NEW RADIATOR FILL AND BLEED
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rockinrich, Feb 15, 2022.
  1. Feb 19, 2022 at 6:58 PM
    #161
    rockinrich
    rockinrich [OP] Well-Known Member
    I am doing my best to get this thread to 40 pages!
  2. Feb 19, 2022 at 6:59 PM
    #162
    OldTacoDD
    OldTacoDD current brain has check engine light on
    PNW
    2002 3.4L V6 SR5
    If the concentrate says 50/50 on the bottle, it's partially diluted. You could fill it with 2 gallons of it and still be within normal limits of what Toyota recommends.
    There is still water/fluid in the block after a flush.
    lol, it's something my Grandpa used to say to me "We are lazy". I was baffled for years until I got what he meant.
    Now to look on the floor behind you to see where that 2x4 landed :thumbsup:
    davidstacoma likes this.
  3. Feb 19, 2022 at 6:59 PM
    #163
    rockinrich
    right on!
    OldTacoDD likes this.
  4. Feb 19, 2022 at 7:00 PM
    #164
    OldTacoDD
    PNW
    2002 3.4L V6 SR5
    That will get you banned.
    Not a good idea.
    Transmission fluid change next up?
  5. Feb 19, 2022 at 7:02 PM
    #165
    rockinrich
    There is still water/fluid in the block after a flush. No i got full strength so i'll mix that with the water.so there is just some fluid in the block you cant get out huh.
  6. Feb 19, 2022 at 7:03 PM
    #166
    rockinrich
    possibly lol i've done that before but been awhile so look out!!!I hear ya on the 40 pages lol
  7. Feb 19, 2022 at 7:08 PM
    #167
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    You know, you're all right.
  8. Feb 19, 2022 at 7:09 PM
    #168
    rockinrich
    thank you! lol
  9. Feb 19, 2022 at 7:10 PM
    #169
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    You work in an automotive shop for a few years and you get to see the handywork of alot of lazy people lol, bolts missing/broken/crossthreaded, wiring not where it belongs, broken connectors, "twist n tape' wire splices instead of butt connectors or soldered connections, etc etc.
  10. Feb 19, 2022 at 7:23 PM
    #170
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    I’m a butt splice and heat shrink guy myself. Which reminds me, I still need to go tie wrap up the wiring I did adding dual low tone horns to my single horn SR a month or so ago….oops.
    OldTacoDD and Dm93[QUOTED] like this.
  11. Feb 19, 2022 at 7:29 PM
    #171
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I prefer to solder and heat shrink if I can, where that isn't possible I like the crimp & seal butt splices (always remember to do the tug test on butt splices:thumbsup:).
    davidstacoma[QUOTED] likes this.
  12. Feb 19, 2022 at 7:40 PM
    #172
    davidstacoma
    David
    NC
    I have a high quality ratchet crimper, you’ll break the wires before you pull the crimp loose with that thing. Those pliar type crimpers are garbage. Have a solder gun reserved for soldering wires to circuit boards etc.
    Dm93[QUOTED] likes this.
  13. Feb 19, 2022 at 7:47 PM
    #173
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I'm to tight to buy a ratchet crimper lol, never had an issue with a plier type crimper, just always remember to do the tug test.
  14. Feb 19, 2022 at 11:36 PM
    #174
    hotajax
    hotajax Well-Known Member
    09 TRD Off Road
    I just fill it from the cap. Drive it around for a day, refill. Repeat 2 or 3 times. Make sure you keep your overflow tank full if you do it this way. The lazy man way. PS- I got 309,000 miles, so something's working ok.
  15. Feb 20, 2022 at 9:16 AM
    #175
    rockinrich
    where ya been you missed all the fun on this thread lol
    Dm93 and BlkDakDave like this.
  16. Feb 20, 2022 at 3:34 PM
    #176
    hotajax
    09 TRD Off Road
    No I didn't. I went to the gym and checked out the hot looking MILFs in tight pants. Beats talking to you guys anyday. :) Nothing personal.
  17. Feb 20, 2022 at 6:38 PM
    #177
    TacoTuesday1
    SD CA
    I like it when you get a car from a body shop that doesn’t want to pay diagnosis and thinks the CEL has nothing to do with their work
    and you find out in the area they worked on they put a potato in the light bulb socket and used a shoelace to be the “wire” that connects it
    certain manufacturers only allow heat shrink crimp connectors because soldering can alter resistance and break/crack over time from any movement, bending, or vibration caused from normal use of the vehicle
    I have been told by helicopter mechanics that this is the same principle used in the military, not just automotive repair
    with a properly sized crimp connector installed in a staggered position in a harness, used with 3M Super 33, cloth tape, heat shrink tubing, etc you cannot tell a repair has been done in the area aside from a strip of colored tape you’re supposed to wrap on the outside to let people know a repair has been performed in that area.
    soldering is also high temperature and difficult, requiring skill/experience and good materials, versus crimping on a butt connector
  18. Feb 20, 2022 at 7:55 PM
    #178
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I don't do body work but yea I've had to go behind them and fix electrical stuff.
    That's why I prefer to use lead/tin solder, the lead free stuff is hard to solder with and it's much more prone to cracking (that's why cracked solder joints are so common in electronics these days).
  19. Feb 20, 2022 at 10:12 PM
    #179
    rockinrich
    ok i'll cut you some slack this time lol
  20. Feb 24, 2022 at 3:40 PM
    #180
    rockinrich
    just an update,i drove it a bit and let it cool and then the rad would suck out the reservoir so i'd fill the reservoir up a bit and kept driving it,letting it cool until the rad was full and isn't sucking anymore and the reservoir is just above the low line and it finally got to the point to where it's not sucking it dry and i'm over 8 qts to fill the rad,remember when i said it would only take 6 qts,no more!Also a side note,generally when you disconnect your battery and then reconnect it the truck runs like crap and doesn't want to idle for a bit till the computer does it's thing and that's what mine was doing but wasn't getting any better after 80 miles drive time so i figured i'd take a look at the air filter and it was filthy,i'm surprised it ran but cleaned it,k&n filter,and it idles and runs great now!
