NEW RADIATOR FILL AND BLEED
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rockinrich, Feb 15, 2022.
  1. Feb 19, 2022 at 10:49 AM
    #121
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    OldTacoDD likes this.
  2. Feb 19, 2022 at 10:57 AM
    #122
    rockinrich
    rockinrich [OP] Well-Known Member
    ok i started flushing out the heater core,mine are top and bottom not side to side and i put water through the one hole and it came out the other side with some coolant then turned to water and i stopped and put it in the other hole for a minute or three and it comes out the same hole nothing from the other hole,what gives?
  3. Feb 19, 2022 at 11:02 AM
    #123
    davidstacoma
    David
    NC
    You guys have the OP disconnecting heater hoses for a simple coolant drain and fill?
    :facepalm:
  4. Feb 19, 2022 at 11:08 AM
    #124
    rockinrich
    i just put in a new radiator,what does it hurt to flush everything out as i have never done it to this truck before?
  5. Feb 19, 2022 at 11:09 AM
    #125
    rockinrich
    bump.
  6. Feb 19, 2022 at 11:10 AM
    #126
    davidstacoma
    David
    NC
    Your coolant goes through the heater core, flushing the whole system and running the engine and heater also flushes the heater core.
  7. Feb 19, 2022 at 11:36 AM
    #127
    rockinrich
    I understand that can you tell me why when i ran water through the other end of the heater core it didn't come out the opposite hole?
  8. Feb 19, 2022 at 11:39 AM
    #128
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    If you think this one turned into a science project just wait until he does a drain and refill on the transmission.
    It's the first time the OP has done this. He has ask a lot of questions, but you have to give it to him for NOT taking it to a shop and tackling the job himself.
    I saw a thread on another site where a dude had bed stiffeners put on at a shop. He asked about a missing washer on one of the bolts. One of the replys said to "hit it with your purse." Now that was funny!
  9. Feb 19, 2022 at 11:45 AM
    #129
    davidstacoma
    David
    NC
    I’ve replaced heater cores before but I’ve never done anything with my Tacoma’s heater core so don’t know the construction of it. Could be a check valve for all I know about it.
  10. Feb 19, 2022 at 11:46 AM
    #130
    davidstacoma
    David
    NC
    Haha I don’t blame the OP at all, he’s getting advice to take a lot of stuff apart is what amazes me.
    Want to make sure you get a lot of air in your coolant system to have to work to get out? Drain your block. Same goes with heater core, unless you’re replacing it no need to mess with it for a simple drain and fill or a flush.
    Also where is that damned transmission dipstick. :p
    BlkDakDave[QUOTED] likes this.
  11. Feb 19, 2022 at 1:36 PM
    #131
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    Everybody has different ways to do things. That's how we learn!
    BlkDakDave and Monkeybutt2000 like this.
  12. Feb 19, 2022 at 3:54 PM
    #132
    rockinrich
    allright i've flushed it twice with distilled water and each time it only took about 6 quarts and my truck holds 9 quarts,so obviously i have air in the system should i just put the 50/50 in next time and just keep working the bubbles out?
  13. Feb 19, 2022 at 4:29 PM
    #133
    davidstacoma
    David
    NC
    Read posts #6, 9, and 18 in this thread.
    Be sure to remove the radiator cap first as stated, removing the cap with the engine hot will spray you with hot coolant!
    https://www.tacomaworld.com/threads/how-to-bleed-air-out-of-radiator.582492/#post-19376970
  14. Feb 19, 2022 at 4:38 PM
    #134
    rockinrich
    i had cap off and
    i poured in distilled water until it stopped sucking it in the rad so i started truck and revved it a bit and air bubbles seemed to come up but wouldn't take any more than about 5.5 to 6 quarts both times and the second flush i have yet to drain but there is some distilled water in funnel still and it's still a light shade of pink.do i really need to flush until its clear or can i just put some 50/50 in it and drive it a bit and maybe come back and see if will take more fluid?
    davidstacoma[QUOTED] likes this.
  15. Feb 19, 2022 at 4:57 PM
    #135
    davidstacoma
    David
    NC
    Did you turn your heater on to make sure you had coolant flow through the heater core to remove trapped air? Also some water still in the block. If it were me I would drain the radiator, fill with 50/50 (or with prediluted only if that’s what you have), then do per the post link I gave you.
    After a short drive and waiting for the engine to cool down an hour or so I would slowly remove the radiator cap with a rag on top and add more there if needed.
    And as was said check the level in the overflow tank every day for a few days and add as needed, watching engine temp and making sure the heaters blowing hot air.
  16. Feb 19, 2022 at 5:40 PM
    #136
    rockinrich
    I did turn the heater on and revved it up a bit and air bubbles would come up bit still only took between 5.5 and 6 qts. so maybe tomorrow i'll do the 50/50 and drive it a bit.it's still a bit pink but i don't think i'm going to worry about that.Also the heater inside the truck was hot coming through the vents.
  17. Feb 19, 2022 at 6:00 PM
    #137
    davidstacoma
    David
    NC
    Sounds like a plan. If the coolant in your overflow tank is clear and no sediments you should be fine.
    Toyota will tell you to flush the coolant every 3k miles or 2-3 years whichever comes first, but they love the service money. Others will say every 100k miles/5 years. I’m somewhere in between based on how clear the coolant is.
  18. Feb 19, 2022 at 6:21 PM
    #138
    rockinrich
    the color was a light pink but i flushed it twice and i thought the radiator puts fluid into the reservoir when the trucks running and i didn't see any going into it.Anyway i'll deal with it tomorrow lol
  19. Feb 19, 2022 at 6:21 PM
    #139
    OldTacoDD
    OldTacoDD current brain has check engine light on
    PNW
    2002 3.4L V6 SR5
    PUT.THE.CAP.BACK.ON.ITS.NOW.SUCKING.AIR. (which is normal and good to see, it means it circulating properly)
    You are done with the hard work so to speak, now it's time to keep checking the reservoir. There should be some in when cold, just don't go for traffic drives that can overheat the engine. It took 6 quarts which is just over a gallon and a half and you just need 2 gallons. 1 gallon of 50/50 and 1 gallon distilled water (hence 50/50 fluid). Sounds like you will have enough 50/50 left over to fill the reservoir, don't mix it down, fill to "cold" line when the engine is cold.
    Done.
    3 Taco's since 1986, didn't do any radiator flush or change until 100K miles.
    davidstacoma likes this.
  20. Feb 19, 2022 at 6:22 PM
    #140
    davidstacoma
    David
    NC
    I meant clear as in not cloudy or any sediments, pink is fine.
    Here’s how to properly fill the reservoir, the picture is of mine (2.7L engine).
    https://www.tacomaworld.com/threads/what-says-the-wise-forum.755047/page-2#post-26910661
