New rear end
Discussion in '5 Lug' started by DrunkenDangler, Jun 22, 2011.
  1. Jun 22, 2011 at 10:59 AM
    DrunkenDangler
    DrunkenDangler [OP] Well-Known Member
    AL
    2005 5 lug access cab
    fat bob lift
    Im just put 30s on my 5 lug auto with a fat bob lift. and it has really seemed to kill my power. what rear end would you recommend for a lot of interstate driving. what a prerunner rear be a good choice?
  2. Jun 22, 2011 at 2:39 PM
    ISUGrad05
    ISUGrad05 Public Servant Enemy #1
    Wichita, KS
    2012 4x4 5.7 Tundra DoubleCab
    3.73 3rd member swap from a V6 should put you back to near stock with 30" tires. The 4 cyl auto is 3.58 stock ratio.
  3. Jun 22, 2011 at 3:43 PM
    DrunkenDangler
    AL
    fat bob lift
    anyone know where i can find one?
  4. Jun 22, 2011 at 4:09 PM
    ISUGrad05
    Wichita, KS
  5. Jun 22, 2011 at 5:14 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I'd go 3rd member from 4cyl Prerunner or 4x4, they come with 4.10 gears stock...
  6. Jun 22, 2011 at 5:17 PM
    DrunkenDangler
    AL
    fat bob lift
    how would the 4:10 ride on the interstate?
  7. Jun 22, 2011 at 5:18 PM
    05RedTaco
    Tony
    Scottsdale
    With 30's probably very close to stock.
  8. Jun 22, 2011 at 5:27 PM
    DrunkenDangler
    AL
    fat bob lift
    where would you recommend i get the set up?
  9. Jun 22, 2011 at 5:38 PM
    ISUGrad05
    Wichita, KS
    4.10 with 31's would be stock, with 30's it would geared lower than stock. Either way you would get more torque to the wheels, but run higher rpms. If you search around on here you'll some links to gear/tire ratio calculators.
  10. Jun 22, 2011 at 6:00 PM
    DrunkenDangler
    AL
    fat bob lift
  11. Jun 22, 2011 at 6:32 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    We can't run rear 3rds from 6 lug trucks can we? I don't know about 2nd gen but 1st gen have different ring gear sizes... HOWEVER I know the front diff is a 7.5" ring gear... So can we use front 3rds from trucks that swap to lower gears?
  12. Jun 22, 2011 at 8:23 PM
    ISUGrad05
    Wichita, KS
    Yes you can run a 3rd member from a 6-lug because it includes the gears and the housing. You are correct that you can't run the ring gear from a 6-lug in a 5-lug housing.
  13. Jun 22, 2011 at 8:58 PM
    05RedTaco
    Tony
    Scottsdale
    Yes correct, that's why if you want to re-gear a 5lug, you need to purchase used 3rd member from 6lug truck not just the ring and pinion... Yes it sucks...
    That is because the carrier in the differential of 5 lug truck is different from 6lug truck...
  14. Jun 23, 2011 at 4:13 PM
    MowTaco
    Kansas
    Oh that makes re gearing seem pretty easy then... I mean so many people are going to 4.30 and 4.56 and 4.88 that we should be able to pick up the old gear sets all day, no?
  15. Jun 23, 2011 at 4:16 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    18 PreRunner TRD OffRoad DCSB
    <--- 245/75r16, 4.10 gears stock.
  16. Jun 24, 2011 at 6:07 AM
    DrunkenDangler
    AL
    fat bob lift
    could someone send me a link to some 4.10 gears for my 5 lug automatic?
  17. Jun 24, 2011 at 7:24 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    As far as I know nobody makes 4.10 gears as aftermarket. They come as stock in the +05 6 lug 4cyl trucks (can't remember about 1st gens). So your choices are to either buy a new set from Toyota or try to find a used set from forum classifieds or ECGS may have some after taking them out from someone's regear. Either way you go, I would try to get a complete third member that's already setup. You might pay a little more up front, but it saves you the trouble of finding someone to install and setup the gears. All you have to do is swap the third member out. Also, make sure whomever you get the gears or third member from, that it is the 8.4" and not the 8" elocker!!
  18. Jul 12, 2011 at 12:36 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    just use a 3rd member from any non e-locker 6 lug tacoma. 4.10s will be fine. probably find used for $100. if you are 1st gen 5 lug, different story.
  19. Jul 12, 2011 at 5:17 PM
    NakedTacoma
    NakedTacoma Well-Known Member
    West Covina
    Mid travel front Long travel rear
    not worth the money unless ur going to 32 and over .......... i have had 4.10 4.56 and now 4..88 with lsd
  20. Jul 12, 2011 at 5:18 PM
    NakedTacoma
    West Covina
    hard to find lol i payed 250 for a 3rd with lsd
