NEW RADIATOR FILL AND BLEED
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rockinrich, Feb 15, 2022.
  1. Feb 18, 2022 at 6:09 PM
    #101
    rockinrich
    rockinrich [OP] Well-Known Member
    I finally got those heater hoses off,what a b*tch those were lol it got dark on me so i'll flush it in the morning.
  2. Feb 18, 2022 at 7:03 PM
    #102
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    Please look at post 95 from @Dm93 and how he flushes the heater core. By disconnecting the upper and lower heater hoses, you have isolated the heater core. Any debris in the core will "freely" flush out and will not enter into the block or radiator.
    Yes when draining the block, opening the block drain valve while removing the lower hose is like...
    when you shotgun a beer.
  3. Feb 18, 2022 at 7:14 PM
    #103
    rockinrich
    will do, but then he flushes water through the heater hoses as well and i'm assuming one direction of water will exit out the lower rad hose and the opposite will exit out the other hose?
  4. Feb 18, 2022 at 7:36 PM
    #104
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Most vehicles don't have block drains, Toyota is one of the few that do.
    I usually pull the upper and lower hose off and heater hoses (or what ever hoses are accessible) and flush through everything both ways best I can with a garden hose, it's not the ideal way to do it but it does a pretty good job of getting most of the crap out.
    Most of the garbage in the cooling system settles out in the radiator and heater core, on vehicle without block drains you can't get everything out but you can get the majority of it.
    If you change your coolant at the recommended intervals and use the correct coolant there should never be any sediment or particulates in the system to worry about flushing out, most of that stuff comes from the coolant breaking down and some coolants will even start attacking the plastic and rubber parts of the cooling system when they break down (GM Dexcool is really bad about this).
    It depends which hose the thermostat is in, I'm not sure on the 4 cyl if it's on the inlet or outlet side. It will come out of the one that doesn't have the thermostat in it.
    Like I said if you have always kept your coolant clean I wouldn't be overly concerned about going crazy flushing the block, do the heater core and the radiator, run water through the block best you can, let it all drain and fill it back up with the proper coolant/ distilled water blend.
    Total capacity is about 9 Quarts on a 4 cyl.
  5. Feb 18, 2022 at 7:50 PM
    #105
    BlkDakDave
    David
    CC TX
  6. Feb 18, 2022 at 8:11 PM
    #106
    rockinrich
    i just looked it up and it says the thermostat on a 2.7 litre is at the other end of the lower rad hose at the water pump so does that mean i should disconnect my upper rad hose just to avoid any sediment going into my new radiator?As far as keeping my coolant clean ummm,no comment lol.
  7. Feb 18, 2022 at 8:18 PM
    #107
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Pull them both off if you want to keep stuff out of your rad.
  8. Feb 18, 2022 at 8:23 PM
    #108
    rockinrich
    will do and i can run water through both heater hoses with no problem right?As well as the heater core but watch the pressure you use in the heater core i understand?
  9. Feb 18, 2022 at 8:28 PM
    #109
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yes
    Yes don't use too much pressure, that's usually not a problem on a good flowing heater core but if its restricted you may have to go back and forth several times to get the crud to come out.
  10. Feb 18, 2022 at 8:35 PM
    #110
    rockinrich
    ok thank you!
  11. Feb 19, 2022 at 5:50 AM
    #111
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    I didn't read through the whole thread,but if it hasn't been mentioned,a no-spill funnel makes filling a radiator a breeze.
  12. Feb 19, 2022 at 8:56 AM
    #112
    rockinrich
    got one just the other day!Thanks!
  13. Feb 19, 2022 at 9:31 AM
    #113
    rockinrich
    just spit balling,after you flush should you blow hoses out with compressed air even if drains are opened?
  14. Feb 19, 2022 at 9:36 AM
    #114
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You can but you don't have to, not gona be a great amount that stays in there I would say no more than a quart or so.
  15. Feb 19, 2022 at 9:50 AM
    #115
    rockinrich
    cool,thank you!
  16. Feb 19, 2022 at 9:52 AM
    #116
    rockinrich
    Also,no need to worry about which one is inlet or outlet except when reattaching to firewall since i'll be putting water through both right?
  17. Feb 19, 2022 at 9:54 AM
    #117
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Not really as long as you put the hoses back in the correct locations when your done.
  18. Feb 19, 2022 at 9:55 AM
    #118
    rockinrich
    awesome,thanks man.
  19. Feb 19, 2022 at 9:58 AM
    #119
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You may already know this but with those spring clamps on used hoses try to get them back in the same position they were (usually you can see the imprint on the hose) when you put them back on or they may not seal.
  20. Feb 19, 2022 at 10:34 AM
    #120
    rockinrich
    will do,thank you!
