New problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tntacoma, Dec 13, 2011.
  1. Dec 13, 2011 at 12:15 PM
    tntacoma
    tntacoma [OP] Well-Known Member
    tn
    Just in the last couple of days, I noticed when I am turning my steering wheel I hear a winding spring kinda noise. That is the only way I know how to describe it. Anyone have any suggestions to what this may be?
    Thanks in advance.
  2. Dec 13, 2011 at 12:22 PM
    jeremy_283
    jeremy_283 Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    Could you describe the noise? :spy:
    but seriously, what noise does a spring make?
  3. Dec 14, 2011 at 5:17 AM
    tntacoma
    tn
    Ha, I understand that was a bad description, but I am not sure how else to describe it. if you compress a spring in a flashlight or other device it makes a sound. almost like your winding something up? I don't know.
  4. Dec 14, 2011 at 5:23 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Do you mean like an old screen door spring when it streches out kind of noise?
  5. Dec 14, 2011 at 5:28 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I know exactly what noise your talking about. My truck doesn't make it, but my Dad's F150 does. I'm not really sure what causes it. I figure it's the two plastic components on the back of the wheel assembly that rotate on each other.
  6. Dec 14, 2011 at 5:47 AM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Selkirk, NY
    4x4 reg cab, 5 speed
    Better tires Hurcules Terra Track, trimmed front mud flaps, (access limited tonneau-took off) softopper, ats running boards, Piaa fogs, window vents, Wireless thermometer, extra bed rings, valley hitch
    My old car did that when it was cold when starting up sometimes. I think it was plastic between the steering when turning.
  7. Dec 14, 2011 at 6:02 AM
    tntacoma
    tn
    <<<<< Nailed it, I knew someone would know what I was talking about.
  8. Dec 14, 2011 at 7:40 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    LOL, I nailed the sound, but I have no idea what it is. Hope that helps people figure it out of you though!
  9. Dec 14, 2011 at 7:55 AM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Flagstaff, AZ/Walnut, CA
    2005 Tacoma Prerunner SR5 TRD offroad
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Does it sound like the winding sound when you crank a flashlight?
  10. Dec 14, 2011 at 7:57 AM
    NicNac22
    NicNac22 D.I.L.L.I.G.A.F
    Nic
    Wild and Wonderful
    95 V6 4x4 ex cab SR5 5sp PICKUP!!!
    fun stuff coming soon! New battery, radiator and CV joints and axles. Added some Rancho RS5000 shocks.
    does it do it on a full turn or half turn?
    checked your fluid lately?
  11. Dec 14, 2011 at 6:12 PM
    USAONE
    USAONE Well-Known Member
    2011 DC Tacoma Prerunner SR5
    Stock
    Normal, some type of actuator device.
  12. Dec 15, 2011 at 7:31 AM
    tntacoma
    tn
    This sound is actually coming form the steering wheel itself not the front end. An earlier reply nailed it as far as sound. It sounds like a spring on a screen door when you open it. I turn the wheel all the way left or right and I get the sound. Like it is coming from the space in between the steering wheel and the housing around the steering column.
