New Recall~drive shaft replacement?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by volks71folk, Dec 6, 2017.
  1. Dec 11, 2017 at 1:11 PM
    #61
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I don't think this a recall. But rather a warranry enchantment of the particular parts effecting the vibration issues
  2. Dec 11, 2017 at 4:01 PM
    #62
    Manfred
    Manfred Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
  3. Dec 11, 2017 at 9:08 PM
    #63
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    I had the driveshaft replaced on my 2008 under the 60k powertrain warranty in 2011. Took it in due to vibration around 60mph, they through in a complete assembly the next day, no questions asked.
  4. Dec 12, 2017 at 4:55 AM
    #64
    TacoRob08
    TacoRob08 Well-Known Member
    Rob
    Fredericton, NB, Canada
    17 Sport DCLB
    gibson exhaust, OVTuned base 91, AFE intake
    I also had this done but did not fix the issue. I gave up on my local dealership after that.
  5. Dec 12, 2017 at 5:54 AM
    #65
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    You mean just before Freddy? That's where I got my u-joint replaced.
  6. Dec 12, 2017 at 6:14 AM
    #66
    TacoRob08
    Rob
    17 Sport DCLB
    The rear shaft was replaced back in 2011 before I had done any mods.
  7. Dec 12, 2017 at 6:29 AM
    #67
    Maticuno
    2011 Suburban 2500
    It fixed mine. I generally don't trust dealerships, but Valley Hi Toyota in Victorville has been a pleasant surprise. As was mentioned by @gearcruncher , this is likely related to no grease added after assembly, and Valley Hi greased the new one right off the bat.
    gearcruncher likes this.
  8. Dec 13, 2017 at 9:46 PM
    #68
    DR_SEYMOUR_BUSH
    DR_SEYMOUR_BUSH Well-Known Member
    Tony
    Vancouver, BC
    2008 TRD Sport DCLB BSP
    Bilstein 5100's/OME 885, LR UCA, URD exhaust/intake, Frontrunner rack
    Has anyone attempted to bring it in to the dealership even with a lift yet?
  9. Dec 14, 2017 at 9:36 AM
    #69
    TacoRob08
    Rob
    17 Sport DCLB
    I'd like to hear this as well.
    anthony250f and ovrlndkull like this.
  10. Dec 14, 2017 at 12:22 PM
    #70
    jungleman
    jungleman There can be only one
    North California
    2005 Access Cab Indigo Blue
    I'd be interested in hearing about the lifted trucks being covered also.
    It says in the fine print
    "This coverage is subject to the same terms and conditions set forth in the New Vehicle Limited Warranty Section of your Owners Warranty Information booklet. For example, damage from abuse, an accident, theft and/or vandalism is not covered"
    Doesn't say anything about modification to the suspension.
    I found everything except my owners warranty info booklet. Mustve tossed it years ago?
    Anybody still have theirs?
    The other u joints are still fine but that last one on the rear diff was beyond shot when I replaced it the first time.
    Manfred likes this.
  11. Dec 14, 2017 at 12:45 PM
    #71
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Service bulletins are just that a bulletin there is nothing to be honored anywhere if your dealer decides to honor it under warranty or just being good natured then good on them. TSBs are used even in the independent shops to help diagnose issues that manufacturers have recognized as a normal fault for said problem. The only thing by law manufacturers are required to have recalls on are Safety related items. Certain things are grey areas for safety and manufacturers choose to go ahead and issue a recall. Other non safety related recalls or extended warranties on vehicles are completely up to the discretion of the manufacturer now most choose to go ahead and issue them just to save face from a class action lawsuit or bad rap for not taking care of issues that are on a large scale if there is a large enough scale of affected vehicles. Before the wide spread internet most people never knew about TSBs they are a diagnostic tool so to speak for technicians and just because the TSB describes the issue at hand it still may not be that causing the problem it is a place to start or place of reference. Here is an example I had a dodge in one time with CEL pointing with many codes for bad O2 sensor faulty CAT etc. There was a TSB for replacing the O2 sensors and flashing (new program) the ECU. Well the issue was a squirrel or rodent got in there and chewed the wires. But the vehicle presented itself like the TSB described. I hope that clears some things up.
    On a side note I hope I'll get all new stuff from this warranty program because replacing all the U-joints and carrier bearing are on my need to replace list for maintenance purposes as well as the fronts.
  12. Dec 14, 2017 at 1:02 PM
    #72
    jungleman
    North California
    Is ur truck lifted?
    Good luck either way.
    Yeah this is a "Customer Support Program- ZH2"
    It applies specifically to the prop shaft u joints -if- the condition is verified and "in limited instances the prop shaft may be replaced if damaged due to the universal joint condition described above"
    So sounds to me like u joints and -if- the u joint failed to the point it damaged ur driveshaft like mine almost did then u also get a new driveshaft.
    I guess we wont know for sure until someone with a lift takes theirs in.
    I'll do it but not right away.
    I have until 4/30/2019
    I cant afford a diagnostic bill right now if they deny me because of a lift.
  13. Dec 14, 2017 at 1:04 PM
    #73
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    They shouldn't charge you a diag. bill for looking for a vibration what dealer do you take your's to?
  14. Dec 14, 2017 at 1:07 PM
    #74
    jungleman
    North California
    I would hope not but with my luck....
    Im not doing it until someone verifies a lift wont disqualify.
    Lithia Toyota in Reddibg is my go to for parts but as far as service & repairs Ive done mine myself.
  15. Dec 14, 2017 at 1:14 PM
    #75
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    I would look around for another dealer in your area that is better. The one near me all the techs and service guys drive lifted tacomas, t4rs, FJCs, and older FJs, so yeah they are pretty friendly to modified vehicles. Since I stopped turning wrenches and now live in an apt. I can't easily work on my own stuff so for some things I take mine to them and they have been top notch.
  16. Dec 14, 2017 at 2:13 PM
    #76
    jungleman
    North California
    The dealer has been great i would highly recommened them.
    Im not saying if they would or wouldnt, i dont know.
    ive just been burned before where i didnt read the fine print on a boat i bought, the guy wrote in a service/warranty contract and when i took it in the next season for a reccomended service visit i got a $300 bill to change the oil, spark plugs and check the lower unit fluid level.
    The owners warranty info booklet isnt available as a download from toyota....maybe a different year...
  17. Dec 14, 2017 at 2:35 PM
    #77
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Call and ask them to make 100% sure. BTW you will always get hosed with a boat new or used. A boat owner is happiest the day they buy it and the day they sell it, I believe that's the saying.
  18. Dec 14, 2017 at 2:48 PM
    #78
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    Toyota will wait until someone's driveshaft falls out and they die in a crash, then issue a recall.
    :bananadead:
  19. Dec 14, 2017 at 2:51 PM
    #79
    Extra Hard Taco
    R.J.
    Devil's Island
    Is there a way to tell what VINs are effected by this then? Help us out here brother.
  20. Dec 14, 2017 at 2:55 PM
    #80
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Does this have anything to do with the carrier bearings ?
