New Radiator Questions - Aluminum?
Discussion in '1st Gen. Tacomas (1995-2004)' started by japeda, Nov 4, 2018.
  1. Jul 22, 2019 at 2:07 PM
    #81
    1997tacomav6
    Denver
    Possibly but the builder says the new technology of the extruded design will way out perform anything in
    it’s class for comparison and it’s going to be 2.5” thick
    cruiserguy[QUOTED] likes this.
  2. Jul 22, 2019 at 2:08 PM
    #82
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Yeah sounds like extra cooling won't be needed at all with that bad boy. Be nice to not ever have to worry about the radiator in back of your mind
  3. Jul 22, 2019 at 2:10 PM
    #83
    1997tacomav6
    Denver
    That’s were I’m at!!! Sick of looking at that temp gauge when it’s 105 outside and stuck in traffic. Will check back in 3 weeks middle of August when temperatures outside will be hotter
  4. Jul 22, 2019 at 2:14 PM
    #84
    JMJordan
    JMJordan Active Member
    Atlanta, GA
    2003 Tacoma 4-Door 4WD SR5
    285/70/17 Nitto Terra Grappler G2 BK-9504 Lift Kit w/Bilstein 5100's, 3" Toytec/Eibach Coils, 2" ToyTec AAL
    Educate me on what else the issue(s) could be? My hood stays hot hours after the truck is turned off.
  5. Jul 22, 2019 at 2:22 PM
    #85
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Educate me on how adding nearly a gallon of coolant to your system can make your truck run hotter.
    Possible other factors... Let's see
    Bad water pump, or
    Bad thermostat, or
    Clogged heater core, or
    Any number of other things.
    The Champion may be developing a track record for leaks, but no one has ever said it makes their truck run hotter.
    1997tacomav6 likes this.
  6. Jul 22, 2019 at 2:26 PM
    #86
    JMJordan
    Atlanta, GA
    New water pump, new thermostat...there was never an issue before the first Champion was installed, so by process of elimination it seems like the Champion is the cause...you sound like this is hitting a nerve, relax...this forum is about education without being a prick, try it...I’m no master, I’m trying to learn, so don’t be a prick.
    Running Board Man likes this.
  7. Jul 22, 2019 at 2:39 PM
    #87
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    @JMJordan
    How am I being a prick?
    You made a statement that your truck runs hotter now than before the Champion. I made a statement that you may have a different issue that is an underlying problem.
    You tell me to "educate you" and I answered your question.
    You say all your problems started when you replaced the radiator. Did you make sure to properly burp the system of air when you did that? Because THAT is another very common reason for overheating these engines. (of course you'll say you did, because you're convinced I'm being a prick... when I'm only trying to help)
    After all the complaints about these radiators... I think you're the first and only one that has said the Champion Radiator makes your truck run hotter.
  8. Jul 22, 2019 at 2:41 PM
    #88
    tony2018
    tony2018 Well-Known Member
    Hm....wondering if rubber bushings should be used at the locations of the threaded bolt holes. Like drill it out and stick one of those sleeved rubber bushings on it.
  9. Jul 22, 2019 at 2:45 PM
    #89
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I'm probably going to do exactly that while working on the truck this weekend.
  10. Jul 22, 2019 at 2:45 PM
    #90
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Lol... my bad
  11. Jul 22, 2019 at 2:46 PM
    #91
    tony2018
    K, I didn't think about it until someone stated the 'flexing'. We don't need poly bushings but rubber ones.
  12. Jul 22, 2019 at 2:48 PM
    #92
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Also @JMJordan
    Did you install your Tstat correctly? Jiggle valve should be at 6:00 not 12:00... That will also overheat your truck. Non-OEM Tstat (if it doesn't have a jiggle valve) will overheat your truck.
  13. Jul 22, 2019 at 2:59 PM
    #93
    JMJordan
    Atlanta, GA
    Read the way you responded the first time to my post, very condescending.
    Now, let’s move forward...let’s say the system was properly burped, what’s the next move you would make to resolve the issue?
    I, like most people on here, aren’t professional mechanics, so I’m genuinely trying to learn.
    Thank You for your assistance, it is appreciated.
  14. Jul 22, 2019 at 3:02 PM
    #94
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Wasn't being condescending... was being direct... because that's how I roll.
    Next thing I would look at is the jiggle valve on the Tstat. Because putting it in the 12:00 position seems like the logical thing to do, but it is incorrect. I don't know what magic is involved in that shit, seems to defy the laws of physics, but the jiggle valve should be at 6:00.
    tony2018 and Running Board Man like this.
  15. Jul 22, 2019 at 3:18 PM
    #95
    Czechnology
    Czechnology Well-Known Member
    04 Xtracab TRD Offroad
    There's a sticker on the back of the top plastic tank near the upper radiator hose fixture that has a date on it, March 2004. Since my Taco is an 04 model, I deduced that the date on the sticker was the date of manufacture of the radiator and was probably installed on the Taco at the factory, in 2004.
  16. Jul 22, 2019 at 3:38 PM
    #96
    1997tacomav6
    Denver
    Running hotter after Champion installed is NOT from the radiator.
    Maybe your thermostat is incorrectly positioned maybe your fan clutch is not working maybe you didn't burp the system correctly and there is air trapped in there
  17. Jul 22, 2019 at 4:48 PM
    #97
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Who's making it / for how much? Also are the leaks easily fixed if you can weld aluminum?
  18. Jul 22, 2019 at 5:28 PM
    #98
    1997tacomav6
    Denver
    I will update that Info when it’s done and I receive it and I’m happy.
    Will not be cheap but like a set of good shocks I want the Kings Struts not the Monroe anymore.
    Champion seams are busting loose on me, not worth welded For me,
    I’m not going to be chasing leaks
  19. Jul 22, 2019 at 5:50 PM
    #99
    dankgus
    dankgus Well-Known Member
    Dan
    2002 3.4l Tacoma
    I need a radiator for a 2002 3.4 Automatic 4wd. I was all set on getting a champion but it seems like they don't have the best reputation. I'd be happy getting a factory OEM radiator but it seems like the parts sites I look at all show "discontinued". Am I missing something? What's a good radiator to get?
  20. Jul 22, 2019 at 5:54 PM
    #100
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Toyota didn't make radiators for the Tacoma (or in any vehicle they produced in that era I believe). The OEM was a purchased part from another company - I'd go with the cost vs. reputation scenario - I have a Champion, but a $100 Mishimoto that I previously purchased waiting in case something happens.
