New pop up camper? Topo Toppers
Discussion in 'Tonneau Covers, Caps and Shells' started by mud, May 27, 2021.
  1. Mar 3, 2025 at 8:23 AM
    #521
    blackZEBRA
    blackZEBRA Well-Known Member
    California
    '23 TRD OR DCLB
    Exactly.
    I figured having one that has a "hatch" is easier to handle then a solid panel in terms of getting in-and-out.
    I thought about doing this last year but I'm just a bit lazy hah
  2. Mar 3, 2025 at 8:24 AM
    #522
    lamjam
    lamjam Well-Known Member
    Los Angeles
    2021 TRD Off road 4x4
    I’m cheap. I think that’s the only option I’m getting
    blackZEBRA[QUOTED] likes this.
  3. Mar 3, 2025 at 8:27 AM
    #523
    blackZEBRA
    California
    '23 TRD OR DCLB
    TBH, If I could do it again, it would not get the side windows because I keep them covered 24/7 with curtains. I'm hardly hanging out inside the camper at night and when I do, you can't really see anything out side because its dark (unless you install exterior lights).
    L-Tracks on the roof - I haven't used them yet. I planned to install rigid solar panels, but I think I would get flexible instead and use the L-tracks for a weBoost and ham/ GMRS antenna. But being lazy, I haven't done any of that yet hah.
    Tronfunkblow likes this.
  4. Mar 3, 2025 at 8:42 AM
    #524
    Tronfunkblow
    Tronfunkblow Well-Known Member
    California
    2017 DCLB TRD OFF-ROAD 4x4
    MT64s, Icon RXT Leaf Springs, Topo Topper
    That's correct, it closes it off. In my case I was talking with them about getting one since my toddler sleeps up top and flops around enough to make me nervous. It also means you can slide the mattress back a bit and keep your feet out of the wedge.
    lamjam[QUOTED] and blackZEBRA like this.
  5. Mar 3, 2025 at 8:43 AM
    #525
    blackZEBRA
    California
    '23 TRD OR DCLB
    Do you find it a bit cumbersome when its come to go back down in the morning?
  6. Mar 3, 2025 at 8:47 AM
    #526
    Tronfunkblow
    California
    I made one out of plywood to see if I liked it before committing the cost, but yes its kind of a pain to slide it out and move it. I've just accepted the battle for the better sleep. If I don't have my son with me it stays at home.
  7. Mar 3, 2025 at 3:32 PM
    #527
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    It’s pulled off, my fiancee convinced me to keep it for trips. We’re trying to buy a place in OC.
  8. Mar 11, 2025 at 12:22 AM
    #528
    socalexpeditions
    100% waterproofed. I nailed the interior design and had Terra Quest do the labor.
    MJonaGS32, WheelinDev, 974rnr and 4 others like this.
  9. Mar 11, 2025 at 7:57 AM
    #529
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Looks great, how is it mounted to the truck? Also, how is the mattress?
  10. Mar 11, 2025 at 8:00 AM
    #530
    socalexpeditions
    Attached to base plate, attached to bed rails. Mattress is 5x better than my Mesa, I finally don’t need a mattress topper and don’t bottom out.
  11. Mar 11, 2025 at 8:26 AM
    #531
    Tronfunkblow
    California
    I have the new mattress in my mesa, its not too bad at all, side sleepers can finally sleep. The design looks great, having all the drawers accessible from within the truck is clutch, what's the base plate coated with, photos make it look textured?
    What did you do to waterproof? I did everything I could on my mesa and still have a corner leak.
  12. Mar 11, 2025 at 9:25 AM
    #532
    czukie
    czukie Well-Known Member
    Colorado
    ‘23 Tacoma Access Cab
    Anyone have a photo of factory installed fan?
    I just bought a used Mesa and looking to put a fan-tactic fan (or other option, still deciding) in it, but trying to figure out spacing since the roof is 1/8” and I’m assuming I’ll need some sort of spacer to make it work?
  13. Mar 11, 2025 at 9:56 AM
    #533
    Tronfunkblow
    California
    I don't have a fan but want to install, let us know how the install goes.
  14. Mar 11, 2025 at 10:04 AM
    #534
    czukie
    Colorado
    Still a couple months away. Just gameplanning away. In the what-can-I-have-my-friend-3D-print-for-me stage. Was thinking the spacer for fan would qualify.
    Tronfunkblow[QUOTED] likes this.
  15. Mar 11, 2025 at 10:59 AM
    #535
    TheTacomaInn
    TheTacomaInn Well-Known Member
    Rob
    Littleton, CO
    17 OR Access Cab, OME 887,HD Dakars, 285s
    My buddy has a Badlander with the fan installed from Topo and they used a wood spacer (at least it looks wood). Ill have my buddy snag a picture next time its popped.
    czukie[QUOTED] likes this.
  16. Mar 18, 2025 at 9:05 AM
    #536
    czukie
    Colorado
    Anyone alter their bed panel(s)/platform to make it on gas struts so that it lifts out of the way? I’ve seen it done on Vagabonds, which use essentially identical bed panels.
    blackZEBRA likes this.
  17. Mar 18, 2025 at 9:08 AM
    #537
    blackZEBRA
    California
    '23 TRD OR DCLB
    No but I thought about making it so the two panels attach to one another and then make them hook up to the ceiling or something. would be nice to have easy access to open bed space without moving panels on top of each other over bedding
  18. Mar 18, 2025 at 9:20 AM
    #538
    Tronfunkblow
    California
    I saw this video when looking at build out ideas. Looks like he removed the two panels and built a single panel.
  19. Mar 18, 2025 at 9:21 AM
    #539
    czukie
    Colorado
    If I don’t get any hits on my post by the weekend I’ll be making one out of some scrap 3/4” plywood as a temp solution. If it turns out pretty well I might keep it and post results on here. I have the gas struts, just need some hinges to keep it in place.
  20. Mar 18, 2025 at 9:23 AM
    #540
    blackZEBRA
    California
    '23 TRD OR DCLB
    Struts method will be awsome compared to the hook and chain method. It'll look cleaner too.
    if its easy to do, I'd be interested in a parts list. I think attaching the two current panels would be best for me since I wouldnt have any use for those panels if i didn't have them in the truck.
