New RCD Suspension System For Tacoma's
Discussion in 'Suspension' started by Downsouth Motorsports, Feb 5, 2009.
  1. Jun 28, 2009 at 12:44 PM
    bermise
    bermise Well-Known Member
    Houston
    08 TRD off road
    Total chaos spindles, Total chaos heim joint uca's, Icon E/T coilovers, Icon reservoir shocks, custom Deaver 10 leaf pack, 285/70/17 Cooper STT
    Who is RCD? Have they been around working on other off road products. I wonder how their price will compare to Fabtech or Procomp db lifts.
  2. Jun 28, 2009 at 12:47 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    RCD is big in Chevy, Ford, & Dodge land... known for high quality lifts.
  3. Jun 28, 2009 at 1:07 PM
    bermise
    Houston
    08 TRD off road
    With the rumors about Fabtech maybe RCD will succeed in the Tacoma market.
  4. Jul 22, 2009 at 4:11 PM
    JRW1223
    JRW1223 Well-Known Member
    Jordan
    Tucson, AZ
    07 DCab 4x4 sport
    All Pro long travel, All Pro Front bumper, BFG 285/75/16, American Racing Ledge Wheels 16x8, Vision X 8.7" Tungsten Halogen Off Road Lights
    With this lift is there an option to do an AAL instead of blocks?
  5. Jul 22, 2009 at 6:31 PM
    Downsouth Motorsports [OP] Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    You might be able to do a shorter block and an AAL, but to get the height out of the rear with just an AAL will be a little tough unless you went to a complete new spring pack....
  6. Jul 22, 2009 at 6:39 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    aal and a shackle flip kit would probably work pretty awesome
  7. Jul 22, 2009 at 9:16 PM
    JRW1223
    Jordan
    Tucson, AZ
    07 DCab 4x4 sport
    Do you know of anyone that as added a complete new spring pack with this kit? If so any pics?
  8. Jul 23, 2009 at 11:38 PM
    icon2
    icon2 ICON VEHICLE DYNAMICS Vendor
    Corona
    RCD has been making high quality American made lift kits for many years. Even though we sometimes compete with them I have always recommended customers to them for higher lift height applications. We currently offer our coil-overs for their Tundra and F150 kits. We will be offering our 2.5" diameter adjustable coil-overs for the Tacoma kit as well. This will give you a great performance option upgrade from the Bilsteins. Our coil-overs are built from the ground up specifically for this kit and are not an off the shelf shock that is made to fit. Many of the Tundra owners have been using a custom Deaver Spring pack in the rear instead of the block and Deaver can do the same for the Tacoma This kit is a great alternative to the inferior Chinese made kits that seem to be everywhere.
  9. Jul 23, 2009 at 11:41 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Good to know.
  10. Jul 24, 2009 at 7:05 AM
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2018 dcsb trd offroad 4x4 Inferno
    why spend that much on a 4.5" kit when u can get a 6" kit from procomp or fabtech?
  11. Jul 24, 2009 at 7:07 AM
    KMN-BLU
    KMN-BLU less work/more play
    Destin, Fl
    2018 Tacoma TRD PRO
    Because with the 4.5" kit you wont have to cut your frame to make it work.
  12. Jul 24, 2009 at 8:25 AM
    allrsdup
    Sahuarita AZ.
    yes u do. all drop bracket lifts u need to cut so the front drive shaft has room to lower with the front diff. unless u have a 2 wheel drive.. waste of money basically u get less lift for same price.
  13. Jul 24, 2009 at 8:36 AM
    KMN-BLU
    Destin, Fl
    2018 Tacoma TRD PRO
    You are correct. My bad. I failed to go back and look at the full post. I forgot this RCD lift used the drop bracket. I take back my comment and agree with your initial statement. If your cutting anyway you may as well go 6 inches.
    I originally wanted this lift and ended up going with the Camburg Coilover instead that allowed me to crank it up to 4 inches anyway.
  14. Jul 24, 2009 at 9:58 AM
    allrsdup
    Sahuarita AZ.
    wow cranked up that much? more then 2" and your going to have major rack and pinion and front half shaft problems.
  15. Jul 24, 2009 at 10:03 AM
    #35
    KMN-BLU
    Destin, Fl
    2018 Tacoma TRD PRO
    Maybe thats why it floats all over the road like a butterfly?
    j/k , It has a slight angle on the CV joints but it really isnt that bad.
    But, It does look good either way.
  16. Jul 24, 2009 at 10:05 AM
    #36
    rutherk1
    rutherk1 ElPhantasmo&TheChickenRunBlastarama
    09 Silver TRD 4door
    Awesome. Look at those CV angles. Very nice.
  17. Aug 9, 2009 at 6:15 PM
    #37
    JRW1223
    Jordan
    Tucson, AZ
    07 DCab 4x4 sport
    If I were to do a full leaf pack instead of a block, how much lift would be needed to get a level look? I know it comes with a 4" block but it looks like Peejay's truck is higher in the back.
    How much lift are you actually getting in the front? Its got to be around 5" or so, right?
  18. Aug 9, 2009 at 7:07 PM
    #38
    allrsdup
    Sahuarita AZ.
    all drop bracket lifts are good cv angles. but your payinging same amount for 4.5" that u would pay for 6" and same amount of work. doesnt make sence but if u like to pay more for less thats cool to each there own.
  19. Aug 14, 2009 at 12:01 AM
    #39
    peejay
    peejay Yep im that Peejay..
    PJ
    San Diego
    Running a tricked out rzr xp 4
    Rollin a Hemi, and wheelin a sick xp4
    I didnt have the TSB done on my truck. Those are the stock rear leafs in the back.
