New recall.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gray Tacoma, Mar 6, 2011.
  1. Mar 6, 2011 at 8:45 AM
    Gray Tacoma
    Gray Tacoma [OP] Well-Known Member
    northern West va
    11 Access cab-TRD Sport Package Mag.Gray
    Report date March 6 ,2011
    NHTSA ID number 11V148000
  2. Mar 6, 2011 at 8:46 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Model Year(s): 2008, 2009, 2010, 2011
    Mfr's Report Date: March 4, 2011
    NHTSA CAMPAIGN ID Number: 11V148000
    NHTSA Action Number: N/A
    Component: TIRES:pRESSURE MONITORING AND REGULATING SYSTEMS
    Potential Number of Units Affected: 22000
    Summary: TOYOTA IS RECALLING CERTAIN MODEL YEAR 2008 THROUGH 2011 FJ CRUISER, LAND CRUISER, TACOMA, SEQUOIA AND TUNDRA VEHICLES FOR FAILING TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 138, "TIRE PRESSURE MONITORING SYSTEM (TPMS)." THE TIRE PRESSURE MONITORING SYSTEMS WERE NOT RE-CALIBRATED CORRECTLY AND THEREFORE DO NOT START ILLUMINATING THE LOW TIRE PRESSURE WARNING TELLTALE AT THE REQUIRED MINIMUM ACTIVATION PRESSURE
    Consequence: FAILURE TO WARN OF TIRE DEFLATIONS IS A NON-COMPLIANCE WITH FMVSS 138 AND COULD LEAD TO TIRE FAILURE INCREASING THE RISK OF A CRASH.
    Remedy: DEALERS WILL RE-INITIALIZE THE TIRE PRESSURE MONITORING SYSTEM FREE OF CHARGE. THE MANUFACTURER HAS NOT YET PROVIDED AN OWNER NOTIFICATION SCHEDULE. OWNERS MAY CONTACT TOYOTA AT 1-800-331-4331.
    Notes: OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV .
  3. Mar 6, 2011 at 8:48 AM
    Kingfrog
    Kingfrog Well-Known Member
    08 TRD Rugged Trail Edition
    Undercover,Pop n Lock, Hardwired GPS, Garage door opener , Scanguage II, wireless back up camera, X994 Basslink, ...Prefer stock and non invasive functional mods
    We drove for years without TPMS and now its a recall? Can't people just check the air pressure in their vehicles now and then?
  4. Mar 6, 2011 at 9:02 AM
    JKD
    JKD Well-Known Member
    Isn't recalibration just airing the tires to the proper pressure and then pressing the TPMS button?
  5. Mar 6, 2011 at 9:07 AM
    PAlittlematty
    PAlittlematty "the soulless ginger"
    Beech Creek, PA
    Casper the friendly Taco
    OME Lift, 885 Coils, 13MM Top Spacer, Dakar Leafs, DSM UCAs, Homeroshi Flush Mount Grille, WeatherTech Digifit Mats, Bestop Super Top, Toyota Bed Extender, Clevice Receiver 1990 SR5 3.slow 4" bracket and 35s. MC rear AP front bumpers 5.29s locked
    Somethin clicks there. When I bought my 2011 it took the mechanics like a half hour to get my '08 wheels n the new truck to sync together
  6. Mar 6, 2011 at 9:18 AM
    brettb
    brettb Well-Known Member
    Brett
    Laramie, Wyoming
    '99 Tacoma
    Oh no man. We cant check tire pressure. Too much work. With the automatic doors and such these days why would you check tire pressure? I think I need to get that on my first gen now...
  7. Mar 6, 2011 at 9:21 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    this.... :thumbsup:
    People are fuckin' lazy man!!!
    My 05 didn't come with TPMS :woot:
  8. Mar 6, 2011 at 9:26 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    But, but, but... it's cold out there.... it's wet out there.... I might break a nail.... Why should I check it? It looks round, so there must be enough air in the tire.... :D
  9. Mar 6, 2011 at 9:28 AM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    i know right?? and it feels like theres enough air to me..i pressed it with my finger and it didnt move.. but i dont wanna press too hard kuzi dont want to break my nail
  10. Mar 6, 2011 at 9:29 AM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    30 minutes with the programming tool sounds a bit long , but not too long. When I had my new aluminum wheels put on, with new sensors, it took them about as long to get each sensor scanned and inputted into the ecu for it.
    Since us old pioneers put our life a great risk to learn driving without TPMS...for decades , i wont worry about it. Oops , my bad, we had a TPMS back then too .....Mk 1 pressure guage, but they lacked a fancy light and symbol, only a number.
    As a kid I would've thought things like aribags,TPMS,ABS,and other traction controls, were going to make things better. I think they do ...sorta. More like people got lazier and more brazen with these new found safeties, like they can drive at the edge w/o consequnce and just sue if anything goes wrong.
    Part fact part opinion.... TPMS was made because some idiots in the 1990s were in Explorers and didnt check their tire psi, tires were marginally safe, low psi made em unsafe due to a blowout. Panic ensued as to no control possible , even in light of tests showing they wouldnt careen out of control.
    I beleive in safety , I wont bypass my TPMS ,at some level it will help someone. I intend to keep using my psi guage to keep making TPMS look like the idiot-born/government intervention for idiots thing that it is.
  11. Mar 6, 2011 at 9:32 AM
    The Munster
    The Munster I like turtles!!!
    Lance
    Moody AFB, GA
    no it's a little more complicated, every sensor has its own serial number, every vehicle has to be programed with those serial numbers. theres and sst that looks kinda like and old school game boy that syncs with the sensor and tells us the serial code, next we get the techstream and enter all the serial numbers in to the TPMS ECU, and BAM all done. pays 1hr at my shop :cool:
