NEW RADIATOR FILL AND BLEED
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rockinrich, Feb 15, 2022.
  1. Feb 18, 2022 at 2:03 PM
    #81
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    The easiest ones to get to, it does not matter much. At least one of the heater core hoses should be opened and blown out.
    60 PSI should be fine. I don't see any harm blowing that much air through an open cooling system.
  2. Feb 18, 2022 at 2:27 PM
    #82
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    The DS block drain is a little difficult to see and get to. Please check out this thread on changing the coolant. This one is pretty straight to the point. Please read and study each post. As you may have deduced by now there are different ways or methods to do this fairly simple but important task. Take it all in and decide what you feel is best for you. My thinking is if you get 90% of fresh coolant in, your truck is better off than it was. Just saying...
    https://www.tacomaworld.com/threads/v6-antifreeze-coolant-change-how-to.657479/
  3. Feb 18, 2022 at 3:07 PM
    #83
    rockinrich
    rockinrich [OP] Well-Known Member
    but if you take one off where does the debris if any exit?
  4. Feb 18, 2022 at 3:08 PM
    #84
    rockinrich
    I'm beginning to wonder if my truck has one on the drivers side i can not find that mf'er
  5. Feb 18, 2022 at 3:13 PM
    #85
    BlkDakDave
    David
    CC TX
  6. Feb 18, 2022 at 3:14 PM
    #86
    rockinrich
  7. Feb 18, 2022 at 3:16 PM
    #87
    BlkDakDave
    David
    CC TX
    That may be the reason. Honestly, I do not know if the 2.7 has the left block drain. And what year is your truck?
  8. Feb 18, 2022 at 3:17 PM
    #88
    rockinrich
    BlkDakDave[QUOTED] likes this.
  9. Feb 18, 2022 at 3:26 PM
    #89
    rockinrich
    in this thread titled "
    2.7 L engine block coolant drain pics g17 guy says there's only 1 on the 2.7
  10. Feb 18, 2022 at 3:30 PM
    #90
    BlkDakDave
    David
    CC TX
    That seems to be the consensus on what I finding also.
  11. Feb 18, 2022 at 3:33 PM
    #91
    rockinrich
    oh really? i guess i'll go with that.what are your thoughts on opening up the heater core hose or hoses?when i flush distilled water inside and the thermostat opens wont it flush the heater core out?
  12. Feb 18, 2022 at 4:08 PM
    #92
    BlkDakDave
    David
    CC TX
    I thought of doing the heater core flush. Heard about the possibility of stirring up debris if you don't flush the right way. In through the inlet and out through the outlet.
    If it was me I'd keep it simple. Yes, doing a distilled water flush will circulate through the heater core. Once the T-stat is open turn the heater on and fan on high. You could even drive the truck around the block. IMO - A good couple of flushes with distilled water will do the trick.
    As I said in post #82, My thinking is if you get 90% of fresh coolant in, your truck is better off than it was. Just saying...
    BTW-all you need to do with that block drain bolt is loosen it and watch the flow that comes out of the drain just below the bolt.
  13. Feb 18, 2022 at 4:25 PM
    #93
    rockinrich
    how do i know which one is the inlet?Also if there is debris in the heater core and i spray hose water into the inlet is it sending the debris into my new radiator?
  14. Feb 18, 2022 at 4:31 PM
    #94
    rockinrich
    Also i saw a video where a guy took off both hoses and ran water through both inlet and outlet on the firewall,thoughts?
  15. Feb 18, 2022 at 4:45 PM
    #95
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    At work I pull both hoses, flush the heater core both ways with a garden hose, reinstall, and top off the coolant, if flushing the whole system I pull the heater hoses and lower rad hose and backflush it through the heater hoses.
    Tacoma's have block drains so you can open them while your flushing, when your done let everything drain and refill with antifreeze and distillled water.
  16. Feb 18, 2022 at 4:49 PM
    #96
    rockinrich
    when you backflush it do you pour water in both hoses?
  17. Feb 18, 2022 at 4:51 PM
    #97
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I use a garden hose and flush through everything in both directions, unless your cooling system is severely neglected there shouldn't be much sedement to flush out.
  18. Feb 18, 2022 at 4:54 PM
    #98
    rockinrich
    ok cool i only have one block drain so ill open that along with the rad drain.
  19. Feb 18, 2022 at 5:40 PM
    #99
    BlkDakDave
    David
    CC TX
    If both your lower and upper heater hoses are disconnected (DC) I would think you don't need to worry about the block drain, because you are limiting the heater core flush to just that. I would however with everything buttoned up and do a final flush.
    What @Dm93 said; "unless your cooling system is severely neglected there shouldn't be much sedement to flush out." Kind of like a transmision. Should I do a flush or a drain and fill?
    It's your call.
  20. Feb 18, 2022 at 6:03 PM
    #100
    rockinrich
    He said just take the lower rad hose off so then i would need the drains open right?yes after i do this flush then i will button things up and flush it with the distilled water then do the coolant and be done with it!Also i have never done a flush on this truck so i think it's way overdue.
