New power outlet upgrade cord
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mr.Gadget, Mar 15, 2014.
  1. Mar 15, 2014 at 4:47 PM
    Mr.Gadget
    Mr.Gadget [OP] Well-Known Member
    NC
    2011 DC 4x4 SR5 SB/2012 DC 4x4 SR5 LB(sold)
    So I got around to doing my power outlet/power cord upgrade today when doing an oil change today.
    I know there are a bunch of different ways but I wanted something a little different, easy to add, and has a bunch of different uses.
    Got some links to the parts and types of parts I used.
    What I did was used the ring terminal that hooks to the battery and then comes back to the cab. At that point the terminal hooks to the cord(12'), and drops down to the frame rail and follows the frame down to the point of the drivers seat.
    On the outside of the frame the under the seat is a rubber grommet with wires going into the cab.
    I pulled the sill trim off the drivers side and could see the grommet, I poked a small hole and fed the cord into the cab at the grommet used a wire to feed the cord under the carpet to the hole in the carpet center of the drivers seat.
    Everything back in place the wire is tucked under the drivers seat easy to get to. About 4 feet of wire total.
    What this does is gives me a port to charge anything or run anything from any seat in the truck. So someone setting in the back seat can charge a phone or pad. You can plug any of the extras to it, the USB port, Lighter port for older type stuff, even a volt meter to check the charge of the battery if you are not running the truck.
    Under the hood you also can unplug the cord and plug up anything.
    I have lights with that plug, the lighter, USB all the same stuff you use in the cab.
    It can also be used to solar charge the truck if needed when you are charging stuff for longer times and not running the truck like camping.
    I plug up the solar charger to the cord and set it on the bed cover. Then unplug and use the USB to charge the phone a few hrs and back to solar.
    That why when camping for a week I can charge and use the battery, it stays 100% and never run the truck.
    This is the same setup I used on an older truck, just as a kit and not cut and chop. Makes it easier to do and less time.
    I wish there was something to take pictures of but it is just a wire sticking out under the seat and all the add on stuff.
    IF you have questions let me know.
    Ring Terminal
    http://batterytender.com/products/accessories/ring-terminal-harness.html
    Cord
    http://batterytender.com/products/accessories/12-ft-extension-lead.html
    USB port
    http://batterytender.com/usb-charger-qdc.html
    Lighter outlet
    http://batterytender.com/products/accessories/female-cigarette-adapter.html
    Volt meter
    http://batterytender.com/products/accessories/digital-voltage-indicator-with-lcd-display.html
    Solar charger
    http://batterytender.com/products/solar/10-watt-solar-charger.html
  2. Apr 16, 2014 at 7:34 AM
    Erik
    Erik That smells like pure gasoline
    Erik
    Nashua, NH
    10'TRD off-road
    Shrockworks bumper+ IFS skid, 4xInnovations rock sliders, Toytec Bilstein/Eibach 5100 @ 2.5", 3" All-pro leaf pack w/Bilstein 5100, PIAA 510SMR, PIAA 1500, Python LC3 2-way Auto-start, Fog lights on w/Parking lights, ATRAC Hack, Diff breather mod
    Sub'd. I like how simple the setup is. If I used that solar charger and used my inverter with the ignition on, do you think that solar panel would keep up the charge on a sunny day? While charging phones and laptops (not heavy draw).
  3. Apr 17, 2014 at 7:57 AM
    Mr.Gadget
    NC
    Yes, no problem at all with it on the system I have.
    If you have the switch on, then you are going to be running the other stuff in the truck that runs in the back ground for say so I could not say for the switch on.
    I had a lap top plugged to mine over the past weekend and also the cell, did not run it 24-7 but a good bit and it was fine with the truck setting not running from Friday night to Sunday about 3 in the afternoon for the trip home.
  4. Apr 17, 2014 at 11:49 AM
    Erik
    Erik
    Nashua, NH
    10'TRD off-road
    Nice, that's pretty cool.
