New Recall~drive shaft replacement?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by volks71folk, Dec 6, 2017.
  1. Feb 3, 2018 at 10:53 AM
    #161
    RCKYOTA
    RCKYOTA Member
    Shawn
    1984 x cab toyota rock crawler, 2006 trd dcsb v6 4x4 tacoma
    Crawler, locked dual t cases 37s hydro steering, built motor , everything, tacoma... stock for now !
    Yea it doesn't do it until I am accelerating mildly . Trans flush is next on my list
  2. Feb 5, 2018 at 9:29 AM
    #162
    huck123
    huck123 Well-Known Member
    Hunter
    Butte, MT
    2005 TRD OR Access Cab
    3" 33s, UCAs, Hurst Short Throw, JL 12 500 Watts
    Going in with a lift today..... Wish me luck... I have a slight vibration lets see what the dealer does. I will keep you guys posted!
    4x4Taco09 and TireFire like this.
  3. Feb 5, 2018 at 12:16 PM
    #163
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Oooooo, shiny! (actually....flat...but whatever)
    R0dzilla75 likes this.
  4. Feb 5, 2018 at 12:18 PM
    #164
    RCKYOTA
    RCKYOTA Member
    Shawn
    Did it fix the vibs or shakes?
  5. Feb 5, 2018 at 12:20 PM
    #165
    NeonHeights
    NeonHeights Well-Known Member
    I had a loud screeching coming from my rear end, it started about 2-3 weeks ago. Took it into the dealer and they immediately ordered me a new driveshaft. They claimed that the carrier bearing was starting to go, and there was play in one of the u-joints. My taco has 136,000 Miles on it and none of my u-joints/bearings had been replaced since the truck was made. The mechanic replaced the driveshaft in 30 mins and sent me on my way. The noises from my rear end have been completely gone since..
    Total cost: $0.00
    Just had my frame replaced a month ago. Now I get a brand new driveshaft along with it. Good stuff
  6. Feb 5, 2018 at 12:22 PM
    #166
    ItalynStylion
    Steven
    DFW, Tx.
    Haven't tried it yet. I have a custom shaft I had made that did the trick for me. Very interested to see if this also works as a solution. I'm going to swap it when I get home after my business trip.
  7. Feb 5, 2018 at 12:23 PM
    #167
    RCKYOTA
    RCKYOTA Member
    Shawn
    Oh Ya that is just a bad u joint they get squeaky when all dried up and fried . They didn' replace my whole shaft or carrier just u joints and it was also free. Toyota even took me home and picked me up cause they needed the truck most the day lol I'm going to get my trans flushed I think it's the shudder from the torque converer. I drive a lot 140 miles a day fluid is prob smoked
  8. Feb 5, 2018 at 12:25 PM
    #168
    NeonHeights
    Just take it easy with flushing all the fluid out if you havent done the trans fluid in a while.
    It was recommended to me to do 5 or 6 drain and fills with 2-3qts of fluid instead of a 9-10qt flush all at once
  9. Feb 5, 2018 at 12:28 PM
    #169
    RCKYOTA
    RCKYOTA Member
    Shawn
    Hmmm I have heard in the past that new fluid will make a worn out trans let go but I think the fluid has got to be thick or somthing and it' locking up the torque converter . This is the first automatic vehicle I've ever owned i knew i should have kept looking for a 6 speed man
    NeonHeights[QUOTED] likes this.
  10. Feb 5, 2018 at 12:28 PM
    #170
    RCKYOTA
    RCKYOTA Member
    Shawn
    I don' even have trans problems in my 1984 Toyota truck haha
  11. Feb 5, 2018 at 12:57 PM
    #171
    huck123
    Hunter
    Butte, MT
    OK guys so i went to the dealer sat there for about 2 hour... i was told if they didn't find anything wrong with the shaft they would charge me $50.... i was worried because i really don't feel vibration. But even with a lift they told me i need all new U joints and it was covered by warranty on top of that i got a free inspection!
    lynyrd3, TireFire and NeonHeights like this.
  12. Feb 5, 2018 at 1:25 PM
    #172
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Why is this? Seems counterintuitive to contaminate the new fluid with the old stuff. Seems pointless...
  13. Feb 5, 2018 at 1:30 PM
    #173
    lynyrd3
    Bill
    East Central Upstate NY
  14. Feb 5, 2018 at 1:44 PM
    #174
    Sistawolf
    Sistawolf New Member
    2005 Toyota Tacoma Pre-Runner TRD
    I was told the only thing covered were th ujoints not the driveshaft or carrier bearing was not under the warranty extension
  15. Feb 5, 2018 at 1:51 PM
    #175
    huck123
    Hunter
    Butte, MT
    It all is.... ujoints,driveshaft and carrier bearing! When i brought it in he immediately told me they didn't have the parts and it would be a couple days. But I ended up only qualifying for the ujoints.
  16. Feb 5, 2018 at 1:55 PM
    #176
    Sistawolf
    What the? What do you mean “qualify”? This is starting to pee me off
  17. Feb 5, 2018 at 2:19 PM
    #177
    TireFire
    Olympic Peninsula
    That means his ujoints haven't been so bad and so long that they damaged the drive shaft. Had they been Toyota would have replaced hat too (along with carrier bearing)
  18. Feb 5, 2018 at 2:20 PM
    #178
    TireFire
    Olympic Peninsula
    What's the part number on that box? And how much does it cost?
  19. Feb 5, 2018 at 2:24 PM
    #179
    huck123
    Hunter
    Butte, MT
    Ok you cant just bring your truck in and start thinking you get a box of free parts and labor. The existing parts has to meet a certain point of damage to "QUALIFY" for replacement. If your ujoints are fine than NO FREE PARTS. Its not a recall.
    TireFire likes this.
  20. Feb 5, 2018 at 2:25 PM
    #180
    RCKYOTA
    RCKYOTA Member
    Shawn
    I think they they should have replaced all of our carrier bearings too. Why only u joints . Some of the vibs might be from the rubber being soft from wear making drive shaft flop around
