New Radio Install - light tap question
Discussion in 'Lighting' started by brucewol, Feb 19, 2011.
  1. Feb 19, 2011 at 11:01 AM
    brucewol
    brucewol [OP] Member
    08 tacoma
    I'm installing a pioneer avh3200bt and the installation manual only lists 1 wire to connect for lighting. Does this mean the unit can't be dimmed? I've looked at these threads to determine where to do the light tap.
    vhttp://www.tacomaworld.com/forum/lighting/68173-rcbs204-4x4-illuminated-switch.html
    http://www.tacomaworld.com/forum/lighting/78339-4x4-illuminated-switch-cup-holder-light-mods.html
    With my meter it looks like the green is 12 volts with the light on and the green white voltage varies depending on the dimmer switch. So the voltage difference between the two controls the dimming.
    If I've only got 1 light lead for the radio, is there any way to get dimming. Haven't gotten to turning the radio on yet, so maybe I don't really need dimming????
    Thanks
  2. Feb 19, 2011 at 11:15 AM
    spamy
    spamy Truck guy
    NorCal
    07 4X4 Tacoma Sport SR5 Access Cab
    I decided to skip that on mine and havent regretted it at all.
  3. Feb 22, 2011 at 9:26 PM
    brucewol
    08 tacoma
    I got a reply back from Pioneer USA that indicates the display dims when the light are turned on. My old school thinking got me confused thinking you needed to turn on lighting for the radio at night. I guess since it's a display, it needs to be brighter during the day then at night. I'll hopefully find out this weekend, all the wiring is in, now just need to plug it in and test/configure.
  4. Apr 21, 2011 at 9:02 PM
    CCFBERG
    CCFBERG The Shocker and Me Tall Dark TACO
    Shawn
    LRAFB Arkansas
    2010 TRD 4x4 SR5 DBL cab
    Kenwood 516 DD head unit, Kenwood 12" sub, Kenwood 1800W amp, Brighter reverse light mod, 2nd Air filter ripped out, Tailgate anti-theft. Fog light anytime. Rearview mirror display in HU mod. JBA shorty headers & Catback. K&N Filter. Smittybilt Nerf Steps. Smittybilt M1 Grille. Pro Comp stage II, 6" Lift. 12V Bed PWR. LED interior lighting
    Just an FYI when reading this: If you get your instal kit from Crutchfield the directions for install are confusing. There is a Ver #1 and Ver #2 if you have Ver #1 it will tell you to hook up both wires. You dont find out you were only supposed to hook up one of them until you turn on the truck and lights and you have no lights....headlights and all go out and do crazy things! I was able to get most of the lights back on by unpluging the dimmer switch and all works fine except climate control lights are 100% out until I order a new dimmer. Called crutchfield and they said "ya there is a new rev to that. You should have Vers #2 not #1" Personaly I think they should pay for my dimmer but F*ck it! Just a warning! be careful
