NEW RADIATOR FILL AND BLEED
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rockinrich, Feb 15, 2022.
  1. Feb 16, 2022 at 11:49 AM
    #41
    OldTacoDD
    OldTacoDD current brain has check engine light on
    PNW
    2002 3.4L V6 SR5
    When you first fire it up it will draw from the tank but it will flow back in when engine is at operating temp. When it's stoopid hot outside and your sitting in traffic, you may smell the fluid. Don't freak out, that's the excess expansion back to the reservoir and out via the black tube that runs down the side of it. No need to replace any unless it doesn't stop leaking...which means you have a different problem.
  2. Feb 16, 2022 at 11:49 AM
    #42
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    a couple o flushes in Ur driveway wont hurt a thing
    fill run to hot then drain
    garden hose water aint that bad that a 5min flush will contaminate
    there are areas in an engine where flow is slight
    even when needle is straight up there are wide variances inside the engine
  3. Feb 16, 2022 at 11:53 AM
    #43
    rockinrich
    rockinrich [OP] Well-Known Member
    davidstacoma[QUOTED] likes this.
  4. Feb 16, 2022 at 11:54 AM
    #44
    rockinrich
    right on sounds right.
  5. Feb 16, 2022 at 11:54 AM
    #45
    TacoTuesday1
    FL
    Writing an extremely in-depth instructional:
    use a vacuum filler tool
  6. Feb 16, 2022 at 11:55 AM
    #46
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    haha i don’t know what truck you have but this is mine.
  7. Feb 16, 2022 at 12:01 PM
    #47
    OldTacoDD
    PNW
    2002 3.4L V6 SR5
    Coolant is expensive enough, no need to drop $50-$200 on the kit which most people think they need.
    Unless you can dyno 500+rwhp or more there isn't a need for a special filler or kit.
  8. Feb 16, 2022 at 12:10 PM
    #48
    rockinrich
    I have an 07 tacoma base model used to drive it to work every day and have about 280,000 miles on it!
    OldTacoDD likes this.
  9. Feb 16, 2022 at 1:37 PM
    #49
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I disagree with this. Universal coolants like SuperTech, Peak, Prestone, etc… are just fine to replace the overpriced corporate antifreezes. Just follow the directions of the antifreeze manufacturer for correct usage. I have never used Toyota branded antifreezes/coolants in any of my Toyota/Lexus vehicles, ever. Their main requirement is that the antifreeze not contain silicates.
  10. Feb 16, 2022 at 2:10 PM
    #50
    TacoTuesday1
    FL
    people don’t “think they need”
    Warranties, repair manuals, shops, and factories require it, whether a car has 300hp or 100hp
    or if you want to do it the wrong way that works too
    Might add some spice and fun to the experience instead of the boringness that comes with doing something properly the first time and having no issues and having no doubts about if it worked
    colin1qk likes this.
  11. Feb 16, 2022 at 5:50 PM
    #51
    rockinrich
    let me ask another question,my truck holds 9.1 quarts of fluid now when i do a flush with say 2 gallons of distilled water or 8 quarts and when i drain it i get about 2 gallons out which is 8 quarts does that mean that there is still 1.1 quarts in the block?Also is it necessary to get that out as well?
  12. Feb 16, 2022 at 5:59 PM
    #52
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    The drain plug on the right side (PS) is easy to get to and will drain 90% of the block. Remember in an early post what I said about the left drain.
    If it was my truck, I'd drain the block and make it your truck.
  13. Feb 16, 2022 at 6:03 PM
    #53
    rockinrich
    Thank you,so don't even bother with the left side but is it easy to spot on the right side?
  14. Feb 16, 2022 at 6:10 PM
    #54
    OldTacoDD
    PNW
    2002 3.4L V6 SR5
    There is still some in the block unless you left the old radiator and hoses off for a day or two, not a fan of that unless you have a tight, dry shop. That's why you fill gradually, run and fill again.
  15. Feb 16, 2022 at 6:26 PM
    #55
    rockinrich
    well the reason for the new radiator is because i got in a wreck and it thrashed my old one and so the old one was taken out over a week ago while we worked on pounding the rad support back into shape and test fitting other pieces.So maybe i'll open up the petcock once i find it and see if it drains anything?
  16. Feb 16, 2022 at 6:34 PM
    #56
    BlkDakDave
    David
    CC TX
    After the second time of putting in new coolant and opening/draining both the PS/DS plugs, the time and hassle to drain the DS ain't worth the time. And going by your posts we'll keep everything accessible.
  17. Feb 16, 2022 at 6:41 PM
    #57
    OldTacoDD
    PNW
    2002 3.4L V6 SR5
    Glad to hear you tried to rescue the support and tested other fittings. It means you aren't afraid of throwing the dice and learning along the way.
    If it sat that long then you put the new rad in, going for the right side drain plug isn't a bad option, if nothing comes out you can try the petcock but it will most likely be dry too.
    Just fill gradually and keep an eye on the rpms and idiot gauge.
  18. Feb 16, 2022 at 6:54 PM
    #58
    rockinrich
    ok so just look at the right side plug and don't worry about the left side?what does ps/ds stand for lol?
  19. Feb 16, 2022 at 6:57 PM
    #59
    rockinrich
    Thank you i appreciate that,yeah it wasn't too bad but did require some pounding but the bumper cover supports were trash and got new ones.So there's a drain plug and a petock?Are those easy to spot?
  20. Feb 16, 2022 at 7:00 PM
    #60
    OldTacoDD
    PNW
    2002 3.4L V6 SR5
    Passenger Side, drivers side.
    It's for those of us who are dyslexic (maybe we started it lol) since "right" and "left" leads to "your right or left? facing which way?"
