New Predator side steps for DC $263
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MudsweatNgearz, Oct 10, 2015.
  1. Nov 17, 2015 at 10:28 AM
    #301
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    I had planned on it, but these fukers were such a pain in the ass to put on being that some
    of the holes were off a bit so you had to twist and bend them a bit just to get it to line up so
    those bolts aren't going anywhere - ever :D
  2. Nov 17, 2015 at 10:53 AM
    #302
    l0ude0
    l0ude0 Active Member
    Fark i popped one of the bolts. I guess i dont need locktite lol. Now i need a bolt remover
  3. Nov 17, 2015 at 11:03 AM
    #303
    thefinalstraw
    thefinalstraw Well-Known Member
    2024 Underground TRD Sport 4x4 Premium
    good grief, how much did you torque it?
  4. Nov 17, 2015 at 11:54 AM
    #304
    l0ude0
    I dont have a torque wrench so as tight as roid rage can provide :D . Just a thought should i loosen the other ones ?
  5. Nov 17, 2015 at 12:01 PM
    #305
    ridez
    ridez Well-Known Member
    vancouver bc
    2016 white DCLB TRD sport with upgrade package
    OME 887s, 5100s, deaver AAL, light racing UCAs
    Try threading all the bolts and then work them in slowly. And if you have to elongate the mounts a bit I guess you have to. Make sure they go in straight. I'll see this weekend hiw they are when I throw mine on after the lift :D
  6. Nov 17, 2015 at 12:04 PM
    #306
    WSPtaco
    WSPtaco Well-Known Member
    Nick
    Vancouver, WA
    Magnetic Gray 2016 Tacoma TRD OR
    I didn't use locktite, just the washer and lock washers provided. Torqued to 15 lb/ft like the instructions said to. I found it was easier to install by barely threading the top center bolt, then the front bolt, then the top rear. The bottom rear went in, but the bottom center on each side was off.
  7. Nov 17, 2015 at 3:48 PM
    #307
    l0ude0
    Mine aligned real well surprisingly. No issues at all. Time will tell how well thr paint will hold on with the salt in south fl
  8. Nov 17, 2015 at 4:19 PM
    #308
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    Was yours a 2016 double cab ?
  9. Nov 17, 2015 at 5:28 PM
    #309
    l0ude0
  10. Nov 17, 2015 at 6:09 PM
    #310
    smugly
    Doug
    Good! I was fearing the worst, with my truck coming in 2 weeks and these things sitting in my basement just waiting.
  11. Nov 18, 2015 at 7:15 AM
    #311
    smugly
    Doug
    Did you buy one for the 16 modal year that n- fab slightly modified ,or did you buy the $300 one for the 05-15 and motify them your self? I'm asking becouse i'm curious why some people are having fitment issues and others aren't. You would think that the drilling of the rails on the truck would be automated and the drilling of the holes on the steps would be automated and always line up .
  12. Nov 18, 2015 at 7:50 AM
    #312
    Toneloc
    Toneloc Well-Known Member
    Northwest PA
    2016 DCSB 4x4 TRD OR
    Thought I'd share some pics of the factory predator tubes. I feel like I overpaid for them, but they were on the truck and everything else was configured how I wanted it.
    They are aluminum as well which I guess is a pro since I live in the Northeast with lots of road salt.
    I think they look pretty sweet.
    natefirethorn and Cmurder like this.
  13. Nov 18, 2015 at 7:52 AM
    #313
    smugly
    Doug
    They do look good on there!
  14. Nov 18, 2015 at 8:16 AM
    #314
    Trdtoma
    Trdtoma Active Member
    Michigan
    2016 dc TRD orsb
    Stock AF
    got a question... do they make 2 piece steps for each side so its like 1 step for each door like the predators but into 2 pieces? so it would be 4 pieces all the way around..
  15. Nov 18, 2015 at 8:35 PM
    #315
    l0ude0
    I bought the 2016. I didnt want to cheap out for a few bucks and have to drill/modify for fitment... worse pay for return shipping for not ordering the right part.
  16. Nov 18, 2015 at 8:36 PM
    #316
    l0ude0
    Its not my business but why would you want it that way ?
  17. Nov 19, 2015 at 2:43 AM
    #317
    smugly
    Doug
    I believe they do, I have seen them on other trucks.
  18. Nov 19, 2015 at 7:33 AM
    #318
    Trdtoma
    Michigan
    2016 dc TRD orsb
    Stock AF
    I like the predator style I just don't like the whole tube behind it
  19. Nov 28, 2015 at 3:02 PM
    #319
    ToyTim
    ToyTim Well-Known Member
    2016 Tacoma Limited
    3" coil spring spacers , UCA's , Add a leaf
    I want to put N-fabs 2" wheel to wheel on my 2016 Double cab . Can someone give me a definite answer if the T0678CC [2nd gen. version] will fit without modification ? They are alot less money than the 2016 T1678CC price . If I need to modify the T0678CC , what is the procedure . I have been reading every thread here and I am still confused . Thanks in advance .
  20. Nov 28, 2015 at 3:28 PM
    #320
    smugly
    Doug
    Personally, I would spend a little extra money and get the 3 inch. Cosmetically it just looks much better on the vehicle. Don't short change yourself just because of a couple dollars
    andyr562 likes this.
