NEW RADIATOR FILL AND BLEED
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rockinrich, Feb 15, 2022.
  1. Feb 19, 2022 at 6:24 PM
    #141
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Toyota's coolant doesn't seem to have as much issues with particulates as some other manufacturers but on many you have to pull the hoses and backflush the heater cores to clear all the crap out of them.
    2nd gens don't have a heater control valve so coolant is always flowing through the heater core whether the heater is on or not.
    Vehicle cooling systems usually don't take the total listed capacity except on a freshly rebuilt engine as there's always some that stays trapped in the coolant passages even with the drains all being opened, also total listed capacity generally includes the overflow bottle.
    If your using the spillproof funnel park the vehicle on a slight incline with the front of the truck slightly elevated do the initial fill, leave the funnel installed, start the truck and let it idle until the thermostat opens (upper hose and air across the radiator get hot) while keeping coolant in the funnel and keeping an eye on the temperature as to not overheat it.
    Once it's up to temp stick the plug in the funnel and remove it, put the rad cap on, drive the truck a bit, allow it to cool, once it's cooled check the level and top off as needed.
    davidstacoma[QUOTED] likes this.
  2. Feb 19, 2022 at 6:26 PM
    #142
    rockinrich
    rockinrich [OP] Well-Known Member
    how could it be sucking air if there was still fluid in the funnel?
    davidstacoma likes this.
  3. Feb 19, 2022 at 6:27 PM
    #143
    OldTacoDD
    OldTacoDD current brain has check engine light on
    PNW
    2002 3.4L V6 SR5
    That should end up being a 40 page thread...
    :rofl::rofl::rofl::rofl:
  4. Feb 19, 2022 at 6:33 PM
    #144
    rockinrich
    oh ok so don't worry about not taking more than about 5.5 quarts huh.I am using the spillproof funnel and had it jacked up a bit today and will again tomorrow and then like you said drive it once it wont take any more.So no need to turn on the heater huh.like i told david the second flush is a light pink but no need to flush with water anymore huh just 50/50 it?
  5. Feb 19, 2022 at 6:35 PM
    #145
    rockinrich
    one more thing,what the f is op? lol
  6. Feb 19, 2022 at 6:36 PM
    #146
    rockinrich
    obsessive prick? lol
    Biscuits, BlkDakDave and davidstacoma like this.
  7. Feb 19, 2022 at 6:37 PM
    #147
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Your math is off here - 1 gallon of 50/50 and 1 gallon of distilled water equals 2 gallons of a 25/75 mixture, not 50/50. If the current mixture in the system is already at 50/50, then anything he adds should already be a 50/50 mix in order to maintain 50/50.
  8. Feb 19, 2022 at 6:38 PM
    #148
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    YOU lol. Original Poster. :D
  9. Feb 19, 2022 at 6:39 PM
    #149
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    As long as your thermostat opens you should be fine, my 14 4.0L calls for 10.1 Quarts and it took exactly 2 gallons (8 quarts) when I did a drain and fill (and yes I opened both block drains).
    Yea you should be fine, I always use full strength coolant and add half the listed capacity in coolant and the rest distilled water.
    OldTacoDD and davidstacoma like this.
  10. Feb 19, 2022 at 6:39 PM
    #150
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Original Poster.
  11. Feb 19, 2022 at 6:41 PM
    #151
    OldTacoDD
    PNW
    2002 3.4L V6 SR5
    Please look at your Haynes to see how it circulates through the block and radiator. You're fine.
    Why did you have it jacked up? First page, let it sit on a flat surface. You already have heat in the cabin so the T-stat is operating normal. No more flushing, just fill with 50/50 as needed.
    "OP" = Original Poster
    It's by your name if you start a thread.
  12. Feb 19, 2022 at 6:44 PM
    #152
    davidstacoma
    David
    NC
    Everyone should be clear on one thing now, what OP” means lol
    rockinrich[OP] and Dm93 like this.
  13. Feb 19, 2022 at 6:44 PM
    #153
    rockinrich
    right on,yeah i think the haynes toyota book contradicts itself.I read where it says to have the fluid in between the low and full line and another page where it said on a cold engine fill to just above the low mark ,weird.
  14. Feb 19, 2022 at 6:47 PM
    #154
    rockinrich
    ahh,so not obsessive prick? lol I only jacked it up on the second flush to see if that would help anything and i'll just fill with 50/50 tomorrow and drive it a bit and check it and add if needed,thanks!
    OldTacoDD[QUOTED] likes this.
  15. Feb 19, 2022 at 6:47 PM
    #155
    OldTacoDD
    PNW
    2002 3.4L V6 SR5
    Keep that undiluted 50/50 for the res/overflow and no, it's not viscous enough to cause any problems if the mix isn't exact. Less water, more mix is optimal with the caveat where you live and driving type.
  16. Feb 19, 2022 at 6:48 PM
    #156
    davidstacoma
    David
    NC
    Yeah I think back in the day there might have been Hot and Cold marks on some reservoir tanks, could be they have more volume above the top line now (Full or Max) so you fill to the top line. I’m going off “back in the day” memory which could be wrong lol.
  17. Feb 19, 2022 at 6:48 PM
    #157
    OldTacoDD
    PNW
    2002 3.4L V6 SR5
    Being obsessive when you first get under the hood is a good thing. It means you are lazy - lazy people work harder to get it right the first time so they don't have to go back and do it all over again.
    Dm93 likes this.
  18. Feb 19, 2022 at 6:54 PM
    #158
    rockinrich
    i got concentrated not the diluted mix so i'll add a bit of it to the reservoir.So where would those other two qts. be sitting if i drained the engine block?Still in block or the system somewhere?
  19. Feb 19, 2022 at 6:54 PM
    #159
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I wouldn't say they are necessarily lazy but it's definitely much better than the people that try to DIY, screw it up , and then ask how to do it right and/or how to fix what they screwed up.
    rockinrich[OP] likes this.
  20. Feb 19, 2022 at 6:57 PM
    #160
    rockinrich
    lazy??? well i never,wait maybe a tad lol.
    Dm93 likes this.
