New rearview mirror wiring help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kenneth.morris07, Mar 13, 2014.
  1. Mar 13, 2014 at 6:29 PM
    kenneth.morris07
    kenneth.morris07 [OP] كافر‎
    Kenneth
    College Station, TX
    08 PreRunner
    Relentless Fab plate bumper,aFe Cold air intake, 12" JL sub, RE tweeters and speakers, Kenwood Head unit, Autodim/temp/compass mirror from Bob, baffled oil catch can
    So I got a Gentex mirror with autodim, compass, and temp today. I wired it up and everything with the mirror is working fine. Now my windows won't work, my dome light is acting up with the locks, my ABS, parking brake, and rear diff warning lights are on, my A/C is acting up... I'm at my wits end. The mirror is working perfectly. I tried unplugging the mirror, powering it through a different wire. Nothing is working. Does anyone have any clue how to fix this?!
  2. Mar 14, 2014 at 6:01 AM
    kenneth.morris07
    Kenneth
    College Station, TX
    08 PreRunner
    I left the battery disconnected all night. Maybe that will correct it. Any other ideas??
  3. Mar 14, 2014 at 7:38 AM
    weendoggy
    weendoggy Well-Known Member
    Aptos, CA
    2014 TRD ACOR 4x4
    Access Original Tonneau Cover; Toyota Side Tube Steps; Focal ISS690 front speakers; Clarion XC1410 mini amp; Gentex 453 rearview mirror with Homelink, Compass, Temp and Autodim; Prodigy P2 trailer brake controller, Heated Seats from www.cobraheat.com, BriteAss Fogs, Phillips Extreme LED H/L. Heated mirrors from @Up2NoGood. 5100 Bilstein all four corners.
    I'm assuming your '08 didn't come with autodim and the console temp/compass. If this was a clean install, I'm going out on a limb to ask how you put the wire through the firewall. Did you use the large grommet? Did you by chance maybe, just maybe short a wire or two when doing so? Or, did you make a clean routing for the temp sensor. Did you also do a test before putting everything in place, ie. finalizing your install. Hard to know what you did without a pic or two showing what you did or a better explanation of how you did it.
    I just installed the combo mirror in my '14 and had no problems. Give us some details to help you out.
  4. Mar 14, 2014 at 7:56 AM
    Bill in Ky
    Bill in Ky Well-Known Member
    Bright White 08 Reg 4X4 2.7 5spd SR5
    I got my first 4x4 in 1972...haven't been without one! I still like Chrome!
    I agree
  5. Mar 14, 2014 at 8:57 AM
    kenneth.morris07
    Kenneth
    College Station, TX
    08 PreRunner
    You are correct. I went through the large grommet, cut it to fit snug. Everything was clean, secured and how it should be. I thought. I looked in the interior fuse box and most of the fuses show signs of arcing. I'm having it towed to the dealership now with most likely a voided warranty.
  6. Mar 15, 2014 at 11:54 AM
    kenneth.morris07
    Kenneth
    College Station, TX
    08 PreRunner
    So it turns out that it was a blown fuse. Cheap enough fix. Hooked the mirror back up and powered it through a different source and everything's working fine now.
