new power steering pump issue.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Eric05774, Apr 12, 2014.
  1. Apr 12, 2014 at 4:35 PM
    Eric05774
    Eric05774 [OP] Active Member
    vermont
    99 tacoma
    Just replaced p/s pump with remain I also replaced the rack since it sprung a leak on the rack. New (aae) rack with pump,started it up sounded fine added more fluid not over filling. After several minutes started whining just like the old one. The truck is up stands and it doesn't feel like there's power steering. Any ideas please.
  2. Apr 12, 2014 at 4:40 PM
    zopperman
    zopperman LED & HID positive
    Zak
    Arlington, VA
    03 4Runner
    Lift, 32" Duratracs, sliders, LED light bar, interior LEDs, sweet tunes & sub, OBA, sliders, TRD 16" 6 spoke wheels, CB, HID spotlights, electrical mods, etc.
    did you bleed the system properly? Did you fill the reservoir with the wheel centered? sounds like you just have air in the lines
  3. Apr 12, 2014 at 4:50 PM
    Eric05774
    vermont
    99 tacoma
    I'm sure I did, atleast I did what the Haynes manual instructed. I actually had someone start the truck so I could be right there to add fluid I knew there was some air in the line.
  4. Apr 12, 2014 at 4:54 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Did you re-use the old reservoir? The internal screen could be clogged, and causing the noise.
  5. Apr 12, 2014 at 4:56 PM
    lipster
    lipster Well-Known Member
    Northern MN
    2004 ext cab 3.4 auto TRD
    License plate frame
    Clean the screen.
  6. Apr 12, 2014 at 5:19 PM
    Eric05774
    vermont
    99 tacoma
    Yeah, this reman don't come with reservoir and it was pretty bad, cleaned the he'll out of it before bolting to the pump.
  7. Apr 12, 2014 at 6:26 PM
    zopperman
    Zak
    Arlington, VA
    03 4Runner
    You used the right fluid, right? Can you describe how you bled it?
  8. Apr 12, 2014 at 8:10 PM
    lipster
    Northern MN
    License plate frame
    Can you see light thru the screen?
  9. Apr 12, 2014 at 8:58 PM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
  10. Apr 13, 2014 at 3:25 PM
    Eric05774
    vermont
    99 tacoma
    I used atf, picked up some Castro brand for foreign vehicles,meets dex III. I cleaned and cleaned the resivoir, used a small light to see inside and yes the screen was clean. I replaced the rack at the same time,the rack had fluid already in it so I figured it was just the lines that had air. Had someone start it up and poured more fluid in as it went down. Sounded fine at first after couple minutes it instantly started whining.
    Traded the pump in today for another one, cardone reman. Something else to add, when I got the first one the mounting bolt holes did not line up,there are 3 holes I only need 2. It was a bitch getting In to place,the pump I picked up today is the same way only 1 bolt hole lines up this time. Is cardone crap? I'm looking for a new one.
  11. Apr 13, 2014 at 4:58 PM
    zopperman
    Zak
    Arlington, VA
    03 4Runner
    mine is a replacement cardone. been good for 1k miles.
  12. Apr 14, 2014 at 5:46 PM
    Eric05774
    vermont
    99 tacoma
    my screen seems to be clean yet ive read some post where people tear the screen out. Would one of those inline magnetic filters on cardones website be a good option? Also looked into a brand new pump, found one for $20.00 more than what i paid for the cardone the plus side it it comes with resivoir.
  13. Apr 14, 2014 at 5:52 PM
    4banger4x4
    4banger4x4 Probably should'nt have done that.
    Eric
    Whorelando, Fl
