New rear suspension, not lifted, need help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Simnicf, Mar 24, 2015.
  1. Mar 24, 2015 at 8:24 AM
    Simnicf
    Simnicf [OP] New Member
    Quebec
    Tacoma DLX 2,4l 1999
    All oem
    Hello guys,
    I'm new on this forum. My wife and I bought this tacoma 1999 extented cab, 2,4l 2 wheel drive. We bought it at 106 000km and in a years we did 20 000km.
    Its the time for us to change the rear absorber. I want to add a good suspension. but i always found suspension for lift truck and not a lot of suspension are available for an original tacoma 2,4l 5 stud wheel.
    I want a good allaround suspension and increase my control on street. I always drive on road and I always have 250 pounds of sand in my bed to add some traction (2 wheel drive). Maybe 30% of the time im loaded and i will add a truck cap this summer.
    One more thing, we leave in province of quebec, so in winter a lot of salt and temp variation.
    I have 250$ - 300$ of budget for my rear suspension. Can someone guide me?
    There picture of the truck :)
    Thanks
  2. Mar 24, 2015 at 8:27 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
  3. Mar 24, 2015 at 8:33 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    If you are talking about changing the absorbers, i.e. the shocks as we call them in America, you cannot go wrong with a stock Bilstein replacement. I am sure Monroe also makes OEM replacements. Any shock is going to be better than the worn out ones you have on there now. Most of the OEM replacements will suit your needs just fine, and will fit into your $200-300 budget.
    I personally do not think you need new springs as the picture shows the truck sitting at a normal ride height. Is the picture with the bed loaded or unloaded with sand bags?
  4. Mar 24, 2015 at 8:38 AM
    Simnicf
    Quebec
    All oem
    Thanks for your suggestion,
    on the picture the truck have no sand on the bed its the oem height.
  5. Mar 25, 2015 at 12:07 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Show us a pic of it loaded down. If it squats a lot, you may want to consider new springs or having your current ones re-arched, to help handle the load if you intend to run sandbags in the bed for most of the year.
  6. Mar 25, 2015 at 11:57 AM
    Simnicf
    Quebec
    All oem
    Hello,
    there the pictures, its loaded. But I dont think the spring need to be change. I change the rear one cause it start to leak.
    THANKS
  7. Mar 25, 2015 at 12:09 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    It looks fine to me. You probably just need new shocks. There are plenty of good options for replacement that will fit in your budget. You can probably order them online, just search your vehicle and for rear shocks. Bilstein and Monroe are fairly reputable shock absorber brands.
