New Product AEM "Short Ram Intake" 2005-2015 4.0 v6 CARB LEGAL 22-681C
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kyleTRDtaco12, Jun 14, 2015.
  1. Jun 14, 2015 at 6:41 PM
    kyleTRDtaco12
    kyleTRDtaco12 [OP] Well-Known Member
    Kyle
    New Jersey
    2012 Toyota Tacoma Base DCSB 4x4 V6 6MT (202)
    TRD Cat-Back Exhaust TRD Sport Package Springs & Shocks (Front Linear Coil Springs, Rear TSB Leafs) Front & Rear Toyota/Bilstein 40mm Shocks) Silver Toyota 16" SR5 Wheels with 265/70/16 BFGoodrich Rugged Trail T/A Tires w/ Locks OEM Black-Chrome Housed Headlights (SR package) OEM TRDpro Grille Insert RokBlokz Rally MudFlaps w/ Stamped Logo OEM 'TRD Sport' Bedside Graphics TRD QuickShifter w/ TRD Shift Knob Hawk HPS Front Brake Pads w/ Brembo Blank Rotors OEM Front Aluminum Skid-Plate eBay TRD seat covers Rear Diff. Breather Mod A/C Drain Extension Mod OEM Fog Light Kit OEM Intermittent Wiper Switch OEM Bed D-Rings OEM Bed Mat OEM Door Sill Protectors Blacked-Out Badges (from Xrunner 205 Black Sand Pearl) Pop & Lock Tailgate Handle TruXedo TruXsport Roll-Up Tonneau Cover AVS BugFlector II Front Bug Guard AVS In-Channel Window Vent Visors TRD High Pressure Radiator Cap Stubby Radio Antenna Ultra-Gauge EM v1.2 w/ Windshield Mount BullaCulla 7-Pin Relocation Bracket Misc. Stickers
    Hey everyone, whats up?? AEM apparently, back in march, made an awesome CARB legal intake for our trucks. Us people who have a 2012 and newer tacoma, v6's in particular, probably are familiar with the struggle of finding any intake that is carb legal since the TRD one does not fit our trucks and every other cold air intake eliminates the hydrocarbon filter that makes the stock intake carb compliant. All this kit consists of is a nice mandrel bent induction tube, a 90 degree bend pipe and most importantly an airflow accelerator bell thats very similar in design to the TRD cold air intake. The kit also includes an AEM high flow dry flowing air filter (but you can run any replacement filter you please, im currently running toyotas TRD high flow air filter) It's a nice little upgrade, it makes alittle more induction noise because the intake resonator is gone and throttle response is slightly better in the mid range because the tube is larger and has smoother bends. I think its a fantastic product and priced nicely. The AEM part number is 22-681C and heres an EBAY item number for those whod like to see what it looks like and who may want to buy one, cheers everyone! :)
    191571095134 <-- just search this item number on ebay and it'll pop up.
  2. Jun 14, 2015 at 7:31 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    uses stock airbox..... filter probably filters less than OEM filter.... you get no gains and worse filtering.
    Any "gains" you get are simply placebo, the "better airflow" you think your getting due to the smoother bends etc, are completely negated by the fact that those bends are before the filter / airbox. The tube itself is no bigger than stock, and infact there probably isnt much noise increase as the resonator is part of the stock airbox which is still used. Its a waste of 271 bucks. Unless your into spending that much money on looks alone.
    And in fact this probably REDUCES performance due to the fact its a metal pipe that conducts engine bay heat better increasing air intake temps vs the stock plastic tube.
  3. Jun 14, 2015 at 8:25 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    Um ok... You don't have to jump down my throat buddy. But I thought this was a decent upgrade, especially for people who just want something nice under the hood and for those like myself who are stuck with having to be carb compliant. The metal tube vs plastic is a long proven invalid argument because plastic gets hot too. If you don't like it, or don't want it, you don't have to buy, but you don't need to squat down and take a shart in the thread. But its half the price of non carb approved cold air intakes and does just fine.. Nothing more, nothing less. And of course it filters alittle less, how else will more air get through in any performance filter?? And on the hot days where I live ive actually seen grams per second increase and intake charge degrees lower on my ultraguage when compaired to the stock. And since it still uses the stock box there is plenty of engine protection.. And the intake resonator on the stock tube is part of the intake tube, its on the part of the tube that is nearest to the fender.
