New Pioneer DMH-WC6600NEX flush mount install
Discussion in 'Audio & Video' started by PreRunnerSeth, May 27, 2020.
  1. Feb 23, 2022 at 6:29 AM
    #1721
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    All TRD trims have the “premium” bezel as far as I know. Maybe SR5 too?
  2. Feb 23, 2022 at 10:47 AM
    #1722
    TiHo
    TiHo Well-Known Member
    2018 TRD Sport
    Yep I installed in my ‘18 Sport without replacing my bezel. Should be the same for your OR I believe.
  3. Feb 23, 2022 at 6:23 PM
    #1723
    Bubble Wrap
    Bubble Wrap Well-Known Member
    Honolulu, HI
    2016 SR5 DCSB MGM
    I can only speak for the Entune 2.0 (2016-2019) but yes, all the TRD models have the premium bezel with the larger opening that will fit the 6600 without any modifications. SR and SR5 have the smaller opening which is why I had to get the new/premium bezel.
  4. Feb 24, 2022 at 3:19 PM
    #1724
    TSmoove
    TSmoove Well-Known Member
    Trevor
    Atlanta, GA
    2017 Tacoma
    SR5 here. Mine has the larger bezel due to having the Rear Parking Sensor and Nav package.
  5. Mar 9, 2022 at 4:32 PM
    #1725
    Kgilcris24
    Kgilcris24 New Member
    Kayne
    New Hampshire
    2022 TRD Sport Lunar Rock
    TRD Lift with 32" Falken Wildpeaks
    Hi all, first post here. I have a 2022 TRD sport with JBL. I did the WT7600 (got a great deal on the 7600 from a friend that works at best buy) upgrade because it looked amazing and everyone said it was a huge improvement over stock head unit soundwise, while it looks great the sound quality is actually worse than the stock system now. Didn't change anything besides the head unit and the maestro. I've played around with the settings a bunch and have been able to make it a little better, but still not even back to stock. Has anyone else had this issue? I tried looking but didn't see anything. Any help would be greatly appreciated!
  6. Mar 12, 2022 at 7:40 AM
    #1726
    Kgilcris24
    Kayne
    New Hampshire
    Can anyone with JBL confirm where the RCAs are supposed to plug into on the head unit? Am I just using the front speaker out? Does the JBL amp redirect to the correct speakers from there? I am very new to car audio so any help is greatly appreciated on getting this thing to sound at least as good as it did stock.
  7. Mar 14, 2022 at 4:40 PM
    #1727
    groundball8404
    groundball8404 Well-Known Member
    NC
    2022 TRD Off Road
    Changing the head unit on the JBL doesn't do anything but give you more radio features. It doesn't change the sound because the head unit only sends a signal to the JBL amp which does all the work. You would need to change out the amp with a better aftermarket amp to get any noticeable improvement with the aftermarket head unit.
    Unfortunately the JBL system is much harder to upgrade because you have to either keep the stock head unit and use something like a PAC Amp Pro to replace the amp and then replace all the speakers that can then handle the power from the new amp or replace everything including the head unit.
    Your options are basically put the stock head unit back in or replace the JBL amp and more than likely the speakers and the sub.
    Hopefully someone with the JBL system can jump in and correct me if I am wrong.
    This is a thread from last year and @destin_meeks answers the question relating to the stock JBL head unit.
    https://www.tacomaworld.com/threads/gen-3-speaker-upgrade-with-jbl-premium-system.717414/
  8. Mar 27, 2022 at 12:29 PM
    #1728
    booka-p3
    booka-p3 Well-Known Member
    Levi
    17 SR5 4x4/DCLB
    stock
    I am running into the same issue. How did you go about finding/sourcing the premium bezel?
  9. Mar 27, 2022 at 12:31 PM
    #1729
    TiHo
    2018 TRD Sport
  10. Mar 27, 2022 at 12:32 PM
    #1730
    booka-p3
    Levi
    17 SR5 4x4/DCLB
    stock
  11. Mar 27, 2022 at 12:52 PM
    #1731
    Bubble Wrap
    Honolulu, HI
    2016 SR5 DCSB MGM
  12. Mar 27, 2022 at 1:13 PM
    #1732
    svermilyea
    svermilyea Well-Known Member
    Scott
    East Tennessee
    2018 Taco Sport (Cement)
    3in leveling lift (Coilovers and AAL) 285/65R18 tires 18" Fuel wheel/tire package Pro Grill, Morimoto XB LED Headlights, DD SS3 Pro Fogs Body Armor Front and Rear Bumpers Pioneer WC6600 head unit w/ OEM Audio + Reference 500 System with dedicated sub amp Meso signal lights, gas hole, led interior lights, ECT relocate, Chrome delete kits Meso Overhead Molle Rack, Seat Risers, Katzkin Leather seats (self installed...it was a fucking bitch) VFTuned .....KDMax Pro!
  13. Mar 27, 2022 at 1:14 PM
    #1733
    booka-p3
    Levi
    17 SR5 4x4/DCLB
    stock
    Yeah a free 6600 would definitely make it nicer! I have a friend at Toyota so will see if he can get me a premium panel down the road. In the mean time my multi-tool and dremel just got some play. Not perfect but it took 10 minutes and could do it now.
    HUTCHRED likes this.
  14. Mar 29, 2022 at 5:16 PM
    #1734
    Rokket
    Rokket New Member
    I just finished the install today of the Pioneer. I also installed a small 75W amp, Kicker component system in the front and Kickers in the rear of the double cab. I bought everything from Crutchfield. My first amp was DOA and when the replacement showed up, I finished everything. Night and day difference between the OEM setup. I am not an audiophile but I couldn't stand how bad the factory system was.
    I had the non-JBL with 6" screen. I could not find a used premium bezel anywhere so I ordered one from a local Toyota dealer. They said it would be at the dealer tomorrow. I paid $240ish for it. Right now, I am running around without the bezel.
    One thing I did that I didn't see anywhere in this thread (unless I missed it) was instead of drilling the bottom hole in lower part of the OEM bracket, I made a slot so I could more precisely move the face plate on an arc and more importantly, in case I messed up the drilling of the hole. I made the slot with a Milwaukee grinder and a cut off wheel.
  15. Mar 29, 2022 at 5:20 PM
    #1735
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Solid first post. Welcome to TW
  16. Mar 29, 2022 at 5:32 PM
    #1736
    TA-5650
    TA-5650 Well-Known Member
    Wilmington, DE
    2017 TRD OR DCSB, Blazing Blue Pearl
    Looks like firmware version 3.0 is out. Anybody have any luck or notice major changes?
    shacol likes this.
  17. Mar 30, 2022 at 11:00 AM
    #1737
    shacol
    shacol Well-Known Member
    Florida
    2018 Offroad DCSB
  18. Mar 30, 2022 at 11:06 AM
    #1738
    yunro2
    yunro2 Member
    Atlanta
    2021 SR5 Silver Metallic
  19. Mar 30, 2022 at 11:19 AM
    #1739
    TA-5650
    Wilmington, DE
  20. Mar 30, 2022 at 11:29 AM
    #1740
    shacol
    Florida
    2018 Offroad DCSB
