New Product Release: 05-15 Tacoma 1 inch body lift kits!
Discussion in 'Toytec Lifts' started by Toytec Lifts, May 11, 2015.
  1. Jul 9, 2015 at 7:56 AM
    ArMarine04
    ArMarine04 Well-Known Member
    Alan
    Beaufort, SC
    Well then I don't suppose this product would be for you know would it
    eccracer104 and ChadsPride like this.
  2. Jul 10, 2015 at 10:40 AM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    Nope, you are supposing correctly...unless i wanted to relocate my bumper.
    ChadsPride likes this.
  3. Aug 21, 2015 at 1:11 PM
    MagTaco24
    MagTaco24 Member
    2015 tacoma sport
    3" suspension lift, 17" ballistic wizard rims, Westin brushguard, 32" tires, +smaller detailed mods
    Will it put a 1" gap on my front bumper too?
  4. Aug 21, 2015 at 1:44 PM
    ArMarine04
    Alan
    Beaufort, SC
    That is an excellent question my friend, you can see the small space on the close up side shot on my off road bumper where the tube is about an inch under the headlight and quarter panel... It's an aftermarket bumper so you prolly wouldn't know it wasn't suppose to have that gap without me telling you
    Idk how the stock front bumper would fit against the body with the body lift but the kit doesn't have any parts to relocate the front stock bumper which would lead me to believe you would have a gap :-/
  5. Aug 21, 2015 at 1:47 PM
    MagTaco24
    MagTaco24 Member
    2015 tacoma sport
    Ahh okay, it would be a definite buy for me if I could get the bumpers back to stock
  6. Jan 15, 2016 at 3:22 PM
    Mcdees84
    Mcdees84 Well-Known Member
    Tallahassee, FL
    2014 MGM DCSB-TRD O/R
    I did a 1" body with stock bumpers (wasn't from Toytec, but 1" is 1"). The front bumper is actually pretty hard to tell at all. There is a little difference, but no one notices it. The back is obvious, but like said earlier by Toytec, it does not look bad. I've since put a rear plate bumper on and the gap still doesn't bother me enough to start welding. If I can think of an easier fix I may try to fill that gap a little, but its not going to cause me to lose sleep at night.
  7. Mar 13, 2016 at 7:32 PM
    dtay4197
    dtay4197 Well-Known Member
    Dustin
    silver 2007 trd offroad
    2.5 bilstiens, colormorph retrofit halos and fogs, urd maf cal, Urd tcai, 20x12 mo962, 33x12.50x20 iron man mts
    I know this post is a little old but does this setup require any extensions and does it make the ride quality rough? Or is it about the same? Thanks.
  8. Jun 6, 2016 at 3:07 PM
    Mcdees84
    Tallahassee, FL
    This won't affect ride quality at all. And at 1" you don't need any extensions for steering shaft and as stated earlier in the thread, brake lines follow the suspension, not the frame, so you'll be fine there as well. I did need to extend my gas cap filler, but this kit may come with that.
  9. Jun 7, 2016 at 4:17 AM
    Telkins88
    Telkins88 Well-Known Member
    Ohio
    2011 TRD Sport 4x4 JBL
    Radflo extended travel 2.5 coilovers, Bilstein 5100 B110's and Headstrong Offroad progressive add-a-leafs on TSB springs, Custom Rear Bumpstops, Revtek diff. drop, OME driveline drop, Camburg Ball Joint Upper Control Arms, CMC, Black Badges/ Emblem, Black TRD Sport Bed Decals, Windows Tinted, Weathertech Front and Rear Floor Mats, OEM bed mat, 285/70R17 Nitto Trail Grapplers on 17x9 Fuel Hostages
    If I could figure out a way to raise my rear bumper also I have thought about this kit too. My thought was that I would lower my radflo coilovers from 3" inches to 2" and be able to get some more droop out of the front suspension and improve the ride while I'm at it.
  10. Jun 15, 2016 at 12:53 PM
    hmasonb34
    hmasonb34 Well-Known Member
    Heath
    Jax, Fl.
    98, ext cab and 2015 LB dbl cab 4x4 sport
    My 98 has 4 in.beefed blocks, QA1 up front, turbo. My 15 4x4 stock looking for lift and tires.
    First off i know this is an older thread so hopefully some of you are still around. I'm thinking of doing the 3" toytec suspension lift and the 1 inch body lift as well. Just wondering how much that helps with running bigger tires. I'm looking to run 33s If i do the combination lift of 3 and 1 could i run 33s with no cutting or trimming of my fenders or the infamous CMC or will they still be necessary? Also with some trimming could i squeeze 35's on it? All though i'm sure at that point we would be back to cutting and trimming which im no fan of but sometimes you gotta do what you gotta do.
    Any pics with tire sizes included would be great. Thanks ahead of time.
  11. Jun 15, 2016 at 1:36 PM
    skootx
    skootx Well-Known Member
    Erie, CO
    2014 Tacoma TRD Off Road Double Cab Short Bed
    Icon Stage 1 Shocks & coils Deaver AAL Light Racing UCA's PAC SNI-35 line output converters, miniDSP, Rockford Fosgate R600X5, Rockford Fosgate Punch P3 P3SD210, Helix Blue B62C speakers, HELIX Blue B5X 5 speakers G4 Elite Fold A Cover Rear Diff Breather Relocation
    I have a 3" Icon lift and am considering this body lift too. I'm running 285/75R16 and have not had to trim anything, but I did need to do the CMC. The body lift will not help with the CMC because that's part of the chassis.
  12. Jun 15, 2016 at 1:44 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I've got the energy suspension cab bushings, will this work with them? And how do the splash skirts work with the body lift?
  13. May 23, 2018 at 10:59 AM
    jmarquez808
    jmarquez808 Large Member
    Jess
    Hawaii
    07 4x2 reg cab / 12 4x4 double cab
    **Afe cold air intake w/pro dry filter, Yellow tint fogs, Daytime running lights, led dome light, led license plate lights, Led tail lights, 3 inch carbon antenna, spec d projector headlights, carbon fiber look interior trim pieces, Djm control arms, Djm notch, 4x4 leaf springs, beefed taco 2 inch blocks with offset pin, Rear Qa1 Shocks, Sittin sic stock height coils, x runner bilstein front shocks, weathertech digital fit floor mats, debadged.
    I have a 2" body lift and with the stock bunper cover the front bumper reinforcement bar does not fit properly. Its smashed on the bottom of the front bumper. I need something to raise the reinforcement bar up 2 inches. Anyone have a solution or bracket?
  14. Sep 28, 2018 at 4:57 PM
    TopKick
    TopKick Well-Known Member
    2012 Spruce Mica CrewCab TRD OR
    3" suspension 1" Body 33" A/Ts + 16" Wheels Muffler swap TRD Pro Grille
    Any more pictures of the 3" suspension 1" BL setup? Thinking about buying the BL tonight
  15. Sep 28, 2018 at 6:04 PM
    #35
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    TopKick likes this.
  16. Oct 7, 2018 at 6:02 AM
    #36
    The Field Archer
    The Field Archer Well-Known Member
    North New Jersey
    15 Tacoma Double Cab 4x4 TRD Sport