  4. Jun 14, 2015 at 8:31 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    That thing is total junk. Are you the ebay seller? Lol
    Unchained 5150 likes this.
  5. Jun 14, 2015 at 8:32 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    Nope, although it'd be awesome to work for summit racing equipment. just thought id share some product information for those of us burdened by the California air research board.
  6. Jun 14, 2015 at 8:35 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    The burden is easy to overcome, just switch to stock before smog check.
    :wink:
    Lord Helmet likes this.
  7. Jun 14, 2015 at 8:36 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    And then have to wait for a drive cycle for all of the readiness monitors to work. Personally I would rather not do that. But thats just me.
  8. Jun 14, 2015 at 8:40 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Nah you're not resetting the ecu when switching intakes. Drive cycle monitoring wont change.
  9. Jun 14, 2015 at 8:45 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    It still may not have the correct a/f ratios. It's usually beneficial to disconnect the bettery and start the fuel trims from a blank slate. It's more precise over time. Thats what I was taught at universal technical institute anyway.
  10. Jun 14, 2015 at 9:11 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Your posts sound a little too salesman.
    AEM sucks, regardless.
    Unchained 5150 and Arailt like this.
  11. Jun 14, 2015 at 9:22 PM
    nd4spdbh
    SoCal
    i bet if you actually did some tests the difference would literally be nothing between the stock unit and this..... yet your 271 bucks less rich. To each their own... but this is nothing more than a pretty piece of pipe to replace the same sized plastic piece of pipe of the stock intake.
  12. Jun 14, 2015 at 9:32 PM
    nd4spdbh
    SoCal
    OP did
  13. Jun 14, 2015 at 9:36 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Shots fired
  14. Jun 14, 2015 at 9:56 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    *facepalm* you know aem and k&n are the same company, right??? I'll never understand this forum, so many negative comments quite literally all of the time. You people really are funny. If you think im a salesman, please take time out of your lives to look through my posts. I'm no salesman, just an enthusiastic enthusiast. Its honestly sickening how much hate enthusiasts of the same vehicle give each other on here. Same team people. I know intakes arent the most 'popular' subject in the automotive community as a whole , but I personally thought this was an ok upgrade and that it was kinda smart on aem's part, although when buying this I knew it was only going to be engine dressup anyway. *smh* the info is here for anyone who wishes to utilize it. Have a good night.
  15. Jun 14, 2015 at 10:18 PM
    evansb2
    evansb2 Well-Known Member
    Evans
    LA, CA
    Yeah, and exhausts blow.
  16. Jun 15, 2015 at 9:21 AM
    T4RFTMFW
    K&N sucks too. Happy?
  17. Jun 15, 2015 at 10:54 AM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Man a lot hate on this thread.
  18. Jun 15, 2015 at 11:03 AM
    VolcomTacoma
    Jeff
    NorCal
    Ok so firstly,
    It's not a "Ram air" as the title states, let's not confuse people.
    And secondly, the only thing that's really getting effected is the filter change. The tubing is purely cosmetic. You can sit he re and argue both sides of plastic vs metal, but in the end it's still thin tubing in the engine bay
    Arailt likes this.
  19. Jun 15, 2015 at 11:35 AM
    VolcomTacoma
    Jeff
    NorCal
    Yea but doesn't the stock intake have more of a smoother bend whereas this one has a solid 90
  20. Jun 15, 2015 at 11:39 AM
    VolcomTacoma
    Jeff
    NorCal
    I found it quite pleasurable
    Lord Helmet and T4RFTMFW like this.
