    Mmacdonald808
    I pulled the stereo and re-did the wiring. The maestro has a blue/white wire which I had originally wired to the blue amp out wire coming off the pioneer. I cut that connection and wired the radio blue to the pioneer blue. I left the maestro blue/white unconnected. Now the radio reception is good. Not sure if the unconnected maestro wire is going to affect anything. Doesn’t seem like it so far.
    I used the gps adapter on the white connector on the car side and connected it to the head unit. When I used Waze in CarPlay it doesn’t pick up a gps signal. I love the look of this stereo, but the connections are driving me crazy. Also the avcarassist app is the biggest piece of garbage Ive ever seen. Cannot update the firmware and getting a hotspot connection from my phone is a huge hassle.
    edit: I do not have the jbl upgrade
  9. Dec 13, 2020 at 3:44 PM
    #1269
    j-utah
    The blue provides power and switches things on so I think you need to connect all of the blues together from the pioneer.
  10. Dec 13, 2020 at 8:07 PM
    #1270
    MGMSangTaco
    MGMSangTaco Colorado Toyota Tuning
    Denver, CO
    2017 TRD OR MGM DCLB
    Just ordered finally after following from the beginning. Anyone have any advice that would either save me some time or help me not mess something up haha?
    I have seen people are modifying the jbl speaker setup, do you guys think there’s a significant improvement? I consider myself somewhat of an audiophile and think the jbl sounds pretty darn good. Plus there are people that say this headunit alone improves sound. Thoughts?
  11. Dec 13, 2020 at 9:22 PM
    #1271
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    Has anyone attempted to rotate the Volume/ Up-Down pad so it makes more sense?
  12. Dec 14, 2020 at 4:52 AM
    #1272
    daveeasa
    David
    PNW
    I haven’t tried that yet. I’ve gotten more used to it now. But I might try if someone else does all the work and posts a step by step.
    I think you’ll be happy. I know I am. Wireless CarPlay is great. Audio quality is excellent. The only thing I miss is a volume knob. The screen is much better.
    Quick start guide:
    1. Solve mounting first. I have some photos of how I did mine. Several ways to get this done. Do the work on the bench and test fit. Use the factory brackets.
    2. Do your harness on the bench too and take your time to connect Pioneer to maestro. In retrospect, I’d have done a custom connector vs solder and heat shrink. But that would have added bulk too, it just would have looked cooler. Actually I’d have done two connectors, one 8 pin for speaker and one for everything else. I’m working on an 8 pin speaker injection T from the amps so I can reuse OEM wire to the speakers. Posilock is a nice option, butt connectors are fine too. It’s all color to color, very idiot proof. Make sure to connect the FM antenna blue lead. Read the maestro wiring a few times, all the complicated stuff is in there, I just missed it a bit and wound up asking.
    3. GPS and SAT are the same shape connector so don’t confuse them. SAT is black and GPS is white, confirm on the info thread. Info thread has all the important stuff, too, use it as a quick reference.
    4. Skip the ODB connector and maybe the 3.5mm audio too. Heck, I don’t even have my USB port accessible anymore. Use a short pigtail for USB if you want that, 2-4” usb-C to female A. Vs the hard adaptor it comes with to avoid damage if you are concerned about that.
    5. Be prepared for some pain updating firmware. It really ought to be something the unit can do on its own via wifi. it’s a pretty rough process and doesn’t make much sense. Or do a USB stick. I might go that way next time.
    6. Be prepared to flash the maestro a few times. Also some have said it can’t be flashed in the vehicle while connected. Maybe you get it perfect the first time.
    7. I had no trouble with the pink wire or any trouble with the power lead but be ready for advanced troubleshooting there.
    That’s about it. Lots of leftover parts from the maestro harness and unit which aren’t used. Compatible with Germes with small mods to supply power to it. Lots of super experts on this thread who know more than I do and have better memory and reading comprehension but I’m happy to try too, feel free to hit me up direct as well.
  13. Dec 14, 2020 at 6:14 AM
    #1273
    Bishop4WD
    Bishop4WD Well-Known Member
    San Diego until I escape Communist California
    2019 MGM Off Road
    I just remapped it using the Maestro. Much less hassle. I never look at the pad when I'm using it now that it is mapped in a more intuitive way so the fact that the graphics don't quite match the function doesn't bother me in the least.
  14. Dec 14, 2020 at 8:01 AM
    #1274
    MGMSangTaco
    Denver, CO
    Thank you sir! Very helpful information. I’ll probably be reaching out at some point too though haha
    daveeasa[QUOTED] likes this.
  15. Dec 14, 2020 at 10:18 AM
    #1275
    cvance383
    cvance383 Member
    I'm looking to upgrade from the stock (non-premium radio) to this WC6600. It looks like I am only able to find the premium radio bezel with the gunmetal trim but mine is all back. Does anyone know if the little trim ring piece can be swapped between the bezels? Is it just the inner hole that is difference between them? So I could have a bezel that fits this new stereo but matches the rest of my dash.
    I don't think I have the skill or tools to modify/cut my bezel to fit the Pioneer WC6600.
  16. Dec 14, 2020 at 11:02 AM
    #1276
    svermilyea
    svermilyea Well-Known Member
    Scott
    East Tennessee
    2018 Taco Sport (Cement)
    3in leveling lift (Coilovers and AAL) 285/65R18 tires 18" Fuel wheel/tire package Pro Grill, Morimoto XB LED Headlights, DD SS3 Pro Fogs Body Armor Front and Rear Bumpers Pioneer WC6600 head unit w/ OEM Audio + Reference 500 System with dedicated sub amp Meso signal lights, gas hole, led interior lights, ECT relocate, Chrome delete kits Meso Overhead Molle Rack, Seat Risers, Katzkin Leather seats (self installed...it was a fucking bitch) VFTuned .....KDMax Pro!
    the trim from your original bezel can be removed and installed on the new bezel.
    cvance383[QUOTED] and daveeasa like this.
  17. Dec 14, 2020 at 11:10 AM
    #1277
    cvance383
    cvance383 Member
    Thanks svermilyea, because I don't think they even make one in all black for the premium stereo. I will try to report back here after I buy one and install it, to confirm. I think I'll also need to ditch the little chrome rings on the AC vents.
  18. Dec 14, 2020 at 6:05 PM
    #1278
    Jamuelsackson08
    Im wiring in my stereo and the only plug I can’t seem to find where it goes is the two row black OBDII plug that plugs into the car. Am I missing something?
  19. Dec 14, 2020 at 6:14 PM
    #1279
    daveeasa
    David
    PNW
    Nope. Skip that one.
  20. Dec 14, 2020 at 6:20 PM
    #1280
    oostroma
    oostroma (Boomer)
    Ontario
    You are looking for the OBD2 connector for the truck?
