New Raptor Lights for the PRO Grille
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kabogski, Nov 20, 2018.
  1. Dec 9, 2018 at 6:32 AM
    #41
    JRH_Tacoma
    JRH_Tacoma Well-Known Member
    Charlotte, NC
    2017 BBP Tacoma TRD Sport 4x4
    Thanks for posting this video. The option with the 3 lights at the very top definitely looks the best. If the 3 lights could pop into the top without modification these things would fly off the shelves. But I’m reluctant to cut into my grille like that to make the lights fit. I’m not a big fan of the lower positions or the 4 light option. Looks best with 3 at the top for sure.
  2. Dec 9, 2018 at 7:59 AM
    #42
    savethewheels
    savethewheels Well-Known Member
    Nashville, TN
    truck
    Couldn't agree more...
    however I've already cut into the lower-middle cutout in order to make it match the rest of the grille, so I'm a bit less reluctant.
    SilverII likes this.
  3. Dec 9, 2018 at 9:03 AM
    #43
    NightStalker68
    NightStalker68 New Member
    Alex
    So if someone doesn't have a fancy fuse dongle that attaches straight into the box, how should i connect some LEDs i got,
    Did you just get a 10amp fuse and wire to it? I also got some LEDs but don't wanna wire it the wrong way.
  4. Dec 9, 2018 at 9:12 AM
    #44
    mOjO_Taco
    mOjO_Taco Well-Known Member
    Mesa, AZ
    2020 TRD 4X4 OR Cement
    None yet
    I feel I should be a bit more reluctant into cutting into the grill. But unless you have plans of removing them later or should they not function then it could be an issue. Either way, I ordered them and I will post the after pic and if any issues came up...I will more than likely go with the top row option.
    savethewheels likes this.
  5. Dec 12, 2018 at 4:58 PM
    #45
    savethewheels
    Nashville, TN
    truck
    SandyTaco4x4, TT005, Toms 17 and 2 others like this.
  6. Dec 13, 2018 at 5:04 AM
    #46
    JRH_Tacoma
    Charlotte, NC
    Nice. Looking forward to hearing your thoughts on the install and the quality of the lights once you have it all hooked up. I'm very close to buying these. The install videos are very helpful but want to get a review from actual customers before committing.
    savethewheels[QUOTED] likes this.
  7. Dec 13, 2018 at 6:19 AM
    #47
    savethewheels
    Nashville, TN
    truck
    I'm just going to add to my toolbox and buy a file and mini-saw like he used in the install vid. Looks like that's the path of least (and safest) resistance.
    Toms 17 and JRH_Tacoma[QUOTED] like this.
  8. Dec 13, 2018 at 11:30 AM
    #48
    mOjO_Taco
    Mesa, AZ
    None yet
    Same here, gotta make a stop to get a file and the mini saw. I have a Dremel...but a little worried I might too much or even worse and slip!
    Lights come in today so I will be installing this weekend!
  9. Dec 15, 2018 at 11:05 AM
    #49
    savethewheels
    Nashville, TN
    truck
    Install video is comprehensive, so I won't repeat everything they worked to put together. I'll summarize and offer some tips.
    Get the 10 piece file set, it's definitely easier and more useful than the mini saw (which I'll be returning).
    Use painters tape so you don't grind other things while filing.
    Filing the grille openings.
    Inserted
    Notice where the shroud was filed on the sides and top.
    Then this happened while closing the fuse cover. I've already spoken with them about an alternate route to run the wiring. Right now you just probably shouldn't completely snap shut the fuse cover in one of the corners.
    Once I replaced the butt connector and recrimped I was back in business.
    Done. More pics to follow.
    Edit: They're going to tinker some with the wiring route, but are thinking that running it through the bottom of the fuse box alongside the other wires might be a tidy and viable option.
    Tommyb08, dskakie, arnette64 and 6 others like this.
  10. Dec 15, 2018 at 11:21 AM
    #50
    NickTaco
    NickTaco Well-Known Member
    SF BayArea
    23' TRD OR DCLB 4X4 MGM
    looks good!
  11. Dec 15, 2018 at 12:08 PM
    #51
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    There was a modding thread I was watching a while ago where people would install folding tow mirrors on their Taco. The Dodge forums noticed and had a field day on that.
    Now I'm kinda curious to see if the raptor forums have noticed this trend yet .:rofl:
  12. Dec 15, 2018 at 12:34 PM
    #52
    JRH_Tacoma
    Charlotte, NC
    Thanks for the review, that’s very helpful. Especially knowing the tools that worked well for you. Those lights look perfectly placed.
  13. Dec 15, 2018 at 10:59 PM
    #53
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    If you wired to the fuse box, do you turn them on with a switch?
  14. Dec 16, 2018 at 1:01 AM
    #54
    Rainer415
    Rainer415 Well-Known Member
    Rainer
    California
    2017 Tacoma TRD Sport Barcelona Red
    Camera mount
    Hi guys I bought the ones on eBay from a seller who is located in California. It took like 4 days to get the lights in the mail.
    Here’s a pic of the lights.
    #54
    Russy8, Rebelman21, bohdiez and 4 others like this.
  15. Dec 16, 2018 at 1:14 AM
    #55
    Eticket
    Eticket Well-Known Member
    Thomas
    Holly Springs, NC
    2016 Tacoma TRD Sport 4x4
    FYI, for the wires in the fuse box, if you just put a small cut in the top cover, on the side, it won’t cut into the wires, and can be routed right out...
    If you ever decide to change, it’s only the lid to replace and very inexpensive.
    Toms 17 likes this.
  16. Dec 16, 2018 at 2:44 AM
    #56
    savethewheels
    Nashville, TN
    truck
    Those are the same lights, but only the lights and harness, correct? No Add a Fuse, ground, splice, zip ties, etc? This Runnin4Tacos kit is more for those looking for a plug n' play solution. Also, I believe the lights you have are wired for an extra light, which you've just got to coil up in the engine bay (which I don't like).
    #56
  17. Dec 16, 2018 at 6:30 AM
    #57
    JRH_Tacoma
    Charlotte, NC
    Looks really good man. This particular style of light is definitely the best I’ve seen out there. They just look like they’re meant to be there, don’t look out of place at all. Even during the day they add a nice subtle touch.
    #57
    Toms 17 and savethewheels like this.
  18. Dec 16, 2018 at 10:05 AM
    #58
    Rainer415
    Rainer
    California
    Camera mount
    Thanks man, I agree.
  19. Dec 16, 2018 at 10:12 AM
    #59
    Rainer415
    Rainer
    California
    Camera mount
    4 PCS GRILL LED LIGHTS with WIRES FOR TOYOTA TACOMA TRD GRILLE LEDS 2016-2018 https://www.ebay.com/ulk/itm/143023181279
    You just need to buy the “add a circuit” and you are all set!
    #59
    cipherbreaker likes this.
  20. Dec 16, 2018 at 10:30 AM
    #60
    Jrgymie
    Jrgymie Tuf MuddR
    Jeff
    Glastonbury, CT
    18 DCSB CEMENT TRD SPORT 4x4
    If you want raptor lights buy a raptor. This truck has plenty of uniqueness and good looks without trying to make it look like another brand. How about adding/upgrading to some rigid or baja designs lights which will provide increased function instead of cheesy knock off lights in the grille.
