new ps pump and STILL whining
Discussion in '1st Gen. Tacomas (1995-2004)' started by anthony250f, May 3, 2015.
  1. May 3, 2015 at 12:22 PM
    anthony250f
    anthony250f [OP] Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    i just put in a brand new ps pump it it still whines..its not nearly as bad but its still clearly there! i used atf valvoline dextron type 3
  2. May 3, 2015 at 6:05 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    Make sure you get all the air out that you can. Turn the steering wheel lock to lock several times. Drive through a neighborhood with a lot of turns.
    12TRDTacoma likes this.
  3. May 4, 2015 at 1:37 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    The screen in the reservoir, did you notice if it was clogged up?
  4. May 4, 2015 at 12:07 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    This.
    PS pumps usually come without the reservoir. The clogged screen is what, many times, causes the whining, not the pump itself.
  5. May 4, 2015 at 4:16 PM
    anthony250f
    Anthony
    San Diego, CA
    It's much better now ....yeah I have cleaned the screen two times...I could see though it but there was a little debree
  6. May 4, 2015 at 4:20 PM
    doyouevenprerun
    doyouevenprerun Well-Known Member
    Jake from state farm
    Gilbert, AZ
    02 TuRD
    just got a simple lift on her
    that screen needs to be perfectly clean.
    i had to drain and refil my PS fluid like 10 times to get all the crap out of it and THEN i could clean my screen and it would actually stay clean....
    everytime i would clean it, it would get clogged again in a day or 2, so i had to fill and drain a bunch for it to stop. it sucked.
  7. May 4, 2015 at 5:03 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    this is great info many will benefit from, lots of times people don't realize how much crap circulates through that system and flushing and replacing fluid doesn't always get it all out.
  8. May 4, 2015 at 8:47 PM
    anthony250f
    Anthony
    San Diego, CA
    Damn I seriously spent hours cleaning it..high pressure water cleaners flushing with a whole bottle of atf...the fluid came out very easy...it's super quite now but has a little noise backing up and turning the wheel
  9. May 5, 2015 at 9:26 AM
    doyouevenprerun
    Gilbert, AZ
    02 TuRD
    well maybe it's the pump then.... is it brand new or used?
    what i would do is just remove the lines from the rack and see if the fluid is dirty while it is draining. if it's dirty, drain, refill, drive, drain and refill. if it is not dirty, then i don't know..
  10. May 5, 2015 at 10:22 AM
    tan4x4
    Rick
    Folsom, CA
    Do you have 3 belts, or one serpentine belt?
  11. May 5, 2015 at 10:23 AM
    anthony250f
    Anthony
    San Diego, CA
    Pump is brand new...I've already removed that line and out 100% new fluid In the entire thing...it's so quite now that I'm just gonna leave it...it was screaming before so I'm happy enough
  12. May 5, 2015 at 10:23 AM
    anthony250f
    Anthony
    San Diego, CA
  13. May 5, 2015 at 11:02 AM
    doyouevenprerun
    Gilbert, AZ
    02 TuRD
    but have you only removed that line one time drained and refilled?
    and this is where you are now?
    if so, you need to do that about 5 more times.
  14. May 21, 2015 at 7:28 AM
    anthony250f
    Anthony
    San Diego, CA
    You think that will do it ? I'll give it a shot...maybe change to a diff brant aft fluid ??
  15. May 21, 2015 at 9:08 AM
    doyouevenprerun
    Gilbert, AZ
    02 TuRD
    i really think it will help, and make sure your screen is clean after.
    i am serious, i had to flush mine like 9 times to get all the shit out. (i blew the gears in my prior pump), the fluid was completely metallic even after draining and refilling 4 times, not shitting you. and it took a ton of times to actually get the fluid clean. it is pretty stupid. but if you dont do that the screen will keep getting clogged and it will continue to whine.
    or your pump could just be bad and you would do all this for nothing.
    But thats my experiences.
  16. May 21, 2015 at 10:37 AM
    anthony250f
    Anthony
    San Diego, CA
    I've cleaned the screen so much.?i wish I just cut it out
  17. Jun 8, 2015 at 9:19 PM
    anthony250f
    Anthony
    San Diego, CA
    Ok so they are sending me a new ps pump for free...in thinking this time a diff brand fluid and punching out the metal screen in the resi? Is that possible?
  18. Jun 9, 2015 at 8:25 AM
    keakar
    karl
    louisiana
    no, don't go punching out the screen, geez, its there to filter the fluid so it protects the pump and steering rack from contaminants that make seals leak and parts wear out.
    just take the time to properly clean the screen out, and flush all the crap out of the system. the screen is doing its job as it was intended and the cup comes out in your hand so you can blast it from the bottom side with spray cleaners to clean it then flush the crap outta the reservoir cup itself so it is all clean then everything is like new again.
    punching out the screen is just lazy and wreckless and it WILL do harm the system over a long period of time but often you can get away with it if you are lucky but remember you are taking a risk on ruining your steering rack by punching the screen out
    12TRDTacoma and koditten like this.
  19. Jun 9, 2015 at 1:04 PM
    anthony250f
    Anthony
    San Diego, CA
    I really don't think its the screen though. I've cleaned it multiple times and fluid poorr a steady streAm out of the resi so its not stopping up the fluid.... I know the pumps don't like 35s but jeez. Two of my friends are running ps fluid in these pumps, I have valvoline atf and I'm thinking of using a diff atf and flushing it AGAIN at the rack
  20. Jun 9, 2015 at 1:47 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Check to see if one of your pulleys are frozen, my AC pulley froze and screamed like a MF'er, driving on the way home and my belt snapped and it went away. Replaced the pulley and belt, hasn't been a problem since :notusre:
